Competition engineering drag shocks? How do you like them ?? #2666345
06/15/19 10:42 PM
06/15/19 10:42 PM
CA.
RAY1969CARS Offline OP
CA.
Hi guys tell me about your Experiences and adjusting
Mopar are no car
Re: Competition engineering drag shocks? How do you like them ?? [Re: RAY1969CARS] #2666348
06/15/19 11:41 PM
06/15/19 11:41 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
I bought some lightly used 3 way adjustable CE's. I put them on the 90/10 setting and leave them there all the time street or strip. They seem to work fine for my level of performance.
As I recall they were a little confusing on the adjustment markings and opposite of what they should have been. work
'63 Dodge 330
11.19 @ 121 mph
Re: Competition engineering drag shocks? How do you like them ?? [Re: GY3] #2666363
06/16/19 01:00 AM
06/16/19 01:00 AM
Phoenix, AZ
Belvedere1 Offline
Belvedere1  Offline
Phoenix, AZ
I run these too but have never been clear on how to set for 90/10.
Re: Competition engineering drag shocks? How do you like them ?? [Re: GY3] #2666393
06/16/19 08:21 AM
06/16/19 08:21 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Same for me as I put them on the 90/10 setting and leave them there. And mine is a street/strip car also. Drives and handles fine. And works ok at the track. Ron
Re: Competition engineering drag shocks? How do you like them ?? [Re: 383man] #2666423
06/16/19 09:42 AM
06/16/19 09:42 AM
Andrews,In. U.S.of A.
67_Satellite Offline
Same set up here. Got a pair for $10(yes $10) at the Indy swap meet a few years back. One wouldn't adjust, but was set on 90/10, so I set the other one there and it works fine. Better than the old "loose" stock shocks I had on there before.
Re: Competition engineering drag shocks? How do you like them ?? [Re: 67_Satellite] #2666590
06/16/19 05:39 PM
06/16/19 05:39 PM
Arizona, USA
gsmopar Offline
gsmopar  Offline
Arizona, USA
I sold a set that were on my car for>10 Year’s for $10 not too long ago. Internet deal, not the ones you bought. Ya! Pain in the butt to adjust. Set them on 90/10 and left them that way.
Re: Competition engineering drag shocks? How do you like them ?? [Re: RAY1969CARS] #2666612
06/16/19 06:49 PM
06/16/19 06:49 PM
I've used several different sets on different A boy Mopar, BB and SB, automatics and stick shift.
They all worked okay BUT if your going to make big HP with marginal traction then you will need a better set of front shocks like the Koni SPA or better up twocents
Re: Competition engineering drag shocks? How do you like them ?? [Re: Cab_Burge] #2666763
06/17/19 09:16 AM
06/17/19 09:16 AM
an8sec70cuda Offline
Never cared for them. Always seemed real stiff and never could get them to adjust to the 90/10 setting...don't think so anyway.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Competition engineering drag shocks? How do you like them ?? [Re: an8sec70cuda] #2666803
06/17/19 10:37 AM
06/17/19 10:37 AM
North Central, Indiana
Roughbird72 Offline
Roughbird72  Offline
They worked fine on my car for years, but that was on a 3800# car running 11s - 12s.
I never had an issue with adjusting them. twocents
72 Plymouth Roadrunner 11.08@123.25
Re: Competition engineering drag shocks? How do you like them ?? [Re: Roughbird72] #2666826
06/17/19 11:13 AM
06/17/19 11:13 AM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
It is tricky adjusting them.
I ran them on all 4 corners of a S/S spring 9 sec A body for years. Worked great
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Competition engineering drag shocks? How do you like them ?? [Re: B3422W5] #2666859
06/17/19 11:59 AM
06/17/19 11:59 AM
CA.
CA.
Do you remember what you adjusted the backs to?
Re: Competition engineering drag shocks? How do you like them ?? [Re: RAY1969CARS] #2666866
06/17/19 12:21 PM
06/17/19 12:21 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
I remember with the S/S springs i had the back left the loosest and back right tighter
40/60 back left, 50/50 back right. Never used the tightest setting
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Competition engineering drag shocks? How do you like them ?? [Re: B3422W5] #2667063
06/18/19 01:03 AM
06/18/19 01:03 AM
Ohio
moparjoe360.4 Offline
Ohio
The timing on this is impeccable, I just bought a set of fronts and rears off a member, got the tracking info today. Thanks to the OP for asking about them so I can learn the ins and outs as well. beer
