Re: 545rfe pan gasket
[Re: stumpy]
#2676345
07/10/19 05:30 PM
07/10/19 05:30 PM
Posts: 20,662 in a cattle trailer down by th...
Guitar Jones
I thought they were just RTV, no gasket.
[Re: stumpy]
#2676357
07/10/19 06:22 PM
07/10/19 06:22 PM
Guitar Jones
Oh yeah, I remember them. That parts house gasket will probably leak though.
[Re: Guitar Jones]
#2676401
07/10/19 08:55 PM
07/10/19 08:55 PM
Posts: 18,493 Granite Bay CA
Kern Dog
Striving for excellence
Granite Bay CA
Oh yeah, I remember them. That parts house gasket will probably leak though. I have done both the gasket and the RTV. Both sealed up without a single drip. 332,000 miles and several trans filter and fluid services with zero problems.
[Re: SALEM1912]
#2676497
07/11/19 08:39 AM
07/11/19 08:39 AM
Posts: 6,309 nowhere
Sniper
nowhere
OP says this Parts house filter kit comes with a gasket. The issue is trying to get the pan in place without screwing up the RTV. It's a tight fit on my Grand Cherokee. You say this I'd use the RTV mopar forget the pn# should be a 41 on it. Not real helpful. Unfortunately it doesn't appear they make the steel reinforced rubber gasket for this trans. What I like to do is clean the pan real good, use a spray gasket adhesive to glue the gasket to the pan and bolt it up. Alternatively, you can skip the glue and use thread to tie the gasket to the pan, I tie it to each hole and it works pretty good with no glued on gasket mess to clean up next time.
[Re: stumpy]
#2676628
07/11/19 06:13 PM
07/11/19 06:13 PM
Guitar Jones
That thread thing is an interesting idea. Thanks. It's old, old school. Even before my time.
