Blower motor on the dyno #2701878
09/28/19 11:57 PM
09/28/19 11:57 PM
AndyF Offline OP
AndyF  Offline OP
Tested a Chevy 454 (Old LS6 engine with blower pistons and Dart heads) on the dyno last week. First time I've helped test a blower motor. Engine pulled a rocker arm stud out of the head on the first pull so that took a bunch of work to fix. Took a few days to repair the head and then we were able to get some good pulls on it. This is a boat motor so it was built really conservative. I think the compression ratio was 8.5 and it had 32 degrees of timing and a small flat tappet cam with 0.500 lift. It still made 700 hp and a ton of noise. I think it was the loudest engine we've ever ran on the dyno. Just starts to shriek once you get over 5000 rpm. Not so sure I'd like that noise in a car. The owner says he doesn't really hear it in the boat since you're going 70 mph and the wind blows the noise away. He does say that people up and down the river hear him coming.
Re: Blower motor on the dyno [Re: AndyF] #2701891
09/29/19 02:09 AM
09/29/19 02:09 AM
New York, USA
Chargerfan68 Offline
New York, USA
Nice! How much boost, and what size blower is that. 8-71?
Re: Blower motor on the dyno [Re: Chargerfan68] #2701904
09/29/19 07:34 AM
09/29/19 07:34 AM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
Blowers are big time fun. I hear lots of long winded explanations of how terrible, and inefficient they are. Blah blah blah,,just something about them I've always loved. They're all in your face, your ears, and toss ya in the seat faster than any other adder.
Re: Blower motor on the dyno [Re: AndyF] #2701932
09/29/19 11:13 AM
09/29/19 11:13 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Carter carbs?
Re: Blower motor on the dyno [Re: AndyF] #2701935
09/29/19 11:22 AM
09/29/19 11:22 AM
Frackster Offline
Frackster  Offline
Is that going in a jetboat? What type?
Re: Blower motor on the dyno [Re: Chargerfan68] #2701948
09/29/19 12:09 PM
09/29/19 12:09 PM
AndyF Offline OP
AndyF  Offline OP
The blower is run 10% over. It was making 16 inches of boost at 6000 rpm.
Re: Blower motor on the dyno [Re: AndyF] #2701950
09/29/19 12:09 PM
09/29/19 12:09 PM
Byron, NY
W.I.N. Racing Offline
Byron, NY
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60
'01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust,
'05 Dodge Magnum R/T - Too Much to list
'60 Willys CJ5
'01 International LPX - Project,DT466, Allison
'64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: Blower motor on the dyno [Re: Frackster] #2701951
09/29/19 12:10 PM
09/29/19 12:10 PM
AndyF Offline OP
AndyF  Offline OP
I think the owner said it is a V drive with a Powerglide trans and a prop
Re: Blower motor on the dyno [Re: AndyF] #2701969
09/29/19 12:53 PM
09/29/19 12:53 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
I am sure the TQ was nice with 16#.I used an Isky solid .557 on 110 that made big tq but with 452 iron heads.Thank you for sharing.
Re: Blower motor on the dyno [Re: Clanton] #2701979
09/29/19 01:22 PM
09/29/19 01:22 PM
AndyF Offline OP
AndyF  Offline OP
The torque was above 600 ft-lbs for the entire pull from 3000 rpm to 6000 rpm. I didn't print out the graphs but I think the peak torque was in the 650 range down around 4500 rpm.
Re: Blower motor on the dyno [Re: AndyF] #2701981
09/29/19 01:26 PM
09/29/19 01:26 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
Did you get an IAT reading?Mine was above 250F with 14#.
Re: Blower motor on the dyno [Re: Clanton] #2702019
09/29/19 03:13 PM
09/29/19 03:13 PM
AndyF Offline OP
AndyF  Offline OP
No, we didn't have a temp gauge hooked up to the intake manifold. The air temp was fairly cold when we were testing. Correction factor was only 1%.
Re: Blower motor on the dyno [Re: AndyF] #2702305
09/30/19 03:46 PM
09/30/19 03:46 PM
Odessa, Fl
blowndart Offline
blowndart  Offline
Odessa, Fl
Maybe it's just me... but 700 HP at 16 lbs of boost seems a little lower than I would expect for an engine that size with aftermarket heads. Even with a conservative cam.
Re: Blower motor on the dyno [Re: AndyF] #2702318
09/30/19 04:58 PM
09/30/19 04:58 PM
AZ
squirrel Offline
squirrel  Offline
AZ
he said inches...everyone else is saying pounds...???
I think it's a bit more conservative than folks are reading into it.
I've been driving around with a couple different blown BBCs for 30 years, yeah, they're fun!
Re: Blower motor on the dyno [Re: blowndart] #2702319
09/30/19 05:01 PM
09/30/19 05:01 PM
Cab_Burge Online work
Cab_Burge  Online Work
I've seen similar results on a LS6 crate motor with a small bore BDS 6.:71 with two Holley 650 center squirters on 91 octane CA pump swill back in the early 2000s shruggy
That motor had a set of the old TRW forged turbo pistons with a reverse dome(7.5 to 1 comp ratio) and a small hydraulic blower cam, it made 620 HP with 5 lbs. of boost at around 6000 RPM if I'm remembering correctly now. The customer wanted me to JUST check it out initially, physical inspection on the bottom end and a leak down test due to the engine being used out of a street hot rod(1 ton dually Chevy 4 door pickup confused) and then he had me dyno test it to make sure it ran and didn't leak. That led to him wanting more power so I bought two more blower pulleys to make more boost and loaned him a set of 850 B.G. Speed Demon carbs I had in stock and swapped the cam to a Comp Cams solid roller set up and put a gear drive on it per his buddy advice work Those changes ended up making right at 780 HP at 6700 RPM with around 12.0 lbs. of boost, the manifold inlet temps went from 130 F with the lower boost to 190 F with the higher boost levels shruggy It did make 700 HP at 7000 RPM with 7.0 lbs. of boost with a smaller blower pulley and his carbs jetted to the best power, he put that motor in a 1972 SS Chevelle he had and he loved it, it would smoke the tires pretty easily according to him shruggy
Re: Blower motor on the dyno [Re: squirrel] #2702356
09/30/19 07:19 PM
09/30/19 07:19 PM
Odessa, Fl
blowndart Offline
blowndart  Offline
Odessa, Fl
16 inch of Mercury? That make more sense. I was confused by others referring to 16 PSI.
Re: Blower motor on the dyno [Re: blowndart] #2702371
09/30/19 07:47 PM
09/30/19 07:47 PM
AndyF Offline OP
AndyF  Offline OP
Yes, 16 in of Hg max boost. Roughly 8 psi of boost.
