Re: 545rfe pan gasket
[Re: stumpy]
#2676345
07/10/19 05:30 PM
07/10/19 05:30 PM
Guitar Jones
I thought they were just RTV, no gasket.
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon! 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
[Re: stumpy]
#2676357
07/10/19 06:22 PM
07/10/19 06:22 PM
Guitar Jones
Oh yeah, I remember them. That parts house gasket will probably leak though.
[Re: Guitar Jones]
#2676401
07/10/19 08:55 PM
07/10/19 08:55 PM
Posts: 18,493 Granite Bay CA
Kern Dog
Striving for excellence
Granite Bay CA
Oh yeah, I remember them. That parts house gasket will probably leak though. I have done both the gasket and the RTV. Both sealed up without a single drip. 332,000 miles and several trans filter and fluid services with zero problems.
[Re: SALEM1912]
#2676497
07/11/19 08:39 AM
07/11/19 08:39 AM
Posts: 6,241 nowhere
Sniper
nowhere
OP says this Parts house filter kit comes with a gasket. The issue is trying to get the pan in place without screwing up the RTV. It's a tight fit on my Grand Cherokee. You say this I'd use the RTV mopar forget the pn# should be a 41 on it. Not real helpful. Unfortunately it doesn't appear they make the steel reinforced rubber gasket for this trans. What I like to do is clean the pan real good, use a spray gasket adhesive to glue the gasket to the pan and bolt it up. Alternatively, you can skip the glue and use thread to tie the gasket to the pan, I tie it to each hole and it works pretty good with no glued on gasket mess to clean up next time.
[Re: stumpy]
#2676628
07/11/19 06:13 PM
07/11/19 06:13 PM
Guitar Jones
That thread thing is an interesting idea. Thanks. It's old, old school. Even before my time.
