Re: What 528 Hemi Do I Have?
[Re: SSSN8KE]
#2713918
11/08/19 10:57 AM
11/08/19 10:57 AM
Posts: 2,652 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
They probably mean it was built by Indy. Probably has Indy heads and some other components. A photo would tell more. A 528 would normally be a 4.500" bore and a 4.150" stroke. And yes, that is a Mopar block. Attach a photo and we can tell more.
Welcome to the Hemi world. It's fun.
2011 Drag Pak Challenger
[Re: rickseeman]
#2713988
11/08/19 02:01 PM
11/08/19 02:01 PM
Posts: 1,709 central il.
second 70
central il.
I assume it will be siamese because it's probably 4.500" bore. I agree
[Re: rickseeman]
#2714035
11/08/19 05:23 PM
11/08/19 05:23 PM
Posts: 10 Orillia, Canada
SSSN8KE
Orillia, Canada
Welcome to the Hemi world. It's fun. Here are some pics of the motor. I have what I believe to be Mopar Aluminum heads as per the Mopar Logo. Yes I have the Mopar Logo stamped above the 2468330-M
[Re: rickseeman]
#2714037
11/08/19 05:25 PM
11/08/19 05:25 PM
SSSN8KE
Orillia, Canada
Welcome to the Hemi world. It's fun. The only Indy item on the motor is the intake.
[Re: SSSN8KE]
#2714218
11/09/19 12:56 PM
11/09/19 12:56 PM
second 70
central il.
In your professional opinions what do I have? Is it an Indy Hemi or a Mopar Performance Hemi with a Siamese Block? or is the only way to tell for sure is to open it up?
Thanks! Stu. It's a Mopar performance Siamese block with mopar performance aluminum heads. Not an Indy hemi. It could have been built by anybody or be a crate. The numbers on the pad where probably stamped by whoever assembled it. If it's 8 years old and still running well it should be fine. A bad block would have eaten itself by now. Mike
[Re: second 70]
#2714259
11/09/19 02:13 PM
11/09/19 02:13 PM
SSSN8KE
Orillia, Canada
Thanks! Stu. It's a Mopar performance Siamese block with mopar performance aluminum heads. Not an Indy hemi. It could have been built by anybody or be a crate. The numbers on the pad where probably stamped by whoever assembled it. If it's 8 years old and still running well it should be fine. A bad block would have eaten itself by now. Mike Mike Thank you for your opinion and comments, much appreciated! The owner who ordered this engine is "3 owners ago" and I cannot get in touch with him so I'm just trying to figure out what I have. Thanks again! Stu.
