Hellcat pass 7.87 #2692984
08/30/19 06:22 PM
08/30/19 06:22 PM
Pattison Texas
CSK Online shake_head OP
CSK  Online Shake_Head OP
Pattison Texas
Re: Hellcat pass 7.87 [Re: CSK] #2692987
08/30/19 06:27 PM
08/30/19 06:27 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
WOW !!!
Re: Hellcat pass 7.87 [Re: tubtar] #2692991
08/30/19 06:50 PM
08/30/19 06:50 PM
On the run…
BloFish Offline
BloFish  Offline
On the run…
Holy smokes!
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: Hellcat pass 7.87 [Re: BloFish] #2692993
08/30/19 07:01 PM
08/30/19 07:01 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
That thing really hauls!!
Re: Hellcat pass 7.87 [Re: fast68plymouth] #2693001
08/30/19 07:55 PM
08/30/19 07:55 PM
Pattison Texas
Pattison Texas
its a stick shift car also
Re: Hellcat pass 7.87 [Re: CSK] #2693014
08/30/19 09:12 PM
08/30/19 09:12 PM
Pittsburgh,PA
RTSrunner Offline
RTSrunner  Offline
Pittsburgh,PA
Awesome!
Re: Hellcat pass 7.87 [Re: RTSrunner] #2693027
08/30/19 10:03 PM
08/30/19 10:03 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
DAYUM!! It sounded like he peddled it too.
Re: Hellcat pass 7.87 [Re: CSK] #2693033
08/30/19 10:50 PM
08/30/19 10:50 PM
Martinsville, IN
cdwmotorsports Offline
Martinsville, IN
Wow
eBay-cdwmotorsports
Re: Hellcat pass 7.87 [Re: justinp61] #2693093
08/31/19 09:30 AM
08/31/19 09:30 AM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
He mentioned it got loose coming down from the launch in the associated article.
That thing has every trick in the book, but the fact that he's banging gears with a 5-speed might be the most impressive thing to me.
Re: Hellcat pass 7.87 [Re: BradH] #2693125
08/31/19 11:23 AM
08/31/19 11:23 AM
Cab_Burge Online work
Cab_Burge  Online Work
Stroked, ported after market race heads and a bigger blower, how fast can it go work shruggy
I could here the two step working before the clutch was let out, as far as pedaling it I couldn't tell if it was on the two step again in first gear or not confused
Re: Hellcat pass 7.87 [Re: Cab_Burge] #2693200
08/31/19 05:03 PM
08/31/19 05:03 PM
BradH Offline
BradH  Offline
Blower... nitrous... methanol injection... change pulleys and put in a bigger N2O tune... no limit but the budget! grin
Re: Hellcat pass 7.87 [Re: BradH] #2693302
08/31/19 11:15 PM
08/31/19 11:15 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
N2O is the ulimate intercooler. I am headed that way!! Fantasic pass!!boogie Can't wait to seeit stick all the way bow
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Hellcat pass 7.87 [Re: CSK] #2693366
09/01/19 09:17 AM
09/01/19 09:17 AM
It's Complicated
HDNMOPERS Offline
HDNMOPERS  Offline
It's Complicated
Matt Hensley was freshening up and doing the upgrades to Eplings engine. At same time he was building my engine. I have seen that engine apart. What was supprising to me. Was how well that everything looked on the tare down. Which is a testament to what the GEN 3 can take. The other thing was how unexcotic it was. Good quality parts mind you. But nothing that made me say "Wow Thats Interesting". Matt and Ken Hensley are really starting to ramp up their GEN 3 program. Doing some good stuff. My next engine I do will be a Hensley GEN 3. Eplings have worked their tails off also. With the tune ups and chassis setup. They got that thing hauling for sure. They have done a awesome job.
Re: Hellcat pass 7.87 [Re: HDNMOPERS] #2693374
09/01/19 09:40 AM
09/01/19 09:40 AM
Duloc
The Shadow Offline
The Shadow  Offline
Duloc
Not much hellcat about that car but impressive none the less
Re: Hellcat pass 7.87 [Re: CSK] #2693380
09/01/19 10:11 AM
09/01/19 10:11 AM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
There was a Hellcat at the track running when I was there. Ran 9.80's. Not sure what was done to it.
Re: Hellcat pass 7.87 [Re: mopar dave] #2693394
09/01/19 10:43 AM
09/01/19 10:43 AM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
We have a good group of guys that test n tune every week at Keystone. Several of them are friends of mine that used to test n tune Dodge Diesel trucks that ran 9’s. It just got to expensive so now they switched to Gen 3 Hemis and recently dipped into the 9’s. Now Keystone is far from the East coast super track conditions but I know I will be going up in October to see what they can do in the Fall air. Maybe they will head East a few hundred miles later in the year to get a bragging number.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Hellcat pass 7.87 [Re: pittsburghracer] #2696334
09/10/19 10:07 PM
09/10/19 10:07 PM
OH
hemislave Offline
hemislave  Offline
OH
They ran 7.84 This past weekend at the Southern Classic. It is a bad machine for sure.
Re: Hellcat pass 7.87 [Re: hemislave] #2696389
09/11/19 05:12 AM
09/11/19 05:12 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I talked to the owner car is 3900+ race ready. Stock block, factory worked heads.
Doug
Re: Hellcat pass 7.87 [Re: dvw] #2696394
09/11/19 06:22 AM
09/11/19 06:22 AM
Mo.
racerx Offline
racerx  Offline
Mo.
Wondering what rear-ends in these cars to be as fast as they are with that kind of weight?
Re: Hellcat pass 7.87 [Re: racerx] #2696603
09/11/19 04:06 PM
09/11/19 04:06 PM
Wheatfield, NY
Cuda340 Offline
Cuda340  Offline
Wheatfield, NY
I thought I read a Strange 9"
