Re: Blower motor on the dyno
[Re: AndyF]
#2701891
09/29/19 02:09 AM
09/29/19 02:09 AM
Posts: 1,264 New York, USA
Chargerfan68
New York, USA
Nice! How much boost, and what size blower is that. 8-71?
[Re: Chargerfan68]
#2701904
09/29/19 07:34 AM
09/29/19 07:34 AM
Posts: 3,097 back in Georgia
dthemi
back in Georgia
Blowers are big time fun. I hear lots of long winded explanations of how terrible, and inefficient they are. Blah blah blah,,just something about them I've always loved. They're all in your face, your ears, and toss ya in the seat faster than any other adder.
[Re: AndyF]
#2701935
09/29/19 11:22 AM
09/29/19 11:22 AM
Frackster
Is that going in a jetboat? What type?
[Re: AndyF]
#2701950
09/29/19 12:09 PM
09/29/19 12:09 PM
Posts: 2,105 Byron, NY
W.I.N. Racing
Byron, NY
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
[Re: Frackster]
#2701951
09/29/19 12:10 PM
09/29/19 12:10 PM
Posts: 30,994 Oregon
AndyF
Is that going in a jetboat? What type? I think the owner said it is a V drive with a Powerglide trans and a prop
[Re: AndyF]
#2701969
09/29/19 12:53 PM
09/29/19 12:53 PM
Posts: 4,489 northern,Ohio,USA
Clanton
northern,Ohio,USA
I am sure the TQ was nice with 16#.I used an Isky solid .557 on 110 that made big tq but with 452 iron heads.Thank you for sharing.
[Re: AndyF]
#2702318
09/30/19 04:58 PM
09/30/19 04:58 PM
Posts: 147 AZ
squirrel
AZ
The blower is run 10% over. It was making 16 inches of boost at 6000 rpm. he said inches...everyone else is saying pounds...??? I think it's a bit more conservative than folks are reading into it. I've been driving around with a couple different blown BBCs for 30 years, yeah, they're fun!
[Re: blowndart]
#2702319
09/30/19 05:01 PM
09/30/19 05:01 PM
Posts: 43,123 Bend,OR USA
Cab_Burge
Maybe it's just me... but 700 HP at 16 lbs of boost seems a little lower than I would expect for an engine that size with aftermarket heads. Even with a conservative cam. I've seen similar results on a LS6 crate motor with a small bore BDS 6.:71 with two Holley 650 center squirters on 91 octane CA pump swill back in the early 2000s That motor had a set of the old TRW forged turbo pistons with a reverse dome(7.5 to 1 comp ratio) and a small hydraulic blower cam, it made 620 HP with 5 lbs. of boost at around 6000 RPM if I'm remembering correctly now. The customer wanted me to JUST check it out initially, physical inspection on the bottom end and a leak down test due to the engine being used out of a street hot rod(1 ton dually Chevy 4 door pickup ) and then he had me dyno test it to make sure it ran and didn't leak. That led to him wanting more power so I bought two more blower pulleys to make more boost and loaned him a set of 850 B.G. Speed Demon carbs I had in stock and swapped the cam to a Comp Cams solid roller set up and put a gear drive on it per his buddy advice Those changes ended up making right at 780 HP at 6700 RPM with around 12.0 lbs. of boost, the manifold inlet temps went from 130 F with the lower boost to 190 F with the higher boost levels It did make 700 HP at 7000 RPM with 7.0 lbs. of boost with a smaller blower pulley and his carbs jetted to the best power, he put that motor in a 1972 SS Chevelle he had and he loved it, it would smoke the tires pretty easily according to him
[Re: squirrel]
#2702356
09/30/19 07:19 PM
09/30/19 07:19 PM
Posts: 965 Odessa, Fl
blowndart
Odessa, Fl
The blower is run 10% over. It was making 16 inches of boost at 6000 rpm. he said inches...everyone else is saying pounds...??? I think it's a bit more conservative than folks are reading into it. I've been driving around with a couple different blown BBCs for 30 years, yeah, they're fun! 16 inch of Mercury? That make more sense. I was confused by others referring to 16 PSI.
