Hellcat pass 7.87
#2692984
08/30/19 06:22 PM
08/30/19 06:22 PM
Posts: 2,872 Pattison Texas
CSK
Pattison Texas
Re: Hellcat pass 7.87
[Re: fast68plymouth]
#2693001
08/30/19 07:55 PM
08/30/19 07:55 PM
CSK
Pattison Texas
its a stick shift car also
[Re: justinp61]
#2693093
08/31/19 09:30 AM
08/31/19 09:30 AM
BradH
DAYUM!! It sounded like he peddled it too. He mentioned it got loose coming down from the launch in the associated article. That thing has every trick in the book, but the fact that he's banging gears with a 5-speed might be the most impressive thing to me.
[Re: BradH]
#2693125
08/31/19 11:23 AM
08/31/19 11:23 AM
Posts: 43,307 Bend,OR USA
Cab_Burge
DAYUM!! It sounded like he peddled it too. He mentioned it got loose coming down from the launch in the associated article. That thing has every trick in the book, but the fact that he's banging gears with a 5-speed might be the most impressive thing to me. Stroked, ported after market race heads and a bigger blower, how fast can it go I could here the two step working before the clutch was let out, as far as pedaling it I couldn't tell if it was on the two step again in first gear or not
[Re: mopar dave]
#2693394
09/01/19 10:43 AM
09/01/19 10:43 AM
Posts: 20,203 PA.
pittsburghracer
"Little"John
"Little"John
PA.
We have a good group of guys that test n tune every week at Keystone. Several of them are friends of mine that used to test n tune Dodge Diesel trucks that ran 9’s. It just got to expensive so now they switched to Gen 3 Hemis and recently dipped into the 9’s. Now Keystone is far from the East coast super track conditions but I know I will be going up in October to see what they can do in the Fall air. Maybe they will head East a few hundred miles later in the year to get a bragging number.
[Re: hemislave]
#2696389
09/11/19 05:12 AM
09/11/19 05:12 AM
Posts: 9,883 MI, usa
dvw
MI, usa
They ran 7.84 This past weekend at the Southern Classic. It is a bad machine for sure. I talked to the owner car is 3900+ race ready. Stock block, factory worked heads. Doug
