Re: 65 Satellite Bracket car
[Re: Duanehydro]
#2668015
06/20/19 02:20 PM
06/20/19 02:20 PM
Posts: 1,030 ohio
67mprfan
ohio
What parts do you have now and how fast do you want to go...any more information about the intentions would help with planning and building..... nice looking car BTW
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it. 67 Belvedere that worked it's way in the 10's
[Re: Duanehydro]
#2668069
06/20/19 05:47 PM
06/20/19 05:47 PM
Posts: 1,030 ohio
67mprfan
ohio
What rear gears and what type of transmission type of suspension is under it. I only ask because with the weight of the car might be a little tuff with steel heads, what intake and carb was on there.
[Re: Duanehydro]
#2668076
06/20/19 05:55 PM
06/20/19 05:55 PM
Posts: 7 South Texas
Duanehydro
South Texas
leaf springs, and torsion bars. fenderwells cut out, cage tied to a-arm supports. weiand team g 4150 flange, with work done, smoothed adapter and 1050 dominator 9375
[Re: Duanehydro]
#2668106
06/20/19 07:29 PM
06/20/19 07:29 PM
Posts: 1,030 ohio
67mprfan
ohio
He's ready to replace heads with aluminum. not sure which ones yet, seems all will require different rockers? Trick flow seems to be the best bang for the buck and I believe you can still use the rockerarms that are in the picture.... might try to move this thread to the racer section alot of helpful people on there. Is this a stock stroke motor?
[Re: topside]
#2671742
06/29/19 10:44 PM
06/29/19 10:44 PM
Posts: 2,497 God's Country Maryland
GODSCOUNTRY340
The 915 heads are great heads with 2.14/1.81 valves. Dump that Team G intake and use an Edelbrock Victor 440. We run a similar set up but run a Crane roller cam with .700/.718 lift, 12.8 compression. 3,000 pound Dart runs 10.03/131 mph using old iron rockers and a 1050 carb. We ported the heads to the point of nearly running out of metal on the valley tray at the ports, just use paper gaskets along with the valley tray. You can cut some of the paper gaskets away too.
