Inner and outer tie rod ends #2669887
06/25/19 06:51 PM
06/25/19 06:51 PM
Millinocket, Maine
JonC Offline OP
JonC  Offline OP
Millinocket, Maine
I'm just getting to replace the tie rod ends on my 72 Cuda. Is there a difference in the outer and inner ends other than the RH and LH threads? I have two a bit different than the other two.
11B40
Re: Inner and outer tie rod ends [Re: JonC] #2669890
06/25/19 07:00 PM
06/25/19 07:00 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
how are they different?
Re: Inner and outer tie rod ends [Re: stumpy] #2669900
06/25/19 07:30 PM
06/25/19 07:30 PM
Millinocket, Maine
JonC Offline OP
JonC  Offline OP
Millinocket, Maine
Stem sizes are not the same where the nut goes on. I'm not sure if the taper is different or not, I haven't measured them. One is a coarse thread and the other fine thread.
11B40
Re: Inner and outer tie rod ends [Re: JonC] #2669914
06/25/19 08:08 PM
06/25/19 08:08 PM
mopar346 Offline
Let me tell ya about fat chicks!
mopar346  Offline
2 different manufacturers is my guess or even different suppliers for the vendor. I cant remember tearing down any original cars with 2 different size nuts on them.
Careful, your character's showing!
Re: Inner and outer tie rod ends [Re: mopar346] #2669923
06/25/19 08:21 PM
06/25/19 08:21 PM
I'd pull the boots & see if taper dimention(s) are the same but highly likely I would just find out which ones' #'s is correct then order another identical one
Re: Inner and outer tie rod ends [Re: JonC] #2670020
06/26/19 01:22 AM
06/26/19 01:22 AM
Phila
P
PhillyRag Offline
PhillyRag  Offline
P
Phila
I've never encountered them on any specific car the TPI was different. Are they stamped 400L 400R or such?
Re: Inner and outer tie rod ends [Re: PhillyRag] #2670071
06/26/19 07:53 AM
06/26/19 07:53 AM
Millinocket, Maine
JonC Offline OP
JonC  Offline OP
Millinocket, Maine
One of them has "TVA-ES4011R TVA306" and the other "OEXA30417 DM30441L".
11B40
Re: Inner and outer tie rod ends [Re: JonC] #2670518
06/27/19 02:11 AM
06/27/19 02:11 AM
Phila
P
PhillyRag Offline
PhillyRag  Offline
P
Phila
The ES4011R seems correct. The 441L doesn't.
Which threads are different.?
Re: Inner and outer tie rod ends [Re: PhillyRag] #2670875
06/27/19 08:10 PM
06/27/19 08:10 PM
Millinocket, Maine
JonC Offline OP
JonC  Offline OP
Millinocket, Maine
I'm not home right now, but the one at the top of my photo doesn't seem right. When tightened down the hole for the cotter pin is way above the castle nut. And the boot is squished a lot.
11B40
Re: Inner and outer tie rod ends [Re: JonC] #2670933
06/27/19 10:48 PM
06/27/19 10:48 PM
the 2 different threads ain't right at all. I would think an inadvertent assy line/packaging mistake. they are human.
Re: Inner and outer tie rod ends [Re: RapidRobert] #2681495
07/26/19 08:53 AM
07/26/19 08:53 AM
Millinocket, Maine
JonC Offline OP
JonC  Offline OP
Millinocket, Maine
I just received a new shipment today of new outer ends from a different vendor, the same as the other two. These have a part number of LTTRES401R. Can someone give me the part number I need? If I install these, the castle nut is so far down on the stem the cotter pin is way above the top of it. I really want to drive it this summer, but working in the woods and only getting home once in a while to work one it to find the wrong part again is frustrating. I need the outer on both sides. Below is a link to my first purchase.
https://www.ebay.com/itm/Set-of-2-Pairs-Front-Inner-Outer-Tie-Rod-End-For-70-83-Chrysler-Cordoba-Dodge/291989241573?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649
11B40
Re: Inner and outer tie rod ends [Re: JonC] #2681585
07/26/19 12:51 PM
07/26/19 12:51 PM
illinois
rbkt65 Offline
rbkt65  Offline
illinois
if you are buying off ebay, it is no wonder. go to a reputable parts store like napa or your local chain brand and get them. napa will order them in if they are in local pdc at no cost to you. if not they can shuttle them in at no cost to you for your inspection.
Re: Inner and outer tie rod ends [Re: rbkt65] #2681616
07/26/19 03:14 PM
07/26/19 03:14 PM
Millinocket, Maine
JonC Offline OP
JonC  Offline OP
Millinocket, Maine
Just called NAPA and they can have them by tomorrow. Real Moog ones. $10.00 a pop, should have gone there first. It'll be a couple weeks before I'm out of the woods again but hope to get it done for August and Sept.
11B40
Re: Inner and outer tie rod ends [Re: rbkt65] #2681617
07/26/19 03:21 PM
07/26/19 03:21 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
I agree.
They do have an on line presence also. shruggy
I was surprised just what is still available these days.
Always figured old stuff would be unavailable.
I have mechanical Aptitude.
I can screw up anything.
Re: Inner and outer tie rod ends [Re: bboogieart] #2681643
07/26/19 05:14 PM
07/26/19 05:14 PM
cbusters Offline
cbusters  Offline
I have Moog on my 69 RR and a couple were too long also and I ended up using thick washers to get the tri castle nuts to work. They are small diameter so they look correct even if they are not.
Re: Inner and outer tie rod ends [Re: cbusters] #2681666
07/26/19 07:20 PM
07/26/19 07:20 PM
illinois
rbkt65 Offline
rbkt65  Offline
illinois
glad you got them coming. ask me how i know, i am retiring from an independently owned napa in illinois on wednesday. it pays to look everywhere at times. warranty is pretty good also. good luck.
Re: Inner and outer tie rod ends [Re: JonC] #2681738
07/27/19 06:21 AM
07/27/19 06:21 AM
Charlotte, NC
Kowal Offline
Kowal  Offline
Charlotte, NC
If you haven’t already, and the current suspension is assembled, order yourself a good tie rod puller otherwise you will be in for another delay, or at least a trip to the auto parts store
'69 Hemi Charger 500, ‘70 U code Challenger R/T
(These and a bunch others at www.dkowal426.com)
P.J. O'Rouke: "The old car ran perfectly, right up until it didn't."
Re: Inner and outer tie rod ends [Re: Kowal] #2682205
07/29/19 03:30 AM
07/29/19 03:30 AM
Millinocket, Maine
JonC Offline OP
JonC  Offline OP
Millinocket, Maine
Got the correct ones and have them installed. Now to get it aligned. I do have a puller, thanks for the help guys.
11B40
