Re: Competition engineering drag shocks? How do you like them ??
[Re: RAY1969CARS]
#2666348
06/15/19 11:41 PM
06/15/19 11:41 PM
Posts: 4,672 Wichita
GY3
Wichita
I bought some lightly used 3 way adjustable CE's. I put them on the 90/10 setting and leave them there all the time street or strip. They seem to work fine for my level of performance. As I recall they were a little confusing on the adjustment markings and opposite of what they should have been.
[Re: GY3]
#2666393
06/16/19 08:21 AM
06/16/19 08:21 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
I bought some lightly used 3 way adjustable CE's. I put them on the 90/10 setting and leave them there all the time street or strip. They seem to work fine for my level of performance. As I recall they were a little confusing on the adjustment markings and opposite of what they should have been. Same for me as I put them on the 90/10 setting and leave them there. And mine is a street/strip car also. Drives and handles fine. And works ok at the track. Ron
[Re: 67_Satellite]
#2666590
06/16/19 05:39 PM
06/16/19 05:39 PM
Posts: 1,145 Arizona, USA
gsmopar
Arizona, USA
Same set up here. Got a pair for $10(yes $10) at the Indy swap meet a few years back. One wouldn't adjust, but was set on 90/10, so I set the other one there and it works fine. Better than the old "loose" stock shocks I had on there before. I sold a set that were on my car for>10 Year’s for $10 not too long ago. Internet deal, not the ones you bought. Ya! Pain in the butt to adjust. Set them on 90/10 and left them that way.
[Re: Cab_Burge]
#2666763
06/17/19 09:16 AM
06/17/19 09:16 AM
Posts: 13,360 Marion, South Carolina [><]
an8sec70cuda
Never cared for them. Always seemed real stiff and never could get them to adjust to the 90/10 setting...don't think so anyway.
[Re: an8sec70cuda]
#2666803
06/17/19 10:37 AM
06/17/19 10:37 AM
Posts: 1,237 North Central, Indiana
Roughbird72
They worked fine on my car for years, but that was on a 3800# car running 11s - 12s. I never had an issue with adjusting them.
72 Plymouth Roadrunner 11.08@123.25
[Re: Roughbird72]
#2666826
06/17/19 11:13 AM
06/17/19 11:13 AM
Posts: 11,711 Portage,michigan
B3422W5
Portage,michigan
It is tricky adjusting them. I ran them on all 4 corners of a S/S spring 9 sec A body for years. Worked great
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
[Re: B3422W5]
#2666859
06/17/19 11:59 AM
06/17/19 11:59 AM
Posts: 1,390 CA.
RAY1969CARS
CA.
It is tricky adjusting them. I ran them on all 4 corners of a S/S spring 9 sec A body for years. Worked great Do you remember what you adjusted the backs to?
[Re: RAY1969CARS]
#2666866
06/17/19 12:21 PM
06/17/19 12:21 PM
B3422W5
Portage,michigan
It is tricky adjusting them. I ran them on all 4 corners of a S/S spring 9 sec A body for years. Worked great Do you remember what you adjusted the backs to? I remember with the S/S springs i had the back left the loosest and back right tighter 40/60 back left, 50/50 back right. Never used the tightest setting
[Re: B3422W5]
#2667063
06/18/19 01:03 AM
06/18/19 01:03 AM
Posts: 394 Ohio
moparjoe360.4
Ohio
It is tricky adjusting them. I ran them on all 4 corners of a S/S spring 9 sec A body for years. Worked great Do you remember what you adjusted the backs to? I remember with the S/S springs i had the back left the loosest and back right tighter 40/60 back left, 50/50 back right. Never used the tightest setting The timing on this is impeccable, I just bought a set of fronts and rears off a member, got the tracking info today. Thanks to the OP for asking about them so I can learn the ins and outs as well.
