Inner and outer tie rod ends
#2669887
06/25/19 06:51 PM
06/25/19 06:51 PM
Posts: 3,623 Millinocket, Maine
JonC
Millinocket, Maine
I'm just getting to replace the tie rod ends on my 72 Cuda. Is there a difference in the outer and inner ends other than the RH and LH threads? I have two a bit different than the other two.
11B40
Re: Inner and outer tie rod ends
[Re: stumpy]
#2669900
06/25/19 07:30 PM
06/25/19 07:30 PM
JonC
Millinocket, Maine
Stem sizes are not the same where the nut goes on. I'm not sure if the taper is different or not, I haven't measured them. One is a coarse thread and the other fine thread.
11B40
[Re: JonC]
#2669914
06/25/19 08:08 PM
06/25/19 08:08 PM
Posts: 11,836 Florida
mopar346
Let me tell ya about fat chicks!
2 different manufacturers is my guess or even different suppliers for the vendor. I cant remember tearing down any original cars with 2 different size nuts on them.
Careful, your character's showing!
[Re: mopar346]
#2669923
06/25/19 08:21 PM
06/25/19 08:21 PM
RapidRobert
I'd pull the boots & see if taper dimention(s) are the same but highly likely I would just find out which ones' #'s is correct then order another identical one
[Re: JonC]
#2670518
06/27/19 02:11 AM
06/27/19 02:11 AM
Posts: 1,757 Phila
PhillyRag
Phila
One of them has "TVA-ES4011R TVA306" and the other "OEXA30417 DM30441L". The ES4011R seems correct. The 441L doesn't. Which threads are different.?
[Re: PhillyRag]
#2670875
06/27/19 08:10 PM
06/27/19 08:10 PM
JonC
Millinocket, Maine
I'm not home right now, but the one at the top of my photo doesn't seem right. When tightened down the hole for the cotter pin is way above the castle nut. And the boot is squished a lot.
11B40
[Re: JonC]
#2670933
06/27/19 10:48 PM
06/27/19 10:48 PM
RapidRobert
the 2 different threads ain't right at all. I would think an inadvertent assy line/packaging mistake. they are human.
[Re: RapidRobert]
#2681495
07/26/19 08:53 AM
07/26/19 08:53 AM
JonC
Millinocket, Maine
I just received a new shipment today of new outer ends from a different vendor, the same as the other two. These have a part number of LTTRES401R. Can someone give me the part number I need? If I install these, the castle nut is so far down on the stem the cotter pin is way above the top of it. I really want to drive it this summer, but working in the woods and only getting home once in a while to work one it to find the wrong part again is frustrating. I need the outer on both sides. Below is a link to my first purchase.
https://www.ebay.com/itm/Set-of-2-Pairs-Front-Inner-Outer-Tie-Rod-End-For-70-83-Chrysler-Cordoba-Dodge/291989241573?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649
11B40
[Re: rbkt65]
#2681616
07/26/19 03:14 PM
07/26/19 03:14 PM
JonC
Millinocket, Maine
Just called NAPA and they can have them by tomorrow. Real Moog ones. $10.00 a pop, should have gone there first. It'll be a couple weeks before I'm out of the woods again but hope to get it done for August and Sept.
11B40
[Re: rbkt65]
#2681617
07/26/19 03:21 PM
07/26/19 03:21 PM
Posts: 3,886 Lost and Spaced
bboogieart
Lost and Spaced
go to a reputable parts store like napa or your local chain brand and get them. I agree. They do have an on line presence also. I was surprised just what is still available these days. Always figured old stuff would be unavailable.
I have mechanical Aptitude. I can screw up anything.
[Re: JonC]
#2681738
07/27/19 06:21 AM
07/27/19 06:21 AM
Posts: 531 Charlotte, NC
Kowal
Charlotte, NC
Just called NAPA and they can have them by tomorrow. Real Moog ones. $10.00 a pop, should have gone there first. It'll be a couple weeks before I'm out of the woods again but hope to get it done for August and Sept. If you haven’t already, and the current suspension is assembled, order yourself a good tie rod puller otherwise you will be in for another delay, or at least a trip to the auto parts store
'69 Hemi Charger 500, ‘70 U code Challenger R/T (These and a bunch others at www.dkowal426.com) P.J. O'Rouke: "The old car ran perfectly, right up until it didn't."
[Re: Kowal]
#2682205
07/29/19 03:30 AM
07/29/19 03:30 AM
JonC
Millinocket, Maine
Got the correct ones and have them installed. Now to get it aligned. I do have a puller, thanks for the help guys.
11B40
