Full time rocker oiling, what restrictor size? #2726573
12/24/19 11:49 AM
12/24/19 11:49 AM
Missouri
galen Offline OP
galen  Offline OP
Missouri
I have a 400 block. Galleys to supply heads have been drilled to lifter galleys for full time oil supply to rockers. #4 cam bushing has been rotated and drilled to no longer supply oil to top. My question is what size restrictors should I start with in the deck for Harland Sharp rockers? Ball & Cup, Trick flow heads. Thinking the world blocks ran .035 or .040 screw in restrictors at the deck but not positive.
Re: Full time rocker oiling, what restrictor size? [Re: galen] #2726576
12/24/19 11:57 AM
12/24/19 11:57 AM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
IIRC, .060 is commonly used with Indy feed lines. My Victors have. 090 restrictors in the #4 shaft pedestals, but could possibly be decreased in size.
Re: Full time rocker oiling, what restrictor size? [Re: galen] #2726587
12/24/19 12:30 PM
12/24/19 12:30 PM
on a side note what about drilling/tapping/adding the restrictors in the rocker stands, that way if you ain't happy with the flow you can easily alter it.
Re: Full time rocker oiling, what restrictor size? [Re: RapidRobert] #2726601
12/24/19 01:08 PM
12/24/19 01:08 PM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
One other way... bush the stand... I put a .035 in mine. These are BS heads.
Re: Full time rocker oiling, what restrictor size? [Re: B1MAXX] #2726607
12/24/19 01:17 PM
12/24/19 01:17 PM
Missouri
galen Offline OP
galen  Offline OP
Missouri
Thanks guys. I will look at the stands and see if I can put the restrictor there. That would make it a lot easier to change.
Re: Full time rocker oiling, what restrictor size? [Re: galen] #2726669
12/24/19 05:27 PM
12/24/19 05:27 PM
Fulton County, PA
CMcAllister Online content
Mr. Helpful
CMcAllister  Online Content
Mr. Helpful
Fulton County, PA
I'm thinking I had .045 in the deck with my small block. Slightly elevated wear on the Crane Gold rockers. My goal was to get the oil to a safe minimum. Just watch the rocker gear and pushrods. Adjust accordingly. I didn't mind working on my stuff. Better than blowing it up.
Re: Full time rocker oiling, what restrictor size? [Re: galen] #2726691
12/24/19 07:56 PM
12/24/19 07:56 PM
World BB iron Mopar blocks came with a .039 to .042 restrictors in their oil feed passages to the rocker arm stock shruggy work
I like to use a smaller size on caged needle bearing rockers arms than on a rocker arm on shaft with no needle bearings up work
Re: Full time rocker oiling, what restrictor size? [Re: Cab_Burge] #2726754
12/25/19 10:01 AM
12/25/19 10:01 AM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
I agree, mine is a T&d set up. with a bushed set up I would be afraid to go less than .060. When I had Koffel's rocker I didn't use any restriction.
Re: Full time rocker oiling, what restrictor size? [Re: B1MAXX] #2726794
12/25/19 12:20 PM
12/25/19 12:20 PM
BradH Offline
BradH  Offline
I'm going to leave mine at .090 since I don't use needle bearing rockers.
Re: Full time rocker oiling, what restrictor size? [Re: BradH] #2727946
12/29/19 11:02 AM
12/29/19 11:02 AM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
I used .040 in both sides, cam grooved for full time oiling. Rocker gear, push rods and valve tips looked good after a bunch of dyno pulls and a few tests with a little spritz of the happy gas.
Last edited by Jeremiah; 12/29/19 11:06 AM. Reason: I blame everything in infolinks
