545rfe pan gasket #2676342
07/10/19 05:13 PM
07/10/19 05:13 PM
Grand Prairie,Texas
stumpy Offline OP
stumpy  Offline OP
Grand Prairie,Texas
Does Mopar make a sandwich style pan gasket for the 545rfe like the one for the 518a?
Re: 545rfe pan gasket [Re: stumpy] #2676345
07/10/19 05:30 PM
07/10/19 05:30 PM
Guitar Jones Online laugh2
I thought they were just RTV, no gasket.
'74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon!
Re: 545rfe pan gasket [Re: Guitar Jones] #2676349
07/10/19 05:39 PM
07/10/19 05:39 PM
Grand Prairie,Texas
stumpy Offline OP
stumpy  Offline OP
Grand Prairie,Texas
Parts house filter kit comess with a gasket. The issue is trying to get the pan in place without screwing up the RTV. It's a tight fit on my Grand Cherokee.
Re: 545rfe pan gasket [Re: stumpy] #2676357
07/10/19 06:22 PM
07/10/19 06:22 PM
Oh yeah, I remember them. That parts house gasket will probably leak though.
Re: 545rfe pan gasket [Re: Guitar Jones] #2676365
07/10/19 06:43 PM
07/10/19 06:43 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
No less than 6 choices at Rockauto, none Mopar though.
Re: 545rfe pan gasket [Re: Guitar Jones] #2676366
07/10/19 06:45 PM
07/10/19 06:45 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Originally Posted by Guitar Jones
Oh yeah, I remember them. That parts house gasket will leak though.
fixed
Re: 545rfe pan gasket [Re: Guitar Jones] #2676401
07/10/19 08:55 PM
07/10/19 08:55 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
I have done both the gasket and the RTV. Both sealed up without a single drip.
332,000 miles and several trans filter and fluid services with zero problems.
Re: 545rfe pan gasket [Re: Kern Dog] #2676434
07/10/19 11:01 PM
07/10/19 11:01 PM
Southeast Pa.
SALEM1912 Offline
SALEM1912  Offline
Southeast Pa.
I'd use the RTV mopar forget the pn# should be a 41 on it.
Re: 545rfe pan gasket [Re: SALEM1912] #2676442
07/10/19 11:23 PM
07/10/19 11:23 PM
Grand Prairie,Texas
stumpy Offline OP
stumpy  Offline OP
Grand Prairie,Texas
I really liked the 518 gasket and was hoping for one to fit my trans.
Re: 545rfe pan gasket [Re: SALEM1912] #2676497
07/11/19 08:39 AM
07/11/19 08:39 AM
nowhere
Sniper Offline
Sniper  Offline
nowhere
OP says this
Quote
Parts house filter kit comes with a gasket. The issue is trying to get the pan in place without screwing up the RTV. It's a tight fit on my Grand Cherokee.
You say this
Not real helpful.
Unfortunately it doesn't appear they make the steel reinforced rubber gasket for this trans.
What I like to do is clean the pan real good, use a spray gasket adhesive to glue the gasket to the pan and bolt it up. Alternatively, you can skip the glue and use thread to tie the gasket to the pan, I tie it to each hole and it works pretty good with no glued on gasket mess to clean up next time.
Re: 545rfe pan gasket [Re: Sniper] #2676550
07/11/19 12:05 PM
07/11/19 12:05 PM
Grand Prairie,Texas
stumpy Offline OP
stumpy  Offline OP
Grand Prairie,Texas
That thread thing is an interesting idea. Thanks. up
Re: 545rfe pan gasket [Re: stumpy] #2676628
07/11/19 06:13 PM
07/11/19 06:13 PM
It's old, old school. Even before my time.
Re: 545rfe pan gasket [Re: Guitar Jones] #2676632
07/11/19 06:27 PM
07/11/19 06:27 PM
Grand Prairie,Texas
stumpy Offline OP
stumpy  Offline OP
Grand Prairie,Texas
I'm really old and this is the first time I've heard of it. I guess I just didn't pay attention. Sure would have made some oil pan replacements a lot easier.
Re: 545rfe pan gasket [Re: stumpy] #2676659
07/11/19 09:00 PM
07/11/19 09:00 PM
Southeast Pa.
SALEM1912 Offline
SALEM1912  Offline
Southeast Pa.
Would still use Mopar sealant like what it came with https://www.ebay.com/p/Mopar-OEM-Tr...eqpau4wIVxlcNCh1JEw5vEAQYAyABEgJERvD_BwE Don't know how that's not helpful?
Also be careful changing the filter, make sure it is in the rubber seal properly. Source of a lot of problems if not seated tight. Don't change the seal it's not required even if they give you one in the kit.
Re: 545rfe pan gasket [Re: stumpy] #2676661
07/11/19 09:10 PM
07/11/19 09:10 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
My very personal rule of thought is.
if it came with sealer that's how i put it back together.
If designed for a gasket , same thing . That's how I put it together.
Ive had far far to many pans originally designed for RTV come to me leaking , low and behold they have a gasket on it.
Re: 545rfe pan gasket [Re: stumpy] #2677065
07/13/19 01:22 PM
07/13/19 01:22 PM
moparx Offline
moparx  Offline
i'm really old as well, and have used thread forever for a lot of things as an "extra hand" as sorts.
on restorations however, use the correct thread "color", so as to not get dinged on judging points. biggrin
beer
