BB HV oil pump oil #2716668
11/17/19 12:05 PM
11/17/19 12:05 PM
gainsville, usa
johnfin Offline OP
johnfin  Offline OP
gainsville, usa
I found a HV oil pump in my garage and was thinking of using it my stock 440 rebuild. Non race engine. Is this a bad idea?
Re: BB HV oil pump oil [Re: johnfin] #2716670
11/17/19 12:09 PM
11/17/19 12:09 PM
West Plains, MO
DrCharles Offline
DrCharles  Offline
West Plains, MO
Stock clearances? Stock RPM? Use a stock pump.
In this application, a HV pump will just waste power and heat the oil more by circulating the excess back through the relief valve. twocents
Re: BB HV oil pump oil [Re: DrCharles] #2716704
11/17/19 01:15 PM
11/17/19 01:15 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
What he said !!
Re: BB HV oil pump oil [Re: johnfin] #2716763
11/17/19 03:12 PM
11/17/19 03:12 PM
I use them on all of my engine builds regardless of the application shruggy
Oil supply is like money, HP, traction, sex,common sense, fun and a lot of other things a man can never have to much of whistling AKA I like them up
Re: BB HV oil pump oil [Re: Cab_Burge] #2716810
11/17/19 06:12 PM
11/17/19 06:12 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Depends on how "rebuilt" you plan to go whether it's necessary or not.
Proper machine shop build with all clearances checked and corrected to stock non race specs, not necessary.
Old school loose race clearances or just a backyard hone, re-ring with new rod and main bearings on a 100,000 mile core, probably not a bad idea.
Will it hurt anything? Not likely.
Make sure you disassemble it completely and clean it. Countless examples of machining debris left in them from manufacture causing the rotors to jam and shear off the pump drive, making engine go boom.
Kevin
Re: BB HV oil pump oil [Re: Cab_Burge] #2716814
11/17/19 06:19 PM
11/17/19 06:19 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Nice cliché but...............
Re: BB HV oil pump oil [Re: John_Kunkel] #2716825
11/17/19 06:50 PM
11/17/19 06:50 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Speaking of oil pumps!! work
Re: BB HV oil pump oil [Re: johnfin] #2716916
11/17/19 09:37 PM
11/17/19 09:37 PM
Usa
A39Coronet Offline
A39Coronet  Offline
Usa
It'll peg the dash needle but we've had two decades of use without issue on a mild 440. No clue the tolerances.
Follow my G3 Hemi Barracuda build on Youtube
https://www.youtube.com/watch?v=XSDAWczXoZw&list=PLTus_wQu8POADHEeJNJp2nr4NMHEyB9EK
2015 Tri-State Stock Super Stock Champion
2017 Monster Mopar Pro Winner
2018 Monster Mopar No Box Winner
Re: BB HV oil pump oil [Re: DrCharles] #2716936
11/17/19 10:00 PM
11/17/19 10:00 PM
WI
Dcuda69 Offline
Dcuda69  Offline
WI
Pressure and volume are different things. You can have a high volume pump with a 40 psi spring in the relief valve.
Re: BB HV oil pump oil [Re: Dcuda69] #2716959
11/17/19 10:30 PM
11/17/19 10:30 PM
West Plains, MO
DrCharles Offline
DrCharles  Offline
West Plains, MO
Quote
You don't say. eyes
More importantly, if the engine clearances don't need enough oil to pass the full pump volume at 40 psi (or whatever the relief spring pressure is), the rest will circulate through the relief valve, as I pointed out to begin with! The gerotor pump is a positive-displacement design. Every revolution, the oil has to go somewhere. If it's not going through the bearings, lifters, etc. then it is just wasted volume.
