Whose Rockers are these?
#2683062
07/31/19 11:54 AM
07/31/19 11:54 AM
Posts: 4,760 Moved to N.E. Tennessee
GomangoCuda
I thought they look a lot like cranes but they do not have the name Crane cast in the bottom. They have interference fit adjusting screws but appear to be spot faced for locknut type adjusting screws. Desirable or not?
Re: Whose Rockers are these?
[Re: Cab_Burge]
#2683081
07/31/19 12:37 PM
07/31/19 12:37 PM
fast68plymouth
So. Burlington, Vt.
SB rockers are straight....... that one looks offset to me..... so it should be a BB rocker.
Looks like the same casting as the Cranes....... but with the “wrong” adjuster screw. There’s a machined flat on the rocker for a lock nut, and that’s a friction lock adjuster in the rocker.
Maybe an “early” Crane rocker that’s had the adjuster replaced.
[Re: GomangoCuda]
#2683106
07/31/19 01:31 PM
07/31/19 01:31 PM
Posts: 194 Springtown Pa
Ray408G3Hemi
Springtown Pa
They look like the old Isky Rockers, I have a set here on a 440 Parts motor
1963 Thunderbolt 496FE 10.80 (still a work in progress) 1968 Mustang slow a$$ 428 FE 1971 Boss 351 Mustang 11.20@115mph 1993 Lightning 10.61 @ 129mph 408Ci A3 headed NA 1996 Viper GTS 2001 Lightning 8.99 @ 155MPH 5.4 Mod Motor 2009 Ram 9.65@144MPH 463CI G3 NA 2010 Challenger 9.91 @ 139MPH 408CI G3ci NA 2019 F150 (local dealer's Lightning package) ..11.90s
[Re: Ray408G3Hemi]
#2683113
07/31/19 01:56 PM
07/31/19 01:56 PM
fast68plymouth
So. Burlington, Vt.
They aren’t “Isky” rockers........ although at one point Isky was selling the Crane rockers.
The actual Isky rockers have a distinctive look:
[Re: fast68plymouth]
#2683140
07/31/19 03:40 PM
07/31/19 03:40 PM
GomangoCuda
The actual Isky rockers have a distinctive look: I have a set of those also that I am going to keep. Mine are not bushed. Did you.do that or RAS? I think the other set must have been made by Crane for some other cam company to market. Who knows when the adjusters were.swapped. I found them when I was looking through stuff that I have had forever. Need to thin out the stash of old stuff that I will likely never use. I will have a pile of old parts in the 4sale section soon. Some used some never used but most are approximately 40+ years old.
[Re: GomangoCuda]
#2683141
07/31/19 03:43 PM
07/31/19 03:43 PM
fast68plymouth
So. Burlington, Vt.
Those aren’t my Isky rockers....... it’s just a pic I grabbed on line.
I have a set of Isky’s, but no pics of them handy.
I lightened mine up by reducing that big “knob” out on the end, and trimming the rib a bit.
[Re: galen]
#2683148
07/31/19 04:26 PM
07/31/19 04:26 PM
Posts: 21,083 Niles , Ohio
therocks
Niles , Ohio
I agree lok like Sig Ersons.I still have mine on my 440.Bought them in 70.Just replaced the adjusters with MP ones.Rocky
Chrysler Firepower
[Re: galen]
#2683150
07/31/19 04:31 PM
07/31/19 04:31 PM
GomangoCuda
Look just like the sig ersons I bought from supershops in the early 80s. Interference adjuster and all. Now that you mention it I remember that erson had iron rockers that looked like Cranes. Bet that's what these are. Thanks all.
[Re: lewtot184]
#2683167
07/31/19 05:25 PM
07/31/19 05:25 PM
Posts: 1,495 Shelby mi.
JAKE68
Shelby mi.
THOSE LOOK JUST LIKE STOCK 273 ROCKERS
JAKES AUTOMOTIVE
[Re: JAKE68]
#2683213
07/31/19 08:31 PM
07/31/19 08:31 PM
fast68plymouth
So. Burlington, Vt.
Actually, the OP’s pic doesn’t look much like 273 rockers at all to me.
1st pic- 273 rockers 2nd pic- Crane SB rocker 3rd & 4th pic- Crane BB rockers
[Re: GomangoCuda]
#2683246
07/31/19 09:38 PM
07/31/19 09:38 PM
Posts: 10,558 Rittman Ohio
fourgearsavoy
Rittman Ohio
The actual Isky rockers have a distinctive look: I have a set of those also that I am going to keep. Mine are not bushed. Did you.do that or RAS? I think the other set must have been made by Crane for some other cam company to market. Who knows when the adjusters were.swapped. I found them when I was looking through stuff that I have had forever. Need to thin out the stash of old stuff that I will likely never use. I will have a pile of old parts in the 4sale section soon. Some used some never used but most are approximately 40+ years old. That rocker is mine and yes I had them blueprinted,bushed,re-directed oil passages,trimmed down,and new hardware installed by RAS about 6 years ago and still going strong Cost me about $500 with shafts . Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: JAKE68]
#2683258
07/31/19 10:06 PM
07/31/19 10:06 PM
Posts: 685 pennsylvania
poboyengineering
pennsylvania
I have 3-4 sets of 273 rockers, and they all have a casting 'knob' on the underside, presumably where they poured them.
It may be ugly, but it sure is slow.
Girls comb their hair in rear view mirrors and the boys try to look so hard....
[Re: GomangoCuda]
#2683381
08/01/19 10:24 AM
08/01/19 10:24 AM
fast68plymouth
So. Burlington, Vt.
This is a close up of the pair of Crane rockers above.
I’ve seen this casting mark on a number of different kinds of rockers through the years.
#2683500
08/01/19 07:11 PM
08/01/19 07:11 PM
Posts: 3,916 usa
lewtot184
usa
I’ve seen this casting mark on a number of different kinds of rockers through the years. i have some cranes with the same script. I believe it's a foundry mark.
