What 528 Hemi Do I Have? #2713887
11/08/19 07:31 AM
11/08/19 07:31 AM
Orillia, Canada
SSSN8KE Offline OP
SSSN8KE  Offline OP
Orillia, Canada
I'm a new owner of a 65 Plymouth Satellite with a 528 Hemi. I'm trying to learn all I can about the Hemi. I was told by the previous owner I have an "Indy Hemi" but I believe I have a Mopar Performance Hemi. I've been reading about these MP Hemi's regarding all the different blocks they came with especially the Cummins block which has not gotten very good reviews to say the least. How can I tell for sure what type of block I have? I DO NOT have the extra frost plugs in the block on either side of the water pump so I think that rules out the "World Block"? This engine was installed in the Satellite about 8+ years ago so if it is a Cummins Block it probably wouldn't have lasted this long.
Here are the casting numbers on the engine: 2468330-M, to the right of this casting is 17 A 1
2
On the front pad I have: 528, G081, 169X, PT
Any and all help is very much appreciated.
Stu.
Re: What 528 Hemi Do I Have? [Re: SSSN8KE] #2713918
11/08/19 10:57 AM
11/08/19 10:57 AM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
They probably mean it was built by Indy. Probably has Indy heads and some other components. A photo would tell more. A 528 would normally be a 4.500" bore and a 4.150" stroke. And yes, that is a Mopar block. Attach a photo and we can tell more.
Welcome to the Hemi world. It's fun.
2011 Drag Pak Challenger
Re: What 528 Hemi Do I Have? [Re: rickseeman] #2713929
11/08/19 11:23 AM
11/08/19 11:23 AM
Houston,Tx.
Lee446 Offline
Lee446  Offline
Houston,Tx.
Cumins did not cast the blocks, they had a contract with Mopar to assemble engines. My first engine build when I was 17 had more attention to detail and clenliness than Cumins put into the 528 that I bought. Nothing wrong with the block other than they over-honed it till a set of new filefit rings had .028 gap out of the box. If Indy did the build, I would have think that that it was done right.
Re: What 528 Hemi Do I Have? [Re: SSSN8KE] #2713961
11/08/19 01:03 PM
11/08/19 01:03 PM
central il.
second 70 Online content
second 70  Online Content
central il.
My guess is it's a mega block cast by Motor casting foundry. If it is a siamese block it will have Mopar cast on the block above the number a water block won't. Your block should look like one of these. Like anything there were some bad blocks that got out but there is plenty of good mega blocks being used.
Hard to know who built the engine.
Mike
Re: What 528 Hemi Do I Have? [Re: second 70] #2713968
11/08/19 01:22 PM
11/08/19 01:22 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
I assume it will be siamese because it's probably 4.500" bore.
Re: What 528 Hemi Do I Have? [Re: rickseeman] #2713988
11/08/19 02:01 PM
11/08/19 02:01 PM
central il.
central il.
I agree
Re: What 528 Hemi Do I Have? [Re: rickseeman] #2714035
11/08/19 05:23 PM
11/08/19 05:23 PM
Orillia, Canada
SSSN8KE Offline OP
SSSN8KE  Offline OP
Orillia, Canada
Here are some pics of the motor. I have what I believe to be Mopar Aluminum heads as per the Mopar Logo. Yes I have the Mopar Logo stamped above the 2468330-M
Re: What 528 Hemi Do I Have? [Re: rickseeman] #2714037
11/08/19 05:25 PM
11/08/19 05:25 PM
Orillia, Canada
SSSN8KE Offline OP
SSSN8KE  Offline OP
Orillia, Canada
The only Indy item on the motor is the intake.
Re: What 528 Hemi Do I Have? [Re: Lee446] #2714039
11/08/19 05:29 PM
11/08/19 05:29 PM
Orillia, Canada
SSSN8KE Offline OP
SSSN8KE  Offline OP
Orillia, Canada
Thank you very much too everyone who has responded. I really appreciate your expertise!
Re: What 528 Hemi Do I Have? [Re: second 70] #2714171
11/09/19 10:17 AM
11/09/19 10:17 AM
Orillia, Canada
SSSN8KE Offline OP
SSSN8KE  Offline OP
Orillia, Canada
In your professional opinions what do I have? Is it an Indy Hemi or a Mopar Performance Hemi with a Siamese Block? or is the only way to tell for sure is to open it up?
Thanks!
Stu.
Re: What 528 Hemi Do I Have? [Re: SSSN8KE] #2714218
11/09/19 12:56 PM
11/09/19 12:56 PM
central il.
central il.
Thanks!
Stu.
It's a Mopar performance Siamese block with mopar performance aluminum heads. Not an Indy hemi. It could have been built by anybody or be a crate. The numbers on the pad where probably stamped by whoever assembled it. If it's 8 years old and still running well it should be fine. A bad block would have eaten itself by now.
Mike
Re: What 528 Hemi Do I Have? [Re: second 70] #2714259
11/09/19 02:13 PM
11/09/19 02:13 PM
Orillia, Canada
SSSN8KE Offline OP
SSSN8KE  Offline OP
Orillia, Canada
Thanks!
Stu.
Mike
Mike
Thank you for your opinion and comments, much appreciated! The owner who ordered this engine is "3 owners ago" and I cannot get in touch with him so I'm just trying to figure out what I have.
Thanks again!
Stu.
