Re: Full time rocker oiling, what restrictor size?
[Re: galen]
#2726587
12/24/19 12:30 PM
12/24/19 12:30 PM
RapidRobert
on a side note what about drilling/tapping/adding the restrictors in the rocker stands, that way if you ain't happy with the flow you can easily alter it.
[Re: RapidRobert]
#2726601
12/24/19 01:08 PM
12/24/19 01:08 PM
Posts: 1,979 Apollo, PA.
B1MAXX
Apollo, PA.
One other way... bush the stand... I put a .035 in mine. These are BS heads.
[Re: galen]
#2726669
12/24/19 05:27 PM
12/24/19 05:27 PM
Posts: 11,551 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
I'm thinking I had .045 in the deck with my small block. Slightly elevated wear on the Crane Gold rockers. My goal was to get the oil to a safe minimum. Just watch the rocker gear and pushrods. Adjust accordingly. I didn't mind working on my stuff. Better than blowing it up.
[Re: BradH]
#2727946
12/29/19 11:02 AM
12/29/19 11:02 AM
Posts: 9,099 Rogue River, OR
Jeremiah
Rogue River, OR
I used .040 in both sides, cam grooved for full time oiling. Rocker gear, push rods and valve tips looked good after a bunch of dyno pulls and a few tests with a little spritz of the happy gas.
Last edited by Jeremiah; 12/29/19 11:06 AM. Reason: I blame everything in infolinks
