Re: T/A hood engineering diagram
[Re: varunner]
#2691530
08/26/19 11:48 AM
08/26/19 11:48 AM
Posts: 5,894 Florida
Locomotion
Maybe you can find something by searching through this, or contacting the person who posted it. He does mention that the T/A hood had no latches and requires pins in Reply #6 on: January 23, 2017, 02:49:09 AM . But you'd have to ask if there is any factory documentation available outlining that. Challenger T/A info
[Re: Alaskan_TA]
#2691632
08/26/19 04:25 PM
08/26/19 04:25 PM
Locomotion
Hood pins only.
No place to mount a latch on the hoods & no need for the pop-up springs either. NHRA requires verifiable documentation if there is any variations that may conflict with their existing rules. They have been known to make exceptions, but being prepared, just in case, like in court, is prudent. Otherwise, it can hurt your wallet and reputation if they decide to enforce and/or "interpret" a particular rule against you.
[Re: varunner]
#2691705
08/26/19 08:40 PM
08/26/19 08:40 PM
Posts: 29,652 Hamtramck, PA
Alaskan_TA
Fluffy Balladeer
Fluffy Balladeer
Hamtramck, PA
Question:
Can I remove the hood latch and use hood pins on my Stock / Super Stock entry?
Answer:
Per the 2019 NHRA Rulebook sections 11A and 12A pages 11 and 9 under Body:7 Hood it reads "Full stock hood including latches, hinges, springs, brackets, and braces as originally produced must be retained." With that said you may add hood pins, in addition to the original latch. He asked if he could remove it. No latch to remove on T/As (or AARs) so you should be good to go.
[Re: varunner]
#2691955
08/27/19 01:56 PM
08/27/19 01:56 PM
Posts: 1,442 NW Chicago suburban area
Mopar Mitch
You won't find anything in black-white... the T/A hood ONLY uses hood pins... period... and the NHRA knows that... they've had plenty of other T/A hood cars run their past events for decades... same for the AAR Cuda hood.
Mopar Mitch
"Road racers and autocrossers go in deeper and come out harder!"... and rain never stops us from having fun with our cars... in fact, it makes us better drivers!
Check out MOPAR ACTION MAGAZINE, August 2006 issue for feature article and specs on my autocross T/A!
