Street Outlaws Procharged Hemis
#2719873
11/27/19 09:52 PM
11/27/19 09:52 PM
Posts: 698 Alberta Canada
Edge
Alberta Canada
Does anyone know specifically how they are controlling power on the procharged combinations that are on street outlaws. There have been a few hemi procharged setups and I was wondering if they can manage the power to get down the track just with timing or are they controller boost ? changing ratios ? I had heard that you would not be able to pull enough power with timing alone ?
76 Duster
work in progress
Re: Street Outlaws Procharged Hemis
[Re: Edge]
#2719884
11/27/19 10:36 PM
11/27/19 10:36 PM
Posts: 4,206 New York
polyspheric
New York
"An engine with ignition set at TDC does not produce enough power to idle": David Vizard
Boffin Emeritus
[Re: polyspheric]
#2719987
11/28/19 10:38 AM
11/28/19 10:38 AM
Posts: 14,492 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
It would appear DV hasn’t done a lot of tune up work on 60’s era Mopars. Quite a few used TDC as the spec for timing at idle...... and there are also some that use 2-5deg ATDC.
[Re: fast68plymouth]
#2720008
11/28/19 11:24 AM
11/28/19 11:24 AM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
Depending on air temps, I would use anywhere from 0° to -10° to maintain rpm and build boost when staging (turbo). Procharged cars can use timing for smooth power management, and/ or blow off valve actuation for abrupt traction loss. Timing is more effective with a blower than with a turbo. Reduced timing with a turbo increases exhaust heat, speeding up the wheels in the turbo. That effect is non existent in a procharged car.
[Re: polyspheric]
#2720118
11/28/19 05:20 PM
11/28/19 05:20 PM
Posts: 8,165 Left Coast
BobR
Left Coast
"An engine with ignition set at TDC does not produce enough power to idle": David Vizard Complete and utter fallacy.
[Re: TRENDZ]
#2720120
11/28/19 05:21 PM
11/28/19 05:21 PM
BobR
Left Coast
Depending on air temps, I would use anywhere from 0° to -10° to maintain rpm and build boost when staging (turbo). Procharged cars can use timing for smooth power management, and/ or blow off valve actuation for abrupt traction loss. Timing is more effective with a blower than with a turbo. Reduced timing with a turbo increases exhaust heat, speeding up the wheels in the turbo. That effect is non existent in a procharged car. Nobody I know uses any kind of boost control with blowers of any kind. It is all done with timing and fuel.
[Re: BobR]
#2720121
11/28/19 05:26 PM
11/28/19 05:26 PM
Posts: 20,627 in a cattle trailer down by th...
Guitar Jones
"An engine with ignition set at TDC does not produce enough power to idle": David Vizard Complete and utter fallacy. Dave is a pretty smart guy but he was probably just thinking about Chevrolets.
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon! 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
[Re: BobR]
#2720147
11/28/19 07:42 PM
11/28/19 07:42 PM
TRENDZ
Milwaukee WI
Depending on air temps, I would use anywhere from 0° to -10° to maintain rpm and build boost when staging (turbo). Procharged cars can use timing for smooth power management, and/ or blow off valve actuation for abrupt traction loss. Timing is more effective with a blower than with a turbo. Reduced timing with a turbo increases exhaust heat, speeding up the wheels in the turbo. That effect is non existent in a procharged car. Nobody I know uses any kind of boost control with blowers of any kind. It is all done with timing and fuel. Look for solenoids on BOVs... especially on cars with dual BOVs. We all know how simple a BOV can be used/ plumbed. When you can’t see where the actuator lines go......
[Re: TRENDZ]
#2720233
11/29/19 12:01 PM
11/29/19 12:01 PM
BobR
Left Coast
Depending on air temps, I would use anywhere from 0° to -10° to maintain rpm and build boost when staging (turbo). Procharged cars can use timing for smooth power management, and/ or blow off valve actuation for abrupt traction loss. Timing is more effective with a blower than with a turbo. Reduced timing with a turbo increases exhaust heat, speeding up the wheels in the turbo. That effect is non existent in a procharged car. Nobody I know uses any kind of boost control with blowers of any kind. It is all done with timing and fuel. Look for solenoids on BOVs... especially on cars with dual BOVs. We all know how simple a BOV can be used/ plumbed. When you can’t see where the actuator lines go...... Timing is more accurate and much quicker acting. If they get into a position where that's not enough they add a bunch of fuel.
#2720272
11/29/19 03:46 PM
11/29/19 03:46 PM
Posts: 194 Springtown Pa
Ray408G3Hemi
Springtown Pa
It would appear DV hasn’t done a lot of tune up work on 60’s era Mopars. Quite a few used TDC as the spec for timing at idle...... and there are also some that use 2-5deg ATDC. Or todays G3 hemi
1963 Thunderbolt 496FE 10.80 (still a work in progress) 1968 Mustang slow a$$ 428 FE 1971 Boss 351 Mustang 11.20@115mph 1993 Lightning 10.61 @ 129mph 408Ci A3 headed NA 1996 Viper GTS 2001 Lightning 8.99 @ 155MPH 5.4 Mod Motor 2009 Ram 9.65@144MPH 463CI G3 NA 2010 Challenger 9.91 @ 139MPH 408CI G3ci NA 2019 F150 (local dealer's Lightning package) ..11.90s
[Re: Dragula]
#2720273
11/29/19 03:49 PM
11/29/19 03:49 PM
Ray408G3Hemi
Springtown Pa
If they are using the individual coils per cylinder, with Fuel Tech, I heard they can pull a ton of timing, even going way negative to bring the power in as they want. ...... https://www.youtube.com/watch?v=ewNUmH8Y4HY My 01 Lightning that's how I control it
[Re: Ray408G3Hemi]
#2722463
12/08/19 08:21 AM
12/08/19 08:21 AM
Posts: 1,629 pa
572charger
pa
my procharged hemi we use timming , i have a FAST ecu and a digital 7 ing box but its all done though the FAST , even when my air charge temps go up it takes out timming to compensate for the heat. its a big learning curve hope to get some better passes next year its been 160mph in the 1/4 on street tires and a base tune at 3960 lbs
606 hemi pump gas best 9.60 at 142mph on motor 05 hemi daytona 1500 go-mango 4wd quadcab 2007 hotrod mag pump gas drags runner up, roadkill nights dodge big tire winner 2018 2019 back to back
[Re: 572charger]
#2722476
12/08/19 09:53 AM
12/08/19 09:53 AM
Posts: 5,160 Texas
dannysbee
Texas
my procharged hemi we use timming , i have a FAST ecu and a digital 7 ing box but its all done though the FAST , even when my air charge temps go up it takes out timming to compensate for the heat. its a big learning curve hope to get some better passes next year its been 160mph in the 1/4 on street tires and a base tune at 3960 lbs Wow. My Moroso speed calculator tilted on that one. Lol. Over 1200 HP.
Getting old just means you were smarter than some and luckier than others.
[Re: dannysbee]
#2722488
12/08/19 10:41 AM
12/08/19 10:41 AM
Posts: 4,066 Mo.
racerx
Mo.
my procharged hemi we use timming , i have a FAST ecu and a digital 7 ing box but its all done though the FAST , even when my air charge temps go up it takes out timming to compensate for the heat. its a big learning curve hope to get some better passes next year its been 160mph in the 1/4 on street tires and a base tune at 3960 lbs Wow. My Moroso speed calculator tilted on that one. Lol. Over 1200 HP. And I no you said with street tires, but at a 160mph there were a lot of tire spend. What et did it run?
[Re: racerx]
#2725777
12/21/19 07:27 AM
12/21/19 07:27 AM
Posts: 1,629 pa
572charger
pa
i could not get it to leave the starting line it had a 2.60 60 ft and ran 9.43 at 160 mph !!!! it did go a 5.69 in the 1/8 at road killnights in aug i was fighting a tuning prob but is was enough to win the big tire dodge class [5,000.00] my tuner wasnt at the track with me ,last time out im going to get it on a chassis dyno in the spring , yes it did make 1381 on the engine dyno on a base tune it is true hemis like to be blown LOL
[Re: 572charger]
#2725792
12/21/19 09:47 AM
12/21/19 09:47 AM
Posts: 4,066 Mo.
racerx
Mo.
