904 CSR Shield install? #2700101
09/23/19 11:23 AM
09/23/19 11:23 AM
MD
RTSE4ME Offline OP
RTSE4ME  Offline OP
MD
Installing a CSR shield and my direct mount Lokar dipstick doesn't clear.
Any ideas before I start cutting ? Called Lokar and they don't have anything that is lockable that works.
Re: 904 CSR Shield install? [Re: RTSE4ME] #2700117
09/23/19 12:14 PM
09/23/19 12:14 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
I’ve used the stock tubes over the years and have had to make minor mods to them. Not a big deal
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: 904 CSR Shield install? [Re: RTSE4ME] #2700167
09/23/19 03:45 PM
09/23/19 03:45 PM
Glendora Ca.
Just-a-dart Offline
Just-a-dart  Offline
Glendora Ca.
I went through this too about a year. After calling Locar I decided that I would not be buying
Anything else from them.
I made a plug for the case and made a little chamber on the back of the trans pan with a -12
Bung for a fill/sight plug. The right side trans tunnel comes off easy in this car.
"Just a Bracket car dressed up like a streetcar"
Re: 904 CSR Shield install? [Re: Just-a-dart] #2700169
09/23/19 03:53 PM
09/23/19 03:53 PM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
Thats pretty slick ,good job
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
Re: 904 CSR Shield install? [Re: Just-a-dart] #2700240
09/23/19 07:40 PM
09/23/19 07:40 PM
MD
RTSE4ME Offline OP
RTSE4ME  Offline OP
MD
That is a really neat solution. My trans tunnel comes off easily. Thanks for the idea.
Shame the Lokar dipstick doesn't work since it was expensive.
Re: 904 CSR Shield install? [Re: RTSE4ME] #2700299
09/23/19 11:11 PM
09/23/19 11:11 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
If you change to a stock style dipstick use a newer style that utilizes the “umbrella” style seal. Allows for quite a bit of movement and doesn’t leak.
http://coperacingtranscom.ipage.com/?product=904-small-block-stick-tube-wcsr-shield
Re: 904 CSR Shield install? [Re: J_BODY] #2700344
09/24/19 07:32 AM
09/24/19 07:32 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I hope John sees this and sends your commission to you. I didn't know they made one of those, I ordered one to give it a try so I can lose the lockar deal. Thanks!
68 Barracuda Formula S 340
Re: 904 CSR Shield install? [Re: Bad340fish] #2700361
09/24/19 08:32 AM
09/24/19 08:32 AM
an8sec70cuda Online content
an8sec70cuda  Online Content
Is the fitment/location of the dipstick in relation to the shield different from 904 to 727?
I use the Lokar flexible braided steel dipstick w/ a CSR shield on my 727 w/ no fitment problems.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: 904 CSR Shield install? [Re: an8sec70cuda] #2700396
09/24/19 10:18 AM
09/24/19 10:18 AM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
I have one of the Cope locking dipsticks on my 69 Barracuda with a 904 and CSR shield. It works and fits well.
Re: 904 CSR Shield install? [Re: RTSE4ME] #2700398
09/24/19 10:19 AM
09/24/19 10:19 AM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
Don't cut on the shield or you will not be able to recertify it.
Re: 904 CSR Shield install? [Re: an8sec70cuda] #2700418
09/24/19 11:23 AM
09/24/19 11:23 AM
MD
RTSE4ME Offline OP
RTSE4ME  Offline OP
MD
I think a Lokar flexible braided steel or Cope will fit the shield but I would have to modify the firewall. Maybe I could mount the flexible dipstick toward the rear some how?
I was hoping they made a stubby dipstick like they do for GM trannys but they can't since there is fluid in a 904 dipstick.
Re: 904 CSR Shield install? [Re: RTSE4ME] #2700430
09/24/19 11:48 AM
09/24/19 11:48 AM
PA.
"Little"John
"Little"John
PA.
Man you guys make a project out of child’s play. Bend it, cut it, modify it and the recalibrate your dipstick. Any good rebuild book shows you where the fluid level should be so you just remark your stick. (I marked mine with a magic marker and then used a hacksaw to put a groove in my dipstick) It’s not brain surgery guys.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: 904 CSR Shield install? [Re: pittsburghracer] #2700695
09/25/19 09:10 AM
09/25/19 09:10 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
It’s not brain surgery.... but I REALLY recommend getting away from the leak prone OE “o-ring” style dipstick tube and move on to the much better GM style seal.
I brazed on a Chevy tube end on my Mirada dipstick tube back in the late 80’s before ma Mopar came to their senses in the mid 90’s to follow suit. It works!!
Re: 904 CSR Shield install? [Re: J_BODY] #2700747
09/25/19 11:34 AM
09/25/19 11:34 AM
moparx Offline
moparx  Offline
one bad trait of the lokar dipstick tube, it takes a tiny funnel end to dump the fluid in, which translates into "forever" to fill the transmission.
do like pittsburgh suggested. chop down a cheap tube, cut your stick to length and recalibrate it. done. save $50 and some grief.
beer
Re: 904 CSR Shield install? [Re: moparx] #2701107
09/26/19 12:10 PM
09/26/19 12:10 PM
beer
I see people here complain about the time it takes to fill one all the time. I've never found it to be that big of an issue. Sure it takes longer, but are you really in that big of a hurry to fill a fresh trans?
CHIP
Re: 904 CSR Shield install? [Re: an8sec70cuda] #2701122
09/26/19 12:54 PM
09/26/19 12:54 PM
moparx Offline
moparx  Offline
i couldn't be in a hurry if the devil was right behind me, stabbing my azz with his pitchfork ! laugh2
i can't control the flow good enough without making a mess, overflowing the funnel.
but that's just me. geeze, i make a mess using a funnel pouring oil into the valve cover.
beer
