Whose Rockers are these? #2683062
07/31/19 11:54 AM
07/31/19 11:54 AM
Moved to N.E. Tennessee
GomangoCuda Offline OP
I thought they look a lot like cranes but they do not have the name Crane cast in the bottom. They have interference fit adjusting screws but appear to be spot faced for locknut type adjusting screws. Desirable or not?
Re: Whose Rockers are these? [Re: GomangoCuda] #2683071
07/31/19 12:11 PM
07/31/19 12:11 PM
Cab_Burge Online work
Cab_Burge  Online Work
Looks like stock Mopar 273 rockers to me, just like some I have in the shop shruggy
Re: Whose Rockers are these? [Re: Cab_Burge] #2683081
07/31/19 12:37 PM
07/31/19 12:37 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
SB rockers are straight....... that one looks offset to me..... so it should be a BB rocker.
Looks like the same casting as the Cranes....... but with the “wrong” adjuster screw.
There’s a machined flat on the rocker for a lock nut, and that’s a friction lock adjuster in the rocker.
Maybe an “early” Crane rocker that’s had the adjuster replaced.
Re: Whose Rockers are these? [Re: GomangoCuda] #2683106
07/31/19 01:31 PM
07/31/19 01:31 PM
Springtown Pa
Ray408G3Hemi Offline
Springtown Pa
They look like the old Isky Rockers, I have a set here on a 440 Parts motor
1963 Thunderbolt 496FE 10.80 (still a work in progress)
1968 Mustang slow a$$ 428 FE
1971 Boss 351 Mustang 11.20@115mph
1993 Lightning 10.61 @ 129mph 408Ci A3 headed NA
1996 Viper GTS
2001 Lightning 8.99 @ 155MPH 5.4 Mod Motor
2009 Ram 9.65@144MPH 463CI G3 NA
2010 Challenger 9.91 @ 139MPH 408CI G3ci NA
2019 F150 (local dealer's Lightning package) ..11.90s
Re: Whose Rockers are these? [Re: Ray408G3Hemi] #2683112
07/31/19 01:55 PM
07/31/19 01:55 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
crane with the factory interference fit adjuster.
Re: Whose Rockers are these? [Re: Ray408G3Hemi] #2683113
07/31/19 01:56 PM
07/31/19 01:56 PM
So. Burlington, Vt.
So. Burlington, Vt.
They aren’t “Isky” rockers........ although at one point Isky was selling the Crane rockers.
The actual Isky rockers have a distinctive look:
Re: Whose Rockers are these? [Re: fast68plymouth] #2683140
07/31/19 03:40 PM
07/31/19 03:40 PM
I have a set of those also that I am going to keep. Mine are not bushed. Did you.do that or RAS?
I think the other set must have been made by Crane for some other cam company to market. Who knows when the adjusters were.swapped. I found them when I was looking through stuff that I have had forever. Need to thin out the stash of old stuff that I will likely never use. I will have a pile of old parts in the 4sale section soon. Some used some never used but most are approximately 40+ years old.
Re: Whose Rockers are these? [Re: GomangoCuda] #2683141
07/31/19 03:43 PM
07/31/19 03:43 PM
So. Burlington, Vt.
So. Burlington, Vt.
Those aren’t my Isky rockers....... it’s just a pic I grabbed on line.
I have a set of Isky’s, but no pics of them handy.
I lightened mine up by reducing that big “knob” out on the end, and trimming the rib a bit.
Re: Whose Rockers are these? [Re: fast68plymouth] #2683146
07/31/19 04:10 PM
07/31/19 04:10 PM
Missouri
galen Offline
galen  Offline
Missouri
Look just like the sig ersons I bought from supershops in the early 80s. Interference adjuster and all.
Re: Whose Rockers are these? [Re: galen] #2683148
07/31/19 04:26 PM
07/31/19 04:26 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I agree lok like Sig Ersons.I still have mine on my 440.Bought them in 70.Just replaced the adjusters with MP ones.Rocky
Chrysler Firepower
Re: Whose Rockers are these? [Re: galen] #2683150
07/31/19 04:31 PM
07/31/19 04:31 PM
Now that you mention it I remember that erson had iron rockers that looked like Cranes. Bet that's what these are.
Thanks all.
Re: Whose Rockers are these? [Re: GomangoCuda] #2683157
07/31/19 05:05 PM
07/31/19 05:05 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Crower had ductile iron rockers available in the late 1970s that looked like that. They had no lock nut and had an interference fit on the adjuster. When I bought them new and got them I was unsatisfied with the adjuster arrangement being concerned that they would not hold adjustment. So I called Dave Crower and expressed my concern. I recall that switching them over to a standard adjuster with a lock nut was really not an option as the threads were unique. Dave agreed to take the rockers back. I then bought the Iskys (which were more money). Still have the Isky's today.
Re: Whose Rockers are these? [Re: BSB67] #2683160
07/31/19 05:16 PM
07/31/19 05:16 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
not sure about the crowers but pretty sure the crane and sig's are the same. the cam grinders don't make much stuff so i'll bet the rockers were sourced from the same foundry. I've had crane rockers with and without the crane script. I've used the interference thread adjusters back in the day (replacing the jam nut adjusters) and the thread pitch is the same for both. pro's and cons to using either adjuster. the interference fit adjuster is hollow and they can break off in the rocker if ones not careful (they're not designed for constant adjusting).
Re: Whose Rockers are these? [Re: lewtot184] #2683167
07/31/19 05:25 PM
07/31/19 05:25 PM
Shelby mi.
JAKE68 Offline
JAKE68  Offline
Shelby mi.
THOSE LOOK JUST LIKE STOCK 273 ROCKERS
JAKES AUTOMOTIVE
Re: Whose Rockers are these? [Re: JAKE68] #2683213
07/31/19 08:31 PM
07/31/19 08:31 PM
So. Burlington, Vt.
So. Burlington, Vt.
Actually, the OP’s pic doesn’t look much like 273 rockers at all to me.
1st pic- 273 rockers
2nd pic- Crane SB rocker
3rd & 4th pic- Crane BB rockers
E9F65A2F-DD4F-4FD9-879C-B58371F38E7B.png78D7DB18-274D-406D-8546-DE481A5AA5A8.png8599930D-A447-4EFB-B371-5BB0704B98BB.png76EA4F22-F219-406C-9E75-779253E993F1.png
Re: Whose Rockers are these? [Re: GomangoCuda] #2683246
07/31/19 09:38 PM
07/31/19 09:38 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
That rocker is mine and yes I had them blueprinted,bushed,re-directed oil passages,trimmed down,and new hardware installed by RAS about 6 years ago and still going strong
Cost me about $500 with shafts .
Gus beer
64 Plymouth Savoy
Dana 60
Re: Whose Rockers are these? [Re: JAKE68] #2683258
07/31/19 10:06 PM
07/31/19 10:06 PM
pennsylvania
poboyengineering Offline
pennsylvania
I have 3-4 sets of 273 rockers, and they all have a casting 'knob' on the underside, presumably where they poured them.
It may be ugly, but it sure is slow.
Girls comb their hair in rear view mirrors and the boys try to look so hard....
Re: Whose Rockers are these? [Re: fast68plymouth] #2683285
07/31/19 11:18 PM
07/31/19 11:18 PM
They look like fast's last pic from above. Definitely not straight like small block rockers
Re: Whose Rockers are these? [Re: GomangoCuda] #2683381
08/01/19 10:24 AM
08/01/19 10:24 AM
So. Burlington, Vt.
So. Burlington, Vt.
This is a close up of the pair of Crane rockers above.
I’ve seen this casting mark on a number of different kinds of rockers through the years.
Re: Whose Rockers are these? [Re: fast68plymouth] #2683500
08/01/19 07:11 PM
08/01/19 07:11 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
i have some cranes with the same script. I believe it's a foundry mark.
