Street Outlaws Procharged Hemis #2719873
11/27/19 09:52 PM
11/27/19 09:52 PM
Alberta Canada
E
Edge Offline OP
Edge  Offline OP
E
Alberta Canada
Does anyone know specifically how they are controlling power on the procharged combinations that are on street outlaws. There have been a few hemi procharged setups and I was wondering if they can manage the power to get down the track just with timing or are they controller boost ? changing ratios ? I had heard that you would not be able to pull enough power with timing alone ?
76 Duster work in progress
Re: Street Outlaws Procharged Hemis [Re: Edge] #2719884
11/27/19 10:36 PM
11/27/19 10:36 PM
New York
polyspheric Offline
polyspheric  Offline
New York
"An engine with ignition set at TDC does not produce enough power to idle": David Vizard
Boffin Emeritus
Re: Street Outlaws Procharged Hemis [Re: polyspheric] #2719987
11/28/19 10:38 AM
11/28/19 10:38 AM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
It would appear DV hasn’t done a lot of tune up work on 60’s era Mopars.
Quite a few used TDC as the spec for timing at idle...... and there are also some that use 2-5deg ATDC.
Re: Street Outlaws Procharged Hemis [Re: fast68plymouth] #2720008
11/28/19 11:24 AM
11/28/19 11:24 AM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
Depending on air temps, I would use anywhere from 0° to -10° to maintain rpm and build boost when staging (turbo). Procharged cars can use timing for smooth power management, and/ or blow off valve actuation for abrupt traction loss.
Timing is more effective with a blower than with a turbo. Reduced timing with a turbo increases exhaust heat, speeding up the wheels in the turbo. That effect is non existent in a procharged car.
Re: Street Outlaws Procharged Hemis [Re: polyspheric] #2720118
11/28/19 05:20 PM
11/28/19 05:20 PM
Left Coast
BobR Offline
BobR  Offline
Left Coast
Complete and utter fallacy.
Re: Street Outlaws Procharged Hemis [Re: TRENDZ] #2720120
11/28/19 05:21 PM
11/28/19 05:21 PM
Left Coast
BobR Offline
BobR  Offline
Left Coast
Nobody I know uses any kind of boost control with blowers of any kind. It is all done with timing and fuel.
Re: Street Outlaws Procharged Hemis [Re: BobR] #2720121
11/28/19 05:26 PM
11/28/19 05:26 PM
Guitar Jones Offline
Dave is a pretty smart guy but he was probably just thinking about Chevrolets.
'74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon!
Re: Street Outlaws Procharged Hemis [Re: Guitar Jones] #2720134
11/28/19 07:03 PM
11/28/19 07:03 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
If they are using the individual coils per cylinder, with Fuel Tech, I heard they can pull a ton of timing, even going way negative to bring the power in as they want. ......
https://www.youtube.com/watch?v=ewNUmH8Y4HY
Re: Street Outlaws Procharged Hemis [Re: BobR] #2720147
11/28/19 07:42 PM
11/28/19 07:42 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
Look for solenoids on BOVs... especially on cars with dual BOVs. We all know how simple a BOV can be used/ plumbed. When you can’t see where the actuator lines go......
Re: Street Outlaws Procharged Hemis [Re: TRENDZ] #2720233
11/29/19 12:01 PM
11/29/19 12:01 PM
Left Coast
BobR Offline
BobR  Offline
Left Coast
Timing is more accurate and much quicker acting. If they get into a position where that's not enough they add a bunch of fuel.
Re: Street Outlaws Procharged Hemis [Re: fast68plymouth] #2720272
11/29/19 03:46 PM
11/29/19 03:46 PM
Springtown Pa
Ray408G3Hemi Offline
Springtown Pa
Or todays G3 hemi
1963 Thunderbolt 496FE 10.80 (still a work in progress)
1968 Mustang slow a$$ 428 FE
1971 Boss 351 Mustang 11.20@115mph
1993 Lightning 10.61 @ 129mph 408Ci A3 headed NA
1996 Viper GTS
2001 Lightning 8.99 @ 155MPH 5.4 Mod Motor
2009 Ram 9.65@144MPH 463CI G3 NA
2010 Challenger 9.91 @ 139MPH 408CI G3ci NA
2019 F150 (local dealer's Lightning package) ..11.90s
Re: Street Outlaws Procharged Hemis [Re: Dragula] #2720273
11/29/19 03:49 PM
11/29/19 03:49 PM
Springtown Pa
Springtown Pa
My 01 Lightning that's how I control it
1996 Viper GTS
Re: Street Outlaws Procharged Hemis [Re: Ray408G3Hemi] #2722463
12/08/19 08:21 AM
12/08/19 08:21 AM
pa
572charger Offline
572charger  Offline
pa
my procharged hemi we use timming , i have a FAST ecu and a digital 7 ing box but its all done though the FAST , even when my air charge temps go up it takes out timming to compensate for the heat. its a big learning curve hope to get some better passes next year its been 160mph in the 1/4 on street tires and a base tune at 3960 lbs
606 hemi pump gas best 9.60 at 142mph on motor
05 hemi daytona 1500 go-mango 4wd quadcab
2007 hotrod mag pump gas drags runner up, roadkill nights dodge big tire winner 2018 2019 back to back
Re: Street Outlaws Procharged Hemis [Re: 572charger] #2722476
12/08/19 09:53 AM
12/08/19 09:53 AM
Texas
dannysbee Offline
dannysbee  Offline
Texas
Wow. My Moroso speed calculator tilted on that one. Lol. Over 1200 HP.
Getting old just means you were smarter than some and luckier than others.
Re: Street Outlaws Procharged Hemis [Re: dannysbee] #2722488
12/08/19 10:41 AM
12/08/19 10:41 AM
Mo.
racerx Offline
racerx  Offline
Mo.
And I no you said with street tires, but at a 160mph there were a lot of tire spend. What et did it run?
Re: Street Outlaws Procharged Hemis [Re: racerx] #2725777
12/21/19 07:27 AM
12/21/19 07:27 AM
pa
572charger Offline
572charger  Offline
pa
i could not get it to leave the starting line it had a 2.60 60 ft and ran 9.43 at 160 mph !!!! it did go a 5.69 in the 1/8 at road killnights in aug i was fighting a tuning prob but is was enough to win the big tire dodge class [5,000.00] my tuner wasnt at the track with me ,last time out im going to get it on a chassis dyno in the spring , yes it did make 1381 on the engine dyno on a base tune it is true hemis like to be blown LOL
Re: Street Outlaws Procharged Hemis [Re: 572charger] #2725792
12/21/19 09:47 AM
12/21/19 09:47 AM
Mo.
racerx Offline
racerx  Offline
Mo.
thumbs
