T/A hood engineering diagram #2691451
08/26/19 06:53 AM
08/26/19 06:53 AM
Virginia
V
varunner Offline OP
varunner  Offline OP
V
Virginia
Does anyone have a factory sketch showing the T/A hood assembly ? I'm looking to document that this hood did not come with a hood latch or safety ketch. NHRA is reminding racers that hoods need a hood latch. thanks
Re: T/A hood engineering diagram [Re: varunner] #2691530
08/26/19 11:48 AM
08/26/19 11:48 AM
Locomotion Offline
Locomotion  Offline
Maybe you can find something by searching through this, or contacting the person who posted it.
He does mention that the T/A hood had no latches and requires pins in Reply #6 on: January 23, 2017, 02:49:09 AM . But you'd have to ask if there is any factory documentation available outlining that.
Challenger T/A info
Re: T/A hood engineering diagram [Re: Locomotion] #2691572
08/26/19 01:31 PM
08/26/19 01:31 PM
Virginia
V
varunner Offline OP
varunner  Offline OP
V
Virginia
Thank you. Lots of info on that site. This should lead me to the document I want
Cheers
Re: T/A hood engineering diagram [Re: varunner] #2691592
08/26/19 02:44 PM
08/26/19 02:44 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Hood pins only.
No place to mount a latch on the hoods & no need for the pop-up springs either.
Re: T/A hood engineering diagram [Re: Alaskan_TA] #2691632
08/26/19 04:25 PM
08/26/19 04:25 PM
Locomotion Offline
Locomotion  Offline
Originally Posted by Alaskan_TA
Hood pins only.
NHRA requires verifiable documentation if there is any variations that may conflict with their existing rules. They have been known to make exceptions, but being prepared, just in case, like in court, is prudent. Otherwise, it can hurt your wallet and reputation if they decide to enforce and/or "interpret" a particular rule against you.
Re: T/A hood engineering diagram [Re: Locomotion] #2691698
08/26/19 08:29 PM
08/26/19 08:29 PM
Virginia
V
varunner Offline OP
varunner  Offline OP
V
Virginia
I have a 70 challenger in nhra stock. This is what got my attention and need documentation.
nhra statement on hood latch
Re: T/A hood engineering diagram [Re: varunner] #2691705
08/26/19 08:40 PM
08/26/19 08:40 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Quote
Question:
Can I remove the hood latch and use hood pins on my Stock / Super Stock entry?
Answer:
Per the 2019 NHRA Rulebook sections 11A and 12A pages 11 and 9 under Body:7 Hood it reads "Full stock hood including latches, hinges, springs, brackets, and braces as originally produced must be retained." With that said you may add hood pins, in addition to the original latch.
He asked if he could remove it.
No latch to remove on T/As (or AARs) so you should be good to go.
Re: T/A hood engineering diagram [Re: Alaskan_TA] #2691708
08/26/19 08:46 PM
08/26/19 08:46 PM
Virginia
V
varunner Offline OP
varunner  Offline OP
V
Virginia
Alaskan T/A, I may have to prove, via oem documentation, that the T/A hood did not have a latch or safety catch. Referencing a social media post is not going to cut it, at least if it I was the one hearing that response. Appreciate the info though.
Re: T/A hood engineering diagram [Re: varunner] #2691711
08/26/19 08:53 PM
08/26/19 08:53 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Well, next July at Carlisle is the 50 Year Reunion for the AARS & T/As so come take photos of every original cars hood & latch area.
You will not go home with any photos of an original latch or catch on any of them though.......... up
Re: T/A hood engineering diagram [Re: Alaskan_TA] #2691843
08/27/19 08:17 AM
08/27/19 08:17 AM
Virginia
V
varunner Offline OP
varunner  Offline OP
V
Virginia
A few good pictures might not hurt to have, as I'm not having to convince a mopar fan what is legit. If I feel like sweating and having a couple of yingling, I might just do that !
Re: T/A hood engineering diagram [Re: varunner] #2691877
08/27/19 10:30 AM
08/27/19 10:30 AM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
Given this car has been out of production and used in racing for the past 49 years, I'm amazed someone in NHRA doesn't already have the exception for this in place.
Re: T/A hood engineering diagram [Re: TC@HP2] #2691930
08/27/19 01:06 PM
08/27/19 01:06 PM
Virginia
V
varunner Offline OP
varunner  Offline OP
V
Virginia
They very well might, but wouldn't count on it. NHRA has a ton of stuff to keep up with, or should keep up with and records on hood latches ain't at the top of the list.. I'd just like to have documentation to deal with it if it comes up. So far I haven't found anything in B/W
Re: T/A hood engineering diagram [Re: varunner] #2691955
08/27/19 01:56 PM
08/27/19 01:56 PM
NW Chicago suburban area
Mopar Mitch Offline
Mopar Mitch  Offline
You won't find anything in black-white... the T/A hood ONLY uses hood pins... period... and the NHRA knows that... they've had plenty of other T/A hood cars run their past events for decades... same for the AAR Cuda hood.
Re: T/A hood engineering diagram [Re: Mopar Mitch] #2692002
08/27/19 04:32 PM
08/27/19 04:32 PM
Virginia
V
varunner Offline OP
varunner  Offline OP
V
Virginia
If NHRA hadn't recently made a statement about just using hood pins, I've wouldn't have wasted my time posting here.
Re: T/A hood engineering diagram [Re: varunner] #2692044
08/27/19 07:39 PM
08/27/19 07:39 PM
MD
floyd Online content
floyd  Online Content
MD
Come to think of it, it seems pretty odd that there wasn’t an engineering drawing for both the AAR and T/A hood set ups...
Re: T/A hood engineering diagram [Re: varunner] #2692249
08/28/19 11:14 AM
08/28/19 11:14 AM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Cheers
Might find something of note here, too. NO mention of latch on 'glass hood, only the factory-installed hood pins, FWIW...
http://hamtramck-historical.com/1970_TA_Challenger_Ordering.shtml
https://www.e-bodies.org/resources/...70-dodge-challenger-ta-review-road-test/
EDIT: I should add that my hood is an older ASC&P T/A replica, which was considered one of the better reproductions at that time, and there is no provision for a latch mechanism.
Re: T/A hood engineering diagram [Re: BradH] #2692382
08/28/19 07:08 PM
08/28/19 07:08 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
After the crusade to get that hood legal for non-T/A cars in Stock, I would think the NHRA has every piece of information there is. whistling
