Re: Anyone remove a spring from SS Springs?? [Re: moparjack44] #2687737
08/14/19 03:53 PM
08/14/19 03:53 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Did you see what the real problem is? Improper angle on the rear shackles. It helps to read more than just the op when replying because sometimes that leads to wrong advice. grin
Re: Anyone remove a spring from SS Springs?? [Re: stumpy] #2687778
08/14/19 06:40 PM
08/14/19 06:40 PM
GMP440 Offline
GMP440  Offline
How long have those rear springs been on the car? I ask because when I installed the ESPO 6 leaf HD leaf springs on my 68 Coronet the back end sat high like your Charger.
Took about 2 weeks before the new springs settled down. If yours are brand new give them a little time settle.
Re: Anyone remove a spring from SS Springs?? [Re: moparjack44] #2687791
08/14/19 07:04 PM
08/14/19 07:04 PM
Holler what it ends up being
Re: Anyone remove a spring from SS Springs?? [Re: stumpy] #2687953
08/15/19 09:49 AM
08/15/19 09:49 AM
Halifax, VA.
moparjack44 Offline
moparjack44  Offline
Halifax, VA.
OK, I get it. But I read each post (again), the word "angle" never said. shruggy Low, Lower, Height, mentioned in nearly every post. Last thing I would want to do is give bad advice, because I come here a lot looking for advice, and normally get good advice. I receive a lot more from this site than I give. up
The main thing is that he is able to get the "good" advice that will allow him to resolve his issue, angle or height.
K.I.S.S.
Re: Anyone remove a spring from SS Springs?? [Re: moparjack44] #2688005
08/15/19 12:20 PM
08/15/19 12:20 PM
central texas
K
krautrock Offline
krautrock  Offline
K
central texas
this is basically what people are thinking might be going on with the rear shackles.
i know my 3400lb bbody SS springs did this when i was dropping the car down, i just used a pry bar to pull the shackle to the correct position then finished setting the car down...
Re: Anyone remove a spring from SS Springs?? [Re: mymcodebee] #2688008
08/15/19 12:25 PM
08/15/19 12:25 PM
central texas
K
krautrock Offline
krautrock  Offline
K
central texas
Originally Posted by mymcodebee
That appears to be my issue. I will loosen up system and get these going the right way.
Thanks for the info I been messing with these for years and never run into this!
if this is what your shackle angle looks like, i think you need to be sure you have the correct front spring hangers. they are 2" longer than the factory hangers if you are using the Super Stock springs, which have a 20" front segment.
this is for SS springs.
https://www.manciniracing.com/marasphaset7.html
this is for the stock springs with 22" front segment.
https://www.manciniracing.com/marasphaset5.html
if you have the shorter front springs hangers, maybe it would be best to get some Reproduction XHD springs. the rear will probably sit lower then the SS springs.
Re: Anyone remove a spring from SS Springs?? [Re: krautrock] #2688038
08/15/19 01:37 PM
08/15/19 01:37 PM
Far Northeast.
mymcodebee Offline OP
Far Northeast.
Sorry guys probably wasn't clear enough on my post anyway. All info is good.
So my shackles are not sitting on the frame, not to say they wouldn't after a few rides as they are already heading in that direction..
My front shackles are these and were ordered with the springs.
I will work on them this weekend and see if it levels out a bit.
I'll keep you posted.
It has been sitting on these for at least six months but never driven on yet.
Re: Anyone remove a spring from SS Springs?? [Re: mymcodebee] #2688346
08/16/19 10:05 AM
08/16/19 10:05 AM
moparx Offline
moparx  Offline
what do the REAR shackles look like ?
the picture you posted is called the front spring HANGER.
beer
Re: Anyone remove a spring from SS Springs?? [Re: moparx] #2688349
08/16/19 10:15 AM
08/16/19 10:15 AM
central texas
K
krautrock Offline
krautrock  Offline
K
central texas
he already posted a pic. they are pointing in the wrong direction.
https://board.moparts.org/ubbthread...-spring-from-ss-springs.html#Post2687419
i have the 456/457 springs and they aren't super high.
i wonder if torquing the front bolt through the bushings with the rear in the air and the axle freehanging would make the car sit high...
Re: Anyone remove a spring from SS Springs?? [Re: krautrock] #2688356
08/16/19 10:31 AM
08/16/19 10:31 AM
moparx Offline
moparx  Offline
i must have forgot about that pic. sorry. "oldtimers" disease i got. grin
cranking the bushings tight while in the air does have a tendency to make things higher, as this puts the bushings in a bind.
beer
Re: Anyone remove a spring from SS Springs?? [Re: moparx] #2688575
08/16/19 10:06 PM
08/16/19 10:06 PM
Hamilton, Ontario Canada
Magnum Offline
Magnum  Offline
Measure how much lower you want the car to be. Then remove the springs and take your own measurement of the arch. Straight line from bushing to bushing, then record the distance from that line to the mounting stud for the centering pad.
Take them to a spring shop and have the dearched.
The wheel being forward in wheel opening will move rearward when the front segment more horizontal after the dearching.
Re: Anyone remove a spring from SS Springs?? [Re: Magnum] #2688585
08/16/19 10:24 PM
08/16/19 10:24 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Once he flips the shackles in the right direction he may not have to do anything else.
Re: Anyone remove a spring from SS Springs?? [Re: mymcodebee] #2688592
08/16/19 10:42 PM
08/16/19 10:42 PM
Magnum Offline
Magnum  Offline
That shackle is not overcenter holding the leaf in a bind. There is too much arch on the leaf. My P 454, 455 Super Stock springs are the same way. They are arched for 4x4 truck ground clearance. The center of my wheels are about 6" below the lowest point of the rocker panels.
Re: Anyone remove a spring from SS Springs?? [Re: Magnum] #2689371
08/19/19 12:47 PM
08/19/19 12:47 PM
Far Northeast.
Far Northeast.
I believe you are correct. I tried to move them and they appear to be exactly where they want to be...
Its going to take a little more effort. I will have to dig deeper and remove them and de arch or put some different springs on. There is no way to make this car sit how I want especially with my front end height being so limited with the Magnum Force front suspension.
Thank you for the input however everyone.
Re: Anyone remove a spring from SS Springs?? [Re: mymcodebee] #2689380
08/19/19 01:24 PM
08/19/19 01:24 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Glad you posted a picture with the last three digits/hand written part number visible.
The problem is, assuming the "456" is correct, then those are the wrong leaf springs.
I've tried to install them myself on a 68 to 70 b body, with the same result.
456/457 are too short, and they have a 35 inch rear segment, Mancini's website has been wrong for years.
You need leaf springs with a 36 inch rear segment.
Only two Mopar Performance springs have the correct 36" rear segment length: P3690455 left, and P3690454 right.
If you have your heart set on the 456 and 457 springs, you can make them work but you will have to
punch a hole through the frame rail and weld in a tube forward of the original location.
Good luck! up
Before it starts-
no, all super stock springs are not the same
yes they all do have a 20" front segment length
no they do not all have the same rear segment length
no the front hanger doesn't make up for the different rear segment length, only front where applicable
Rich H.
Esse Quam Videri
Re: Anyone remove a spring from SS Springs?? [Re: ZIPPY] #2689730
08/20/19 01:15 PM
08/20/19 01:15 PM
central texas
K
krautrock Offline
krautrock  Offline
K
central texas
this is one of the 456/457 springs I bought from summit 3-4 years ago. the original spring is from my 67 coronet.
the springs hangers are almost perfectly perpendicular to the ground, they point to the rear of the car just a tad. the reason for that is i used Plymouth front springs hangers instead of the Dodge front spring hangers. I was in a hurry ordering and didn't realize until I had already installed them. I think the that puts my axle about .60" forward of where it was originally...
https://flic.kr/p/SYGCT5
Re: Anyone remove a spring from SS Springs?? [Re: krautrock] #2689735
08/20/19 01:31 PM
08/20/19 01:31 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Really it's best to take a tape measure, check rear segment length to start with....when these things come up....
36" is the book spec length for later B body. All except 454/455 are shorter than 36".
In the case of my '69 it had to be 454/455, nothing else would work, same issue as original poster.
I believe some of it depends on how much the arch flattens out with vehicle weight applied (or does not flatten out
as in the case of an earlier poster).
Rich H.
Esse Quam Videri
Re: Anyone remove a spring from SS Springs?? [Re: ZIPPY] #2689804
08/20/19 06:48 PM
08/20/19 06:48 PM
Far Northeast.
Far Northeast.
Wow great info. I had no idea I was going to get this much info on this post. I will pull these springs off and get the ones on there that are supposed to be on there.
Thank you for the info!!
Re: Anyone remove a spring from SS Springs?? [Re: mymcodebee] #2689890
08/21/19 12:09 AM
08/21/19 12:09 AM
Wichita
GY3 Online content
GY3  Online Content
Wichita
Or, throw them in the garbage where they belong!
They will end up there in a couple of years anyway after losing their arch and becoming more flaccid than an 80 year-old man.
Buy springs from someone with a better reputation than MP.
'63 Dodge 330
11.19 @ 121 mph
