Budget 5.7 Eagle build #2703680
10/04/19 04:05 AM
10/04/19 04:05 AM
Australia
L4staero Offline OP
L4staero  Offline OP
Australia
Thought id post my build on here for others to see
Low mile 2014 5.7 Eagle from a JGC
Bought the engine in pieces
Torque plate honed
New cam bearings
New rings
New timing chain with updated guide
Heads decked and sand rolled valve seats into port with basic valve job
Apache valve springs
Inertia cam 209/216@ .050
784AD HC lifters
Std length .080 pushrods
6.4 intake manifold and injectors
Will be run by my own standalone system i built and will be self tuning with HP tuners
727 with CRT MRVB
4500 8" stall
9" 4.88 gears
All in a 3600lb Aussie A body charger
Hoping for under 11 99
Re: Budget 5.7 Eagle build [Re: L4staero] #2703686
10/04/19 04:50 AM
10/04/19 04:50 AM
Australia
aus370 Offline
aus370  Offline
Australia
Look forward to the results , the lil 5.7 should like those 4.88's .
Re: Budget 5.7 Eagle build [Re: L4staero] #2704006
10/05/19 12:17 AM
10/05/19 12:17 AM
Southern Missouri
Wailin D Offline
Wailin D  Offline
Southern Missouri
A friendly suggestion while you have it apart is to consider replacing the crankshaft with a forged 6.1 crank or aftermarket crank. The forged 6.4 crankshaft would also probably work, but I would double check. It would be a different stroke while the 6.1 is the same. The stock rods and pistons are the weakest part of the rotating assembly. If you can, I would replace the stock powered metal rods and fragile pistons with forged high quality components. Just my 2 cents.
Re: Budget 5.7 Eagle build [Re: Wailin D] #2704040
10/05/19 09:21 AM
10/05/19 09:21 AM
Springtown Pa
Ray408G3Hemi Offline
Springtown Pa
He'll be fine with the stock 14 parts they are much better then the pre Eagle stuff, I've seen guys put 250shot of NOS to the newer short blocks plus there are afew guys(one post here ) that are boosting the newer eagles to 12lbs no issues unlike the pre Eagles which seem to explode @ 10lbs.When they redesigned the 5.7 they moved the top piston ring down and opened up the top gap , don't know the exact amounts .
1963 Thunderbolt 496FE 10.80 (still a work in progress)
1968 Mustang slow a$$ 428 FE
1971 Boss 351 Mustang 11.20@115mph
1993 Lightning 10.61 @ 129mph 408Ci A3 headed NA
1996 Viper GTS
2001 Lightning 8.99 @ 155MPH 5.4 Mod Motor
2009 Ram 9.65@144MPH 463CI G3 NA
2010 Challenger 9.91 @ 139MPH 408CI G3ci NA
2019 F150 (local dealer's Lightning package) ..11.90s
Re: Budget 5.7 Eagle build [Re: L4staero] #2704048
10/05/19 09:46 AM
10/05/19 09:46 AM
Springtown Pa
Springtown Pa
Torque plate honed
New cam bearings
New rings
784AD HC lifters
727 with CRT MRVB
4500 8" stall
9" 4.88 gears
Looking forward to seeing how it runs, but I'm curious why that Cam ? it's 556 lift and a 112 lsa ,, should be a good torque cam but with 4500 converter I would think you are giving up some potential .I can tell you from 1st hand experience the SRT NON-Mds cam is worth about 20 Hp over that Inertia VVT cam. Inertia's 212/222 Duration Camshaft (112 LSA) gives the SRT cam a run for it's money,
I swapped out my 392cam and now running their 224/232 @ 50 (.556 lift) in my 09 Ram now, picked up 15hp and 20Tq
similar combo except I have a518 OD trans (and A lot of Check engine lights now) and out weigh you by 1000lbs
I think inertia limits their cam Eagle Cam lifts to .556 because of P to V clearance, would love to see what the 224/232 @50 would do with .574/540 lift
1996 Viper GTS
Re: Budget 5.7 Eagle build [Re: Ray408G3Hemi] #2704128
10/05/19 03:28 PM
10/05/19 03:28 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
I would spend $68 on a factory 6.4 cam and save the near $1000 on the aftermarket cam. You did say this is a budget build.
Re: Budget 5.7 Eagle build [Re: Ray408G3Hemi] #2704141
10/05/19 05:19 PM
10/05/19 05:19 PM
Australia
L4staero Offline OP
L4staero  Offline OP
Australia
Torque plate honed
New cam bearings
New rings
784AD HC lifters
727 with CRT MRVB
4500 8" stall
9" 4.88 gears
I picked up the cam used for a quarter of its new price with limiter and a few other pieces.
I asked Jay Greene about this cam vs a SRT NON-MDS cam (I have one on the shelf) and he said the inertia cam although smaller on paper will make more power.
I went with his advice as he's cammed dozens upon dozens of these 5.7's and tuned hundreds of cars
Its got a 6.4 intake manifold so it should carry the power into the rpm a little but the converter is almost brand new and left over from the last engine, i didnt want to spend to reset it but it should flash to just past peak torque.
Re: Budget 5.7 Eagle build [Re: HotRodDave] #2704142
10/05/19 05:21 PM
10/05/19 05:21 PM
Australia
L4staero Offline OP
L4staero  Offline OP
Australia
I didnt pay much more than that for this cam and wont have to worry about valvetrain harmonics from the MDS lobes
New cams are sub $500 from Comp now
Re: Budget 5.7 Eagle build [Re: L4staero] #2704494
10/07/19 07:49 AM
10/07/19 07:49 AM
Home
SRT6776 Offline
I hate internal combustion engines!
SRT6776  Offline
Home
I recently saw one of those smaller than 392 "JG" cams installed and dyno'd in a 5.7 charger and it didn't make more power than a stock 392 cam fyi. Owner was kicking himself for not just going 392 cam....
Re: Budget 5.7 Eagle build [Re: L4staero] #2704770
10/08/19 07:00 AM
10/08/19 07:00 AM
Springtown Pa
Springtown Pa
Torque plate honed
New cam bearings
New rings
784AD HC lifters
727 with CRT MRVB
4500 8" stall
9" 4.88 gears
at that price it's worth the try...... with the 6.4 Intake you can take advantage of the variable runners to help out that 4500 converter.
1996 Viper GTS
Re: Budget 5.7 Eagle build [Re: SRT6776] #2704771
10/08/19 07:04 AM
10/08/19 07:04 AM
Springtown Pa
Springtown Pa
I've seen a few of those JG Cams get their a$$ handed to them also.
Now that Comp's lowered their price on the VVT cams it'll be interesting to see what the market follows with.
1996 Viper GTS
Re: Budget 5.7 Eagle build [Re: Ray408G3Hemi] #2704943
10/08/19 06:53 PM
10/08/19 06:53 PM
Home
SRT6776 Offline
SRT6776  Offline
Home
Which is why he got his lightly used and cheap lol
Re: Budget 5.7 Eagle build [Re: SRT6776] #2704961
10/08/19 08:04 PM
10/08/19 08:04 PM
Australia
L4staero Offline OP
L4staero  Offline OP
Australia
I only had the advice of Jay to work with on whether the 209/216 Inertia/Crower would make more power than a non-MDS 6.4 SRT cam. Jay told me the inertia would make more power. He made $$0 from the advice so i took it as face value as genuine advice. Time will tell i guess
Ive seen quite a few people have terrible results with aftermarket cams but they basically all came.down to tuning. Most tuners seem to have no idea about VVT or Dodges nuaral network and simply switch both them off. A buddies cam swapped 300 picked up 65whp switching from 1 tuner to another with a 6.4 with a MMX nsr cam
Re: Budget 5.7 Eagle build [Re: L4staero] #2705005
10/08/19 10:27 PM
10/08/19 10:27 PM
Springtown Pa
Springtown Pa
The VVT trips a lot of people up, Jay has good handle on it, there are a few guys on HP's forum who also have good handle on it. there's a good bit of power there if you can use it right.
1996 Viper GTS
Re: Budget 5.7 Eagle build [Re: HotRodDave] #2708876
10/21/19 01:51 PM
10/21/19 01:51 PM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
Would you happen to have the 6.4 cam part number?
Re: Budget 5.7 Eagle build [Re: SNK-EYZ] #2708959
10/21/19 06:53 PM
10/21/19 06:53 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Non MDS manual trans cam 05037379BC.
Intake Opens (BTDC) 36.0°
Closes (ATDC) 250.0°
Duration 286.0°
Exhaust Opens (BTDC) 278°
Closes (ATDC) 10°
Duration 288.0°
Valve Overlap 46°
MDS automatic trans cam 05038419AB
Very slightly different specs
Re: Budget 5.7 Eagle build [Re: HotRodDave] #2709066
10/22/19 01:35 AM
10/22/19 01:35 AM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
Thank you! up
Re: Budget 5.7 Eagle build [Re: SNK-EYZ] #2709536
10/23/19 02:21 PM
10/23/19 02:21 PM
Texas
ChevyTS Offline
ChevyTS  Offline
Texas
So far I haven't had that much experience with building GEN III Hemi engines. This Saturday I tested an 07 Charger with a 6.1 based 426 engine. The results were awesome. 485 at the wheels. I have decides to through my hat in the ring. I have already purchased two 6.1 cores, a 4.050 crank, and a set of 6.2 H-Beam rods. Also working on modifications to a set of 5.7 heads. From what I have found these engines are not that complicated. Looks like most of the cylinder head parts interchange with LS Chevrolet components. I will post pics as I make progress. I am also working on a custom intake manifold wink
T & K Performance
Re: Budget 5.7 Eagle build [Re: ChevyTS] #2709592
10/23/19 05:26 PM
10/23/19 05:26 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Update on the cheap cams, apparently chrysler decided we should not get a good deal on cams anymore, I just called and all the part numbers he looked up for 6.4 cams are $300 including the numbers I put up.
Re: Budget 5.7 Eagle build [Re: HotRodDave] #2709593
10/23/19 05:32 PM
10/23/19 05:32 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
I was very tempted to buy about 20 of them because I had this bad feeling this was going to happen, that would have been a sweet return on my investment. BASS TIRDS!!!
