Can someone ID this trans for me? #2681045
07/24/19 10:13 PM
07/24/19 10:13 PM
Toronto, Ontario, Canada
plazomat Offline OP
plazomat  Offline OP
Hi Guys,
Another newbie question here..
Looking at picking up this used trans. supposed to be a small block 727. Kinda looking to upgrade the 904 behind my 318 for a while, its starting to slip.
Is it a 727 for a small block? What should I check out before i pay for it. supposedly rebuilt 4 years ago and has been sitting on garage floor as shown since then.
How can I tell what year its from and if it will work behind my 318? in my 69 Plymouth B-Body..
Plaz
Re: Can someone ID this trans for me? [Re: plazomat] #2681061
07/24/19 11:02 PM
07/24/19 11:02 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Can you get a picture of the bell housing opening so we can see the bolt pattern and starter position?
Re: Can someone ID this trans for me? [Re: stumpy] #2681067
07/24/19 11:33 PM
07/24/19 11:33 PM
Between Houston & Galveston TX
SattyNoCar Offline
SattyNoCar  Offline
What Stumpy is looking for. Pulled this pic off the internet. Note the measurements and starter location.
John
Re: Can someone ID this trans for me? [Re: SattyNoCar] #2681103
07/25/19 06:47 AM
07/25/19 06:47 AM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
Look on the flat spot on the drivers side pan rail and give us the number that starts with PK.
Re: Can someone ID this trans for me? [Re: fastmark] #2681191
07/25/19 10:42 AM
07/25/19 10:42 AM
moparx Offline
moparx  Offline
easiest way to tell a small block 727 from a big block is shown by the posted picture.
a big block starter [nose locator] is located at the 3 o'clock position, while a small block starter [nose locator] is at slightly past 4 o'clock. no measuring required.
beer
Re: Can someone ID this trans for me? [Re: plazomat] #2681202
07/25/19 11:07 AM
07/25/19 11:07 AM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
It is a small block 727 with the bracket for a console shifter.
The last photo shown has the starter lump visible. A keen eye will note the sharp corner on the lump. B/RB provisions were rounded there.
- Stu Harmon
Re: Can someone ID this trans for me? [Re: plazomat] #2681241
07/25/19 12:37 PM
07/25/19 12:37 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The stamped VIN 2Fxxxxx makes it from a '72 model year Dart or Valiant built at the Newark plant.
Re: Can someone ID this trans for me? [Re: John_Kunkel] #2681248
07/25/19 12:54 PM
07/25/19 12:54 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
1972 model year production at Newark (2F) was all C-body
127,790 Plymouth Fury & 61,305 Dodge Polara/Monaco
Re: Can someone ID this trans for me? [Re: 6bblgt] #2681249
07/25/19 12:59 PM
07/25/19 12:59 PM
Ontario, Canada
GVH Offline
GVH  Offline
Ontario, Canada
Trans will work you will need a drive shaft
Re: Can someone ID this trans for me? [Re: GVH] #2681414
07/25/19 09:23 PM
07/25/19 09:23 PM
plazomat Offline OP
plazomat  Offline OP
Hi Guys,
I got the seller to snap a few more for me...
PN PK3515844 3615 0758 - hunting the google looks like a late 1971/72 trans - behind a 360 engine - small block 727..........standard(& police/taxi 318)
I think exactly what I am looking for - are these stronger/better than the pre 1972 variants.
."a longer bushing was introduced into the 727 front clutch retainer which necessitated changing the clutch retainers, the reaction shaft support, the cast iron seal rings, the rear clutch piston retainer and the transmission assembly numbers"
Plaz
Re: Can someone ID this trans for me? [Re: plazomat] #2681470
07/26/19 02:11 AM
07/26/19 02:11 AM
TN
1DGEMAN Offline
1DGEMAN  Offline
TN
Why not rebuild your 904? It is more than strong enough. Every smallblock Stock and super Stock car runs them and some guys have adapted the 904 guts to the 727 case for big blocks. If you put the 727 in your car you will also need a drive shaft and i think converter.
Real Men shift for themselves
