Plug Wires - Looking for Suggestion #2672555
07/01/19 01:49 PM
07/01/19 01:49 PM
O
oldjonny Offline OP
Don't argue with me.
oldjonny  Offline OP
O
I have tried two different sets of "Custom" fit wires for my 1966 361. I have resigned myself to just having to make a set as the "Custom" ones all fit like garbage. So, whose wire sets are actually any good anymore? Nothing HP about the car, just want a set of wires that does not fit like junk.
Never, ever argue with an IDIOT. They will drag you to their level and then beat you with their years of experience
Re: Plug Wires - Looking for Suggestion [Re: oldjonny] #2672656
07/01/19 05:57 PM
07/01/19 05:57 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Lots of guys here swear by the Firecore wire sets, and judging by their photos, they're spot on.
Budget/non-OEM would be whatever low-resistance cut-your-own sets from Summit, Jeg's, etc.
For that kind of thing I usually get Accel or Taylor.
Re: Plug Wires - Looking for Suggestion [Re: oldjonny] #2672667
07/01/19 06:10 PM
07/01/19 06:10 PM
tennessee
P
pushbutton Offline
pushbutton  Offline
P
tennessee
Firecores fit fine on my 69 RR with stock exh manifolds. Wires may route different on a 66 if they have end drop manifolds.
Re: Plug Wires - Looking for Suggestion [Re: pushbutton] #2672706
07/01/19 07:40 PM
07/01/19 07:40 PM
WA
tman Offline
tman  Offline
WA
I like my Firecore set for stock 440-6. I got the stock looking version 7mm.
Re: Plug Wires - Looking for Suggestion [Re: tman] #2672749
07/01/19 09:02 PM
07/01/19 09:02 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
I put a set of firecore wires on a stock 383 in a 1966 coronet. wasnt impressed. My opinion only btw
Best fitting wires Ive found yet for factory made appearance has been htps://www.lectriclimited.com/spark-plug-wire-sets
Re: Plug Wires - Looking for Suggestion [Re: gtx6970] #2672903
07/02/19 09:17 AM
07/02/19 09:17 AM
md
mopars4ever Offline
mopars4ever  Offline
md
I have always used the cut to fit wires. Takes a little more time but I dislike messy looking plug wires.
Re: Plug Wires - Looking for Suggestion [Re: mopars4ever] #2673056
07/02/19 02:11 PM
07/02/19 02:11 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
i buy the components separate and make my own. everything fits like it's supposed to and I don't jump thru a bunch of hoops with vendors.
