Re: top ring for a second ring?
[Re: stinger]
#2686324
08/10/19 06:31 PM
08/10/19 06:31 PM
Posts: 2,105 Byron, NY
W.I.N. Racing
Byron, NY
Awful lot of work and expense if it doesn't work...
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
[Re: W.I.N. Racing]
#2686328
08/10/19 06:43 PM
08/10/19 06:43 PM
Posts: 20,163 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Single rings are sold everyday. Probably moly top cast second but it should say on the box.
[Re: stinger]
#2686337
08/10/19 07:26 PM
08/10/19 07:26 PM
Posts: 20,163 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Yep Ill look around town. Nothing from the internet that I can find. Top is molly second cast What size is it. Maybe one of us have one.
[Re: stinger]
#2686341
08/10/19 07:41 PM
08/10/19 07:41 PM
Posts: 561 USA
B3RE
USA
Long story short,I'm short a second ring but have extra top rings on a total seal file fit sets.Can I use a top ring for the second ring on one cylilinder? to me they look the same and are the same size but different material.I hate to have to buy another set if I really don't have to. Don't do it! The second ring is a scraper ring that does more to control oil than seal compression. It will likely burn oil like crazy if you do.
Mike Beachel
I didn't write the rules of math nor create the laws of physics, I am just bound by them.
[Re: stinger]
#2686376
08/10/19 11:12 PM
08/10/19 11:12 PM
Posts: 43,127 Bend,OR USA
Cab_Burge
[Re: stinger]
#2686534
08/11/19 03:43 PM
08/11/19 03:43 PM
Posts: 3,916 usa
lewtot184
usa
Other than the ring material I can't see a difference between the two in this set. Readers on and holding them up to a light. the bevel must be microscopic. the bevel is to the inside. look to see if the rings have a pip mark.
[Re: Cab_Burge]
#2687245
08/13/19 01:19 PM
08/13/19 01:19 PM
Posts: 1,442 NW Chicago suburban area
Mopar Mitch
DO NOT interchange rings as their cross sectional shape, as well as the tensions, gaps, coatings and OD shapes are different. Rings are a science.
I currently work for a major global piston ring manufacturer.
Mopar Mitch
"Road racers and autocrossers go in deeper and come out harder!"... and rain never stops us from having fun with our cars... in fact, it makes us better drivers!
Check out MOPAR ACTION MAGAZINE, August 2006 issue for feature article and specs on my autocross T/A!
[Re: stinger]
#2687258
08/13/19 01:40 PM
08/13/19 01:40 PM
Posts: 5,399 Aurora, Colorado
451Mopar
Aurora, Colorado
I might have some extras. I'll look when I get home
Never mind, they are the -35 part number, sorry.
[Re: 451Mopar]
#2687269
08/13/19 01:57 PM
08/13/19 01:57 PM
Cab_Burge
Never mind, they are the -35 part number, sorry. The 4.355 bore size file to fit rings may fit perfectly in the 4.360 I wouldn't hesitate to try them to see if they will fit with little or no grinding on the ends to make them fit in the 4.360 bore OP, use a bright light under the ring to see if any light shows between the ring and the cylinder wall with the ring squared up in the bore if is does show light don't use it
