top ring for a second ring? #2686318
08/10/19 06:09 PM
08/10/19 06:09 PM
Detroit Michigan
stinger Offline OP
stinger  Offline OP
Detroit Michigan
Long story short,I'm short a second ring but have extra top rings on a total seal file fit sets.Can I use a top ring for the second ring on one cylilinder? to me they look the same and are the same size but different material.I hate to have to buy another set if I really don't have to.
Re: top ring for a second ring? [Re: stinger] #2686319
08/10/19 06:13 PM
08/10/19 06:13 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
I wouldn't do it. You can buy a single ring.
Re: top ring for a second ring? [Re: stinger] #2686320
08/10/19 06:14 PM
08/10/19 06:14 PM
Missouri
jwb123 Offline
jwb123  Offline
Missouri
I have never tried it, but I would think it would depend on the type of rings you are using, if it is just a cheap set of iron rings, and they have bevels on the inside of the ring, just flip the extra top ring put the bevel down. On all rings I have used the bevel faces up on the top rind and down on the second ring. If it has a moly barrel face ring with no bevels then I don't think I would try it. Most companies will sell a set for one cylinder.
Re: top ring for a second ring? [Re: stinger] #2686324
08/10/19 06:31 PM
08/10/19 06:31 PM
Byron, NY
W.I.N. Racing Offline
Byron, NY
Awful lot of work and expense if it doesn't work...
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60
'01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust,
'05 Dodge Magnum R/T - Too Much to list
'60 Willys CJ5
'01 International LPX - Project,DT466, Allison
'64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: top ring for a second ring? [Re: W.I.N. Racing] #2686328
08/10/19 06:43 PM
08/10/19 06:43 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
Single rings are sold everyday. Probably moly top cast second but it should say on the box.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: top ring for a second ring? [Re: pittsburghracer] #2686330
08/10/19 06:58 PM
08/10/19 06:58 PM
Detroit Michigan
stinger Offline OP
stinger  Offline OP
Detroit Michigan
Yep Ill look around town. Nothing from the internet that I can find. Top is molly second cast
Re: top ring for a second ring? [Re: stinger] #2686337
08/10/19 07:26 PM
08/10/19 07:26 PM
PA.
"Little"John
"Little"John
PA.
What size is it. Maybe one of us have one.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: top ring for a second ring? [Re: pittsburghracer] #2686340
08/10/19 07:36 PM
08/10/19 07:36 PM
Detroit Michigan
stinger Offline OP
stinger  Offline OP
Detroit Michigan
4.360 1/16" speed pro cr6490 45
Re: top ring for a second ring? [Re: stinger] #2686341
08/10/19 07:41 PM
08/10/19 07:41 PM
USA
B3RE Offline
B3RE  Offline
USA
Don't do it! The second ring is a scraper ring that does more to control oil than seal compression. It will likely burn oil like crazy if you do.
Mike Beachel
I didn't write the rules of math nor create the laws of physics, I am just bound by them.
Re: top ring for a second ring? [Re: B3RE] #2686347
08/10/19 08:00 PM
08/10/19 08:00 PM
McGregor,Iowa 52157
500ciDuster Offline
500ciDuster  Offline
McGregor,Iowa 52157
It happened to me a few years back on a friends 360 and when we ordered the single ring it was about 1/2 the price of the full set which sucked
Re: top ring for a second ring? [Re: stinger] #2686376
08/10/19 11:12 PM
08/10/19 11:12 PM
Call Total seal direct and tell them you had one broken ring in the set when you opened it up scope devil
I had one of there rings break while trying to install it years ago, it broke where a bubble was in the ring shock shruggy
Stuff happens, no one or company is perfect, yet whistling
Re: top ring for a second ring? [Re: Cab_Burge] #2686383
08/11/19 12:16 AM
08/11/19 12:16 AM
Detroit Michigan
stinger Offline OP
stinger  Offline OP
Detroit Michigan
I found a single cylinder kit at summit for 30 bucks shipped. I didn't think it was a good idea but had to ask. Thanks all!
Re: top ring for a second ring? [Re: stinger] #2686408
08/11/19 08:08 AM
08/11/19 08:08 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
generally speaking, top and 2nd rings have inside chamfers that are in a different position between the two. they're made to work in different directions. some cheaper ring don't have the chamfers. this is the reason that rings are stamped with a "pip" mark to keep the chamfers in their proper location.
Re: top ring for a second ring? [Re: lewtot184] #2686418
08/11/19 09:43 AM
08/11/19 09:43 AM
Detroit Michigan
stinger Offline OP
stinger  Offline OP
Detroit Michigan
Other than the ring material I can't see a difference between the two in this set. Readers on and holding them up to a light. the bevel must be microscopic.
Re: top ring for a second ring? [Re: stinger] #2686534
08/11/19 03:43 PM
08/11/19 03:43 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
the bevel is to the inside. look to see if the rings have a pip mark.
Re: top ring for a second ring? [Re: stinger] #2686637
08/11/19 09:26 PM
08/11/19 09:26 PM
Some top rings have a barrel face, some don't. shruggy
Most 2nd rings have a reverse taper on the inside, some don't scope
Re: top ring for a second ring? [Re: Cab_Burge] #2687245
08/13/19 01:19 PM
08/13/19 01:19 PM
NW Chicago suburban area
Mopar Mitch Offline
Mopar Mitch  Offline
DO NOT interchange rings as their cross sectional shape, as well as the tensions, gaps, coatings and OD shapes are different. Rings are a science.
I currently work for a major global piston ring manufacturer.
Re: top ring for a second ring? [Re: stinger] #2687258
08/13/19 01:40 PM
08/13/19 01:40 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
I might have some extras. I'll look when I get home
Never mind, they are the -35 part number, sorry.
Re: top ring for a second ring? [Re: 451Mopar] #2687269
08/13/19 01:57 PM
08/13/19 01:57 PM
The 4.355 bore size file to fit rings may fit perfectly in the 4.360 scope
I wouldn't hesitate to try them to see if they will fit with little or no grinding on the ends to make them fit in the 4.360 bore twocents
OP, use a bright light under the ring to see if any light shows between the ring and the cylinder wall with the ring squared up in the bore scope
if is does show light don't use it tsk
