Scratched bore reassembling shortblock #2703478
10/03/19 04:37 PM
10/03/19 04:37 PM
central Pa.
71Pan Offline OP
71Pan  Offline OP
central Pa.
Number 4 cylinder oil retaining ring scratch cylinder. Pulled piston rehoned gonna try it what do you guys think about .001 deep .Every thing fresh ughhhhh
Re: Scratched bore reassembling shortblock [Re: 71Pan] #2703492
10/03/19 04:52 PM
10/03/19 04:52 PM
central texas
K
krautrock Offline
krautrock  Offline
K
central texas
is that a crack???
Re: Scratched bore reassembling shortblock [Re: krautrock] #2703493
10/03/19 04:53 PM
10/03/19 04:53 PM
AZ
squirrel Offline
squirrel  Offline
AZ
that's a crack
Re: Scratched bore reassembling shortblock [Re: squirrel] #2703496
10/03/19 04:56 PM
10/03/19 04:56 PM
Kirkland, Washington
Pacnorthcuda Offline
Holy Batcrack Robin!
Re: Scratched bore reassembling shortblock [Re: squirrel] #2703497
10/03/19 04:57 PM
10/03/19 04:57 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Gouge, crack, whatever... not good.
Re: Scratched bore reassembling shortblock [Re: BradH] #2703501
10/03/19 05:05 PM
10/03/19 05:05 PM
central Pa.
71Pan Offline OP
71Pan  Offline OP
central Pa.
not a crack block just magged
Re: Scratched bore reassembling shortblock [Re: krautrock] #2703502
10/03/19 05:07 PM
10/03/19 05:07 PM
Byron, NY
W.I.N. Racing Offline
Byron, NY
Originally Posted by krautrock
is that a crack???
I would agree...scratches usually are straight as a string...cracks not so much
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60
'01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust,
'05 Dodge Magnum R/T - Too Much to list
'60 Willys CJ5
'01 International LPX - Project,DT466, Allison
'64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: Scratched bore reassembling shortblock [Re: W.I.N. Racing] #2703505
10/03/19 05:12 PM
10/03/19 05:12 PM
Super Spudsville
Mr PotatoHead Online rolleyes
Half Baked
Mr PotatoHead  Online Rolleyes
Half Baked
Super Spudsville
Unless you dropped something harder then the bore in it, it does lookie like buttcrack, buttman.
UMMM did you by chance file your own rings?
STOP POTATO HATE!
Re: Scratched bore reassembling shortblock [Re: Mr PotatoHead] #2703508
10/03/19 05:19 PM
10/03/19 05:19 PM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
That is a crack - no doubt time for a sleeve
Re: Scratched bore reassembling shortblock [Re: DoubleD] #2703521
10/03/19 05:48 PM
10/03/19 05:48 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
I will take your word for it and assume that is not a crack.
It looks like there is some flashing over the edge of the scratch making it appear as a crack though? I can see the skipping of the ring in the gouge after looking close at your picture. I have ran bores that were pitted pretty good but never a long, horizontal wound like that. What kind of ring are you using? Can you hone it another thou and make it go away completely?
How much hp are we talking?
Re: Scratched bore reassembling shortblock [Re: Jeremiah] #2703538
10/03/19 06:29 PM
10/03/19 06:29 PM
central Pa.
71Pan Offline OP
71Pan  Offline OP
central Pa.
its not a crack the thing everyone thinks is a crack is actually standing proud. The pic was before i remove piston and rehoned
Re: Scratched bore reassembling shortblock [Re: 71Pan] #2703539
10/03/19 06:31 PM
10/03/19 06:31 PM
central Pa.
71Pan Offline OP
71Pan  Offline OP
central Pa.
C A rings plama moly standard tension 416 360-1 head ported 266 @50 .637 cam 500 vert 4.10 gear hp should be 600 to 625
Re: Scratched bore reassembling shortblock [Re: 71Pan] #2703542
10/03/19 06:36 PM
10/03/19 06:36 PM
It looks like a crack to me, you can use heat to make sure. I've used heat guns, hair dryers, propane torches to help identify cracks in cast iron, apply heat and watch closely to see if it moves, grows or change how it looks scope
Way better to find out now before reassembling it work
BTW, if it was sticking above the cylinder wall, what would cause that work shruggy It should have flatten out with the honing unless you use a dingle berry hone work shruggy
Re: Scratched bore reassembling shortblock [Re: Cab_Burge] #2703549
10/03/19 06:55 PM
10/03/19 06:55 PM
central Pa.
71Pan Offline OP
71Pan  Offline OP
central Pa.
The block sonic tested well over .200 in that area dont know how i would .have cracked the wall tapping a piston in.
Re: Scratched bore reassembling shortblock [Re: 71Pan] #2703553
10/03/19 07:15 PM
10/03/19 07:15 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
Get it magnafluxed, then you'll know for sure.
Re: Scratched bore reassembling shortblock [Re: rickraw] #2703554
10/03/19 07:18 PM
10/03/19 07:18 PM
central Pa.
71Pan Offline OP
71Pan  Offline OP
central Pa.
k just had it magged and cooked before new ring and bearings
Re: Scratched bore reassembling shortblock [Re: 71Pan] #2703595
10/03/19 08:54 PM
10/03/19 08:54 PM
Sullivan, IN
Mopar Sam Offline
Mopar Sam  Offline
Sullivan, IN
Hone it and run it. Less area there than in your ring gap.You ought to see what dirt track guys run.
Re: Scratched bore reassembling shortblock [Re: 71Pan] #2703597
10/03/19 08:57 PM
10/03/19 08:57 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
I missed the mag post. Doh.
Re: Scratched bore reassembling shortblock [Re: rickraw] #2703617
10/03/19 10:33 PM
10/03/19 10:33 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
Yep, run it.
Re: Scratched bore reassembling shortblock [Re: 71Pan] #2703619
10/03/19 10:37 PM
10/03/19 10:37 PM
Originally Posted by 71Pan
The block sonic tested well over .200 in that area don't know how I would .have cracked the wall tapping a piston in.
No way in the world that you could have caused that crack, NO WAY tskshruggy
I've assembled more than one motor, I see straight scratches in the new honed cylinder a lot from me not getting the file to fit ring ends smooth enough to not scratch the cylinder walls, none of them have ever looked like your does confuseds
Me thinks your shop did not mag that cylinder wall, take it back and have them look at it now to be safe scope twocents
I've had several good auto Hi Po machine shops in SO CA miss external cracks on several different 906 heads that where cracked under the exhaust ports, most shops do a lot more other brands than BB Mopars and neither one was aware that those freeze cracks are not uncommon on 906 heads rant shruggy
