Ebody R/T hood, 440, and Torker II #2709291
10/22/19 07:44 PM
10/22/19 07:44 PM
Halifax, Nova Scotia
Larry Offline OP
Larry  Offline OP
Is anybody running a Torker II intake with stock dual snorkel 440 Magnum air cleaner on a 440 Challenger with an R/T hood? I am wondering if I can do this without clearance issues.
I looked for previous posts on this, but did not see anything specific to this combo.
Re: Ebody R/T hood, 440, and Torker II [Re: Larry] #2709508
10/23/19 12:50 PM
10/23/19 12:50 PM
Watertown, WI
MikeyT Offline
MikeyT  Offline
Watertown, WI
hummm it will be close but I ran a dual snorkel on my 1972 road runner with a 440 and Torker II intake and didn't have any issues with it. I think it should work but it will be close.
1969 Dodge Dart Swinger
Re: Ebody R/T hood, 440, and Torker II [Re: MikeyT] #2710643
10/28/19 02:38 PM
10/28/19 02:38 PM
Larry Offline OP
Larry  Offline OP
Thanks. Any Challenger people out there with this combo??
Re: Ebody R/T hood, 440, and Torker II [Re: Larry] #2710977
10/29/19 05:31 PM
10/29/19 05:31 PM
Tucson, AZ
cruzin Offline
cruzin  Offline
Tucson, AZ
Don't have this exact combo. However, according to E-Brock's specs, the Torker II carb pad height is: 4.67" front / 5.20" rear and is 1.7" taller than stock. The more popular, Performer RPB intake manifold pad height is 5.35". Perhaps someone using a Performer RPM can chime in. If you currently have the stock configuration, check to see if you have the 1.7" clearance.
Re: Ebody R/T hood, 440, and Torker II [Re: cruzin] #2711188
10/30/19 11:32 AM
10/30/19 11:32 AM
Larry Offline OP
Larry  Offline OP
Re: Ebody R/T hood, 440, and Torker II [Re: Larry] #2711262
10/30/19 02:05 PM
10/30/19 02:05 PM
SE Wisconsin, USA
RP's R/T's Offline
RP's R/T's  Offline
SE Wisconsin, USA
my car no longer has this set up, but did when I got it.
440 Torker with 850 Holley. Aftermarket aircleaner.
Re: Ebody R/T hood, 440, and Torker II [Re: RP's R/T's] #2711396
10/30/19 07:49 PM
10/30/19 07:49 PM
ILL
Greentween Offline
Greentween  Offline
ILL
Challenger, r/t hood, 440, RPM intake requires drop base aftermarket air cleaner and it is a close fit. So no way with stock air cleaner with the RPM.
