Holley 6 pack original carb? #2717238
11/18/19 04:30 PM
11/18/19 04:30 PM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
Does anyone know if the center carb on a six pack has a check valve and does it have a squirter?
I can't seem to locate it on the carb.
Re: Holley 6 pack original carb? [Re: Sammy] #2717242
11/18/19 04:50 PM
11/18/19 04:50 PM
TN
1DGEMAN Offline
1DGEMAN  Offline
TN
I think you are in over your head
Real Men shift for themselves
Re: Holley 6 pack original carb? [Re: Sammy] #2717318
11/18/19 09:26 PM
11/18/19 09:26 PM
Alll three years of both the BB and SB,1970 only, six pack motors had accelerator pumps and squirters in the center carbs. only thumbs
Re: Holley 6 pack original carb? [Re: Cab_Burge] #2717354
11/18/19 11:33 PM
11/18/19 11:33 PM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
Cab, is the squirter visible from the top?
Coukdnt see it in the choke primary section
Re: Holley 6 pack original carb? [Re: Sammy] #2717362
11/19/19 12:12 AM
11/19/19 12:12 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Look again ! scope
Re: Holley 6 pack original carb? [Re: 62maxwgn] #2717369
11/19/19 12:48 AM
11/19/19 12:48 AM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
The check valve is under the acc pump's cover underneath the center carb's float bowl.
it's held in place by a small staked strap.
You can see if it's still in place if you look under the diaphragm.
If it has come loose, mine did once, you won't see anything from the squirters.
Joe
Re: Holley 6 pack original carb? [Re: jlatessa] #2717374
11/19/19 01:07 AM
11/19/19 01:07 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
You also won't see anything if the check valve here is missing.
Re: Holley 6 pack original carb? [Re: Sammy] #2717577
11/19/19 03:32 PM
11/19/19 03:32 PM
Yes it is, it is located directly behind the front fuel bowl vent tube above the venture below the choke platescope
Re: Holley 6 pack original carb? [Re: Cab_Burge] #2717595
11/19/19 04:17 PM
11/19/19 04:17 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Cab,would you like to clarify ? no grin
All three years of both the BB and SB,1970 only six pack motors had accelerator pumps and squirters in the center carbs. only
Re: Holley 6 pack original carb? [Re: 62maxwgn] #2717624
11/19/19 06:10 PM
11/19/19 06:10 PM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
My choke was covering the whole top of the center carb. It is there.
But a question. If I let the car sit for over a week it will not start without pouring gas down the center carb. The carbs were rebuilt and done to factory specs and the car idles, runs and revs perfectly.
The squirters seems to be working fine. How can I fix this problem? I was thinking check valve is stuck. Car does sit for a long period of time.
Re: Holley 6 pack original carb? [Re: Sammy] #2717630
11/19/19 06:42 PM
11/19/19 06:42 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Your problem may just be todays quality of gas. It seems to evaporate quicker than it used to. Try cranking it over a little longer to get gas up to the carbs.
Re: Holley 6 pack original carb? [Re: Sammy] #2717632
11/19/19 06:46 PM
11/19/19 06:46 PM
Usa
A39Coronet Offline
A39Coronet  Offline
Usa
With the engine off, and the throttle on the plastic high idle, is there a gap between the rubber stopper and the opening on the top of the float bowl? If so, gas could be evaporating out the vent. On an OTB Holley center I had to do quite a bit of bending to that arm to get it right. Could be making the issue even worse if center float bowls are set low.
Follow my G3 Hemi Barracuda build on Youtube
https://www.youtube.com/watch?v=XSDAWczXoZw&list=PLTus_wQu8POADHEeJNJp2nr4NMHEyB9EK
2015 Tri-State Stock Super Stock Champion
2017 Monster Mopar Pro Winner
2018 Monster Mopar No Box Winner
Re: Holley 6 pack original carb? [Re: 62maxwgn] #2717633
11/19/19 06:49 PM
11/19/19 06:49 PM
Mopar offered the six pack on 340 motors in 1970 only in the T/A Challengers and AAR Cuda work
Is this clear enough or is there something else you want me to try and clear up on that post?
Re: Holley 6 pack original carb? [Re: A39Coronet] #2717710
11/19/19 09:55 PM
11/19/19 09:55 PM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
I'm going to check that tomorrow.
I never checked them after they were restored. Hopefully they were set right.
Re: Holley 6 pack original carb? [Re: Sammy] #2717728
11/19/19 10:57 PM
11/19/19 10:57 PM
Ont, Canada
gygeneral Offline
gygeneral  Offline
Ont, Canada
I have the same problem, i got myself a syringe and I put fuel through the vent hole on the center carb, it starts right up. I gave up trying to solve this LOL, I'm thinking the fuel just evaporates from the bowl throught the vent.
Maybe someone will have a suggestion
Re: Holley 6 pack original carb? [Re: Cab_Burge] #2717745
11/20/19 12:41 AM
11/20/19 12:41 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Well actually since you said all three years both big and small block,that would have included the 340,you could have left the 1970 only out or maybe something to do with the punctuation,you can read it two different ways . shruggy Isn't picking fun ?? argue beer
Re: Holley 6 pack original carb? [Re: 62maxwgn] #2717757
11/20/19 03:18 AM
11/20/19 03:18 AM
When in doubt ask questions up
