Re: Holley 6 pack original carb?
[Re: Sammy]
#2717242
11/18/19 04:50 PM
11/18/19 04:50 PM
Posts: 604 TN
1DGEMAN
TN
I think you are in over your head
Real Men shift for themselves
[Re: Cab_Burge]
#2717354
11/18/19 11:33 PM
11/18/19 11:33 PM
Posts: 1,823 Wind Gap,Pa.
Sammy
Wind Gap,Pa.
Alll three years of both the BB and SB,1970 only, six pack motors had accelerator pumps and squirters in the center carbs. only Cab, is the squirter visible from the top? Coukdnt see it in the choke primary section
[Re: Sammy]
#2717362
11/19/19 12:12 AM
11/19/19 12:12 AM
Posts: 9,436 Blair County,PA
62maxwgn
Blair County,PA
Alll three years of both the BB and SB,1970 only, six pack motors had accelerator pumps and squirters in the center carbs. only Cab, is the squirter visible from the top? Coukdnt see it in the choke primary section Look again !
[Re: Cab_Burge]
#2717595
11/19/19 04:17 PM
11/19/19 04:17 PM
62maxwgn
Blair County,PA
Alll three years of both the BB and SB,1970 only, six pack motors had accelerator pumps and squirters in the center carbs. only Cab,would you like to clarify ? All three years of both the BB and SB, 1970 only six pack motors had accelerator pumps and squirters in the center carbs. only
[Re: 62maxwgn]
#2717624
11/19/19 06:10 PM
11/19/19 06:10 PM
Sammy
Wind Gap,Pa.
You also won't see anything if the check valve here is missing. My choke was covering the whole top of the center carb. It is there. But a question. If I let the car sit for over a week it will not start without pouring gas down the center carb. The carbs were rebuilt and done to factory specs and the car idles, runs and revs perfectly. The squirters seems to be working fine. How can I fix this problem? I was thinking check valve is stuck. Car does sit for a long period of time.
[Re: Sammy]
#2717632
11/19/19 06:46 PM
11/19/19 06:46 PM
Posts: 1,111 Usa
A39Coronet
Usa
You also won't see anything if the check valve here is missing. My choke was covering the whole top of the center carb. It is there. But a question. If I let the car sit for over a week it will not start without pouring gas down the center carb. The carbs were rebuilt and done to factory specs and the car idles, runs and revs perfectly. The squirters seems to be working fine. How can I fix this problem? I was thinking check valve is stuck. Car does sit for a long period of time. With the engine off, and the throttle on the plastic high idle, is there a gap between the rubber stopper and the opening on the top of the float bowl? If so, gas could be evaporating out the vent. On an OTB Holley center I had to do quite a bit of bending to that arm to get it right. Could be making the issue even worse if center float bowls are set low.
[Re: 62maxwgn]
#2717633
11/19/19 06:49 PM
11/19/19 06:49 PM
Posts: 43,118 Bend,OR USA
Cab_Burge
Alll three years of both the BB and SB,1970 only, six pack motors had accelerator pumps and squirters in the center carbs. only Cab,would you like to clarify ? All three years of both the BB and SB, 1970 only six pack motors had accelerator pumps and squirters in the center carbs. only Mopar offered the six pack on 340 motors in 1970 only in the T/A Challengers and AAR Cuda Is this clear enough or is there something else you want me to try and clear up on that post?
[Re: A39Coronet]
#2717710
11/19/19 09:55 PM
11/19/19 09:55 PM
Sammy
Wind Gap,Pa.
You also won't see anything if the check valve here is missing. My choke was covering the whole top of the center carb. It is there. But a question. If I let the car sit for over a week it will not start without pouring gas down the center carb. The carbs were rebuilt and done to factory specs and the car idles, runs and revs perfectly. The squirters seems to be working fine. How can I fix this problem? I was thinking check valve is stuck. Car does sit for a long period of time. With the engine off, and the throttle on the plastic high idle, is there a gap between the rubber stopper and the opening on the top of the float bowl? If so, gas could be evaporating out the vent. On an OTB Holley center I had to do quite a bit of bending to that arm to get it right. Could be making the issue even worse if center float bowls are set low. I'm going to check that tomorrow. I never checked them after they were restored. Hopefully they were set right.
[Re: Cab_Burge]
#2717745
11/20/19 12:41 AM
11/20/19 12:41 AM
62maxwgn
Blair County,PA
Alll three years of both the BB and SB,1970 only, six pack motors had accelerator pumps and squirters in the center carbs. only Cab,would you like to clarify ? All three years of both the BB and SB, 1970 only six pack motors had accelerator pumps and squirters in the center carbs. only Mopar offered the six pack on 340 motors in 1970 only in the T/A Challengers and AAR Cuda Is this clear enough or is there something else you want me to try and clear up on that post? Well actually since you said all three years both big and small block,that would have included the 340,you could have left the 1970 only out or maybe something to do with the punctuation,you can read it two different ways . Isn't picking fun ??
