Hemi project almost done #2714253
11/09/19 02:02 PM
11/09/19 02:02 PM
Tennessee
Hemi ragtop Offline OP
Tennessee
I had posted on here the issues that I had with a previous build. Bob Meyers at Performance Automotive in Greenville TN is close to finishing the engine.
To go back, the engine had the wrong main bearings, the cylinder walls had no finish, and Bob had to replace everything in the heads except the castings!
Here are some photos. So the combo is as follows:
4.360” bore
4.50” stroke
10.2 Compression Coated Diamond pistons
MP heads ported by Bob (340 cam intake @ actual cam lift)
MP “Marine intake with two Holly 750 vacuum secondary carbs
248 I and 254 E @ .050 with .585 net lift on 112 LC solid roller cam
Small TTI street headers.
This engine is going in a 4,100 lb 66’ Coronet STREET car with 3,54 gears and Gear Vendor.
It is strictly a pump gas cruiser.
Any guess as to how much HP it will Dyno at?
35D302B1-94E5-4AE8-B448-3A393230BFBD.jpeg471E7B16-5541-4EE2-B594-C6B34AD8E263.jpeg32A28775-4595-4FBE-84D8-59225F26DEBA.jpeg
Re: Hemi project almost done [Re: Hemi ragtop] #2714256
11/09/19 02:08 PM
11/09/19 02:08 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Is it going on the dyno?
Re: Hemi project almost done [Re: fast68plymouth] #2714260
11/09/19 02:14 PM
11/09/19 02:14 PM
Tennessee
Tennessee
Yes, it will be Brocken in, tuned with A/F sensors and then power pulls
Re: Hemi project almost done [Re: Hemi ragtop] #2714270
11/09/19 03:05 PM
11/09/19 03:05 PM
AndyF Offline
AndyF  Offline
4.5 inch stroke? Wow, it should make some torque. Not sure about the HP but it will definitely make some torque. Were you able to fit an internal oil pickup tube around the 4.50 inch stroke? I see the external line so I'm guessing you removed the internal pickup and are external only?
Re: Hemi project almost done [Re: AndyF] #2714288
11/09/19 04:54 PM
11/09/19 04:54 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
600 HP tire smoking ditch cleaner outer.
2011 Drag Pak Challenger
Re: Hemi project almost done [Re: AndyF] #2714309
11/09/19 06:05 PM
11/09/19 06:05 PM
Tennessee
Tennessee
Yes I have a external swinging pickup with baffles.
Re: Hemi project almost done [Re: Hemi ragtop] #2714404
11/10/19 12:14 AM
11/10/19 12:14 AM
Whos heads are they? Where they flowed at 28. inches of water?
I'm going to take SWAG and say if it doesn't make 600 HP with those parts something is drastically wrong shruggy
I've made 600+ HP on CA pump swill with a 472 C.,I street hemi motor with iron heads and a stock intake with a set of stock (jetted better)1966 Street hemi Carter AFB years ago, that motor had a half way decent solid lifter flat tappet street cam in that motor also, I don't remember the exact specs now though, sorry blush
Be ready for instant tire smoke work up devil boogie
Re: Hemi project almost done [Re: Cab_Burge] #2714416
11/10/19 01:22 AM
11/10/19 01:22 AM
Southern Alberta
Uberpube Offline
Uberpube  Offline
Southern Alberta
686.3
Re: Hemi project almost done [Re: Cab_Burge] #2714433
11/10/19 07:18 AM
11/10/19 07:18 AM
Tennessee
Tennessee
Cab, The heads are Mopar Performance. Some of the last ones Mancini had, 2009?
Re: Hemi project almost done [Re: Hemi ragtop] #2722244
12/07/19 10:38 AM
12/07/19 10:38 AM
Tennessee
Tennessee
So to continue, The engine is done, tuned and has made power pulls. The result? 665 HP @ a street friendly 5,900 rpm. 679 ft. Lb. of torque @ 4,400 rpm. To emphasize the “street” build, it made right at 500 HP @ 4,000 rpm.
These #s represent the engine installed in the car. Small TTI headers, Dual plane intake, and run on pump 93 octane from a station just down the road from the shop!
12E5DBFA-2B34-40C3-B759-6D8EA1F39580.jpeg7C5DAC9E-7CA6-4451-9573-87A7FF677416.jpeg6F7C88A7-7699-460F-87F1-E53E0F78BBA2.jpeg
Re: Hemi project almost done [Re: Hemi ragtop] #2722250
12/07/19 11:03 AM
12/07/19 11:03 AM
Arlington, Texas
bobby66 Offline
bobby66  Offline
Arlington, Texas
That's a beautiful car! up
Re: Hemi project almost done [Re: bobby66] #2722254
12/07/19 11:14 AM
12/07/19 11:14 AM
Tennessee
Tennessee
Thanks, that picture was taken on my phone at the “cruising the coast” show.
Re: Hemi project almost done [Re: Hemi ragtop] #2722256
12/07/19 11:18 AM
12/07/19 11:18 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Man that car would be a blast to cruise. Nice numbers, should be real hard on tires lol.
68 Barracuda Formula S 340
Re: Hemi project almost done [Re: Hemi ragtop] #2722261
12/07/19 11:24 AM
12/07/19 11:24 AM
Tennessee
Tennessee
Perhaps I shouldn’t post details of this engine on a “racing” forum, but I enjoy reading the technical info posted here and thought you might be interested in a “slightly different” build.
This engine was built for a real “street” car that weighs 4,175lb, has a 727 with the tightest possible 11” converter, 3.54 gears and a Gear Vendor overdrive.
So, torque, high idle vacuum for the power disk brakes, low speed drivability, low maintenance and the ability to buy gas anywhere I happened to find myself, were the priorities.
All the clearances were set on the tight side. Diamond coated 4032 allow pistons were chosen for the tight .003-.0035 piston to wall clearance were used. All the bearings are coated, a Napier second ring was used for oil control.
The engine will run full. Synthetic low viscosity oil and pump gas.
Re: Hemi project almost done [Re: Hemi ragtop] #2722265
12/07/19 11:27 AM
12/07/19 11:27 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Unlawful's Race & Engine tech, I think your threads fit in here just fine.
Re: Hemi project almost done [Re: Hemi ragtop] #2722267
12/07/19 11:30 AM
12/07/19 11:30 AM
central il.
second 70 Offline
second 70  Offline
central il.
I bet there's more power in it if you get the AFR closer to 13-13.5 -1. Glad to see you will be able to enjoy your car.
Re: Hemi project almost done [Re: Hemi ragtop] #2722271
12/07/19 12:04 PM
12/07/19 12:04 PM
Monrovia, So-Cal, USA
racerhog Offline
racerhog  Offline
Very nice Job.... Hope it last a long life and gives you good service.... Keep us posted on the driving part !!!! smile
Mopar On !!!
Bob(Cowboy)Hogan
Monrovia So-Cal
Re: Hemi project almost done [Re: Hemi ragtop] #2722289
12/07/19 01:14 PM
12/07/19 01:14 PM
The brake specifics look a little rich, it might run better in the car with the hood closed a little leaner, especially at light part throttle cruise work scope
Re: Hemi project almost done [Re: Cab_Burge] #2722331
12/07/19 03:57 PM
12/07/19 03:57 PM
Tennessee
Tennessee
Cab, thanks for the observation. On a street car that spends a lot of time at part throttle, I am a firm believer in vacume advance. I have an adjustable unit and I run quite a lot of advance with it. Extra timing at part throttle will lean out the AF quite a bit so we will see.
I am planning on installing AF gauge in the car so I can see what “real world” is
Re: Hemi project almost done [Re: Hemi ragtop] #2722764
12/09/19 03:32 PM
12/09/19 03:32 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Nice work
Rich H.
Esse Quam Videri
