65 Satellite Bracket car #2667640
06/19/19 04:13 PM
06/19/19 04:13 PM
South Texas
Duanehydro Offline OP
South Texas
Thank you for adding me to the group. needing some help with parts, direction and such..chevy/ford guy building a roller 440 wedge...lol. Pulling engine tomorrow for teardown. Any and all help will be greatly appreciated!! Thanks!
Re: 65 Satellite Bracket car [Re: Duanehydro] #2668015
06/20/19 02:20 PM
06/20/19 02:20 PM
ohio
67mprfan Offline
67mprfan  Offline
ohio
What parts do you have now and how fast do you want to go...any more information about the intentions would help with planning and building..... nice looking car BTW
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it.
67 Belvedere that worked it's way in the 10's
Re: 65 Satellite Bracket car [Re: 67mprfan] #2668046
06/20/19 04:45 PM
06/20/19 04:45 PM
South Texas
South Texas
I just lost 2 paragraphs...Looking for help on advice for making 3780# go 10.35 again, or faster. I have the engine on the stand. currently a 252/258/ .630/.630 with 1.5 ratio. Solid roller ported 915's. this engine was taken in trade from a guy that ran it in "pinks". We have no baseline with this engine. Thanks for helping out. Been building engines for 40 years, just not many rb engines..
64829379_2251247665137520_4061834985114435584_o.jpg64557027_2252072535055033_1634544791989518336_o.jpg
Re: 65 Satellite Bracket car [Re: Duanehydro] #2668051
06/20/19 04:58 PM
06/20/19 04:58 PM
South Texas
South Texas
Pistons in the hole .005 average. KB Claimer hyper pistons...They claim 11.5 with this head. If we are running 108, why not go to 12.5-13 to 1?
Re: 65 Satellite Bracket car [Re: Duanehydro] #2668053
06/20/19 05:00 PM
06/20/19 05:00 PM
South Texas
South Texas
My Normal work is on Jet boats, so cut me a little slack, guys.
Re: 65 Satellite Bracket car [Re: Duanehydro] #2668069
06/20/19 05:47 PM
06/20/19 05:47 PM
ohio
67mprfan Offline
67mprfan  Offline
ohio
What rear gears and what type of transmission type of suspension is under it. I only ask because with the weight of the car might be a little tuff with steel heads, what intake and carb was on there.
Re: 65 Satellite Bracket car [Re: 67mprfan] #2668074
06/20/19 05:51 PM
06/20/19 05:51 PM
South Texas
South Texas
He's ready to replace heads with aluminum. not sure which ones yet, seems all will require different rockers?
Re: 65 Satellite Bracket car [Re: Duanehydro] #2668075
06/20/19 05:52 PM
06/20/19 05:52 PM
South Texas
South Texas
sorry, 4.88, 31 13" tires 4500 stall, fresh trans 727.
Re: 65 Satellite Bracket car [Re: Duanehydro] #2668076
06/20/19 05:55 PM
06/20/19 05:55 PM
South Texas
South Texas
leaf springs, and torsion bars. fenderwells cut out, cage tied to a-arm supports. weiand team g 4150 flange, with work done, smoothed adapter and 1050 dominator 9375
Re: 65 Satellite Bracket car [Re: Duanehydro] #2668106
06/20/19 07:29 PM
06/20/19 07:29 PM
ohio
67mprfan Offline
67mprfan  Offline
ohio
Trick flow seems to be the best bang for the buck and I believe you can still use the rockerarms that are in the picture.... might try to move this thread to the racer section alot of helpful people on there. Is this a stock stroke motor?
Re: 65 Satellite Bracket car [Re: 67mprfan] #2671354
06/28/19 10:56 PM
06/28/19 10:56 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Get some good-flowing Alum heads to feed it. 108 octane should be OK with 12.5:1, I run 110 with 13.0:1 & alum heads, just watch total timing.
Pay particular attention to setting up the rocker/spring geometry.
Also check the Tech Archives here, as there are several 440 recipes - look at the very top tool bar on the right.
Re: 65 Satellite Bracket car [Re: topside] #2671742
06/29/19 10:44 PM
06/29/19 10:44 PM
God's Country Maryland
GODSCOUNTRY340 Offline
The 915 heads are great heads with 2.14/1.81 valves. Dump that Team G intake and use an Edelbrock Victor 440. We run a similar set up but run a Crane roller cam with .700/.718 lift, 12.8 compression. 3,000 pound Dart runs 10.03/131 mph using old iron rockers and a 1050 carb. We ported the heads to the point of nearly running out of metal on the valley tray at the ports, just use paper gaskets along with the valley tray. You can cut some of the paper gaskets away too.
