BB HV oil pump oil
#2716668
11/17/19 12:05 PM
11/17/19 12:05 PM
Posts: 246 gainsville, usa
johnfin
gainsville, usa
I found a HV oil pump in my garage and was thinking of using it my stock 440 rebuild. Non race engine. Is this a bad idea?
Re: BB HV oil pump oil
[Re: johnfin]
#2716763
11/17/19 03:12 PM
11/17/19 03:12 PM
Posts: 43,129 Bend,OR USA
Cab_Burge
I use them on all of my engine builds regardless of the application Oil supply is like money, HP, traction, sex,common sense, fun and a lot of other things a man can never have to much of AKA I like them
[Re: Cab_Burge]
#2716814
11/17/19 06:19 PM
11/17/19 06:19 PM
Posts: 25,757 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Oil supply is like money, HP, traction, sex,common sense, fun and a lot of other things a man can never have to much of Nice cliché but...............
[Re: DrCharles]
#2716936
11/17/19 10:00 PM
11/17/19 10:00 PM
Posts: 4,943 WI
Dcuda69
WI
Stock clearances? Stock RPM? Use a stock pump. In this application, a HV pump will just waste power and heat the oil more by circulating the excess back through the relief valve. Pressure and volume are different things. You can have a high volume pump with a 40 psi spring in the relief valve.
[Re: Dcuda69]
#2716959
11/17/19 10:30 PM
11/17/19 10:30 PM
Posts: 4,220 West Plains, MO
DrCharles
West Plains, MO
Pressure and volume are different things. You don't say. More importantly, if the engine clearances don't need enough oil to pass the full pump volume at 40 psi (or whatever the relief spring pressure is), the rest will circulate through the relief valve, as I pointed out to begin with! The gerotor pump is a positive-displacement design. Every revolution, the oil has to go somewhere. If it's not going through the bearings, lifters, etc. then it is just wasted volume.
