What would you build? SB Blower max effort with these rules #2666068
06/15/19 01:04 AM
06/15/19 01:04 AM
Quebec, Canada
Diablo Offline OP
Diablo  Offline OP
Quebec, Canada
Here are the rules.
Maximum of 380cu.in. blown small block, supercharger limited to 6-71 with
18% overdrive or 8-71 with 10% overdrive, or a single turbocharger with an
input of 83mm by 130mm. ALL FORD, CHRYSLER & GM SMALL BLOCK ENGINES
ARE ALLOWED 380CI MAXIMUM AND MUST USE THE ORIGINAL DEGREE OF VALVE TRAIN
ANGLE FOR THAT SPECIFIC BLOCK. ONLY SBC STANDARD (23 DEGREE) IS ALLOWED. ALL GM
LS BLOCKS ARE NOT PERMITTED.
What would you build for mopar with these rules, max effort? Probaly can be Billet heads too. Needs to be 1200+++hp. It would be for a Mini-Mod tractor pulling class.
Re: What would you build? SB Blower max effort with these rules [Re: Diablo] #2666106
06/15/19 08:21 AM
06/15/19 08:21 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Building a second?? The one I have seen you race was INSANE eek Will it burn alcohol?? boogie
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: What would you build? SB Blower max effort with these rules [Re: hemi-itis] #2666114
06/15/19 08:57 AM
06/15/19 08:57 AM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
Is the modern hemi considered a small block?
Re: What would you build? SB Blower max effort with these rules [Re: TRENDZ] #2666137
06/15/19 10:04 AM
06/15/19 10:04 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I dont know if they consider the GEN III in the same boat as a LS but
if its legal then thats the way I'd go
wave
Re: What would you build? SB Blower max effort with these rules [Re: Diablo] #2666175
06/15/19 12:03 PM
06/15/19 12:03 PM
Cab_Burge Online work
Cab_Burge  Online Work
48 degree W motor with the best heads you can get twocents
Re: What would you build? SB Blower max effort with these rules [Re: hemi-itis] #2666186
06/15/19 01:00 PM
06/15/19 01:00 PM
Quebec, Canada
Diablo Offline OP
Diablo  Offline OP
Quebec, Canada
oh we are keeping Diablo.. This is just a side idea wink
Re: What would you build? SB Blower max effort with these rules [Re: MR_P_BODY] #2666187
06/15/19 01:06 PM
06/15/19 01:06 PM
Quebec, Canada
Diablo Offline OP
Diablo  Offline OP
Quebec, Canada
wave
From what I have been told the Gen 3 hemi is fine. Actually one person in the club is already using one with a blower.
So you think one of those would be better then trying to use some of the W or P heads?
With the way the rules are stated do you think it would be allowed to use the mopar W or P heads??
Re: What would you build? SB Blower max effort with these rules [Re: Diablo] #2666189
06/15/19 01:14 PM
06/15/19 01:14 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
If only 23* Chevy stuff is legal, I wouldn’t spend a penny of W or P stuff until I had it it writing from the rules committee it would be legal, without penalties, for at least 3 years.
Those heads are clearly outside the “intent” of the class.
I wouldn’t build anything where the big stuff(blocks, rotating assy’s, head castings, etc) wasn’t readily available.
Re: What would you build? SB Blower max effort with these rules [Re: fast68plymouth] #2666190
06/15/19 01:37 PM
06/15/19 01:37 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Re: What would you build? SB Blower max effort with these rules [Re: fast68plymouth] #2666198
06/15/19 02:09 PM
06/15/19 02:09 PM
IL
E
EchoSixMike Offline
EchoSixMike  Offline
E
IL
Talk to Goss, Gen 3 hemi with turbo, on methanol if allowed. S/F....Ken M
Re: What would you build? SB Blower max effort with these rules [Re: Diablo] #2666296
06/15/19 07:45 PM
06/15/19 07:45 PM
New York
polyspheric Offline
polyspheric  Offline
New York
He hasn't beaten anyone on the tech committee yet, "spirit of the rules" means "it's not in the rules".
Boffin Emeritus
Re: What would you build? SB Blower max effort with these rules [Re: polyspheric] #2666322
06/15/19 09:05 PM
06/15/19 09:05 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
I am laughing , but in full agreement.
Re: What would you build? SB Blower max effort with these rules [Re: fast68plymouth] #2666343
06/15/19 10:38 PM
06/15/19 10:38 PM
Quebec, Canada
Diablo Offline OP
Diablo  Offline OP
Quebec, Canada
Thinking about it a little more and you are very right. Wouldn't take long for someone to outlaw it.
Re: What would you build? SB Blower max effort with these rules [Re: polyspheric] #2666344
06/15/19 10:41 PM
06/15/19 10:41 PM
Quebec, Canada
Diablo Offline OP
Diablo  Offline OP
Quebec, Canada
You make a good point. The guy with it has a nice looking machine, but hasn't come close to winning. Same with the P/W heads I would have to make it very clear and have it in writing if they will be allowed or not. Here is a video of their first outing this year.
https://www.youtube.com/watch?v=NS2M4tUPUSY
Re: What would you build? SB Blower max effort with these rules [Re: Diablo] #2666429
06/16/19 09:53 AM
06/16/19 09:53 AM
New York
polyspheric Offline
polyspheric  Offline
New York
Not to be the wet blankie, but the LSR/SCTA site is full of "I wrote with pictures and details, and got a letter back saying it's legal, but when I got to the tech line I got failed. I took 2 weeks off, traveled 1,000 miles, and spent $$$ for nothing, but Boyd Coddington's wife does whatever she wants."
Boffin Emeritus
Re: What would you build? SB Blower max effort with these rules [Re: Diablo] #2666467
06/16/19 11:23 AM
06/16/19 11:23 AM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
Very strange the Hemi is allowed but the LS isn’t. If you’re going to do a Hemi I’d stick to junkyard parts and test the waters, just in case they pull the carpet out from underneath you. Good thing is JY parts will get you there. Buy a Hellcat short block, put some ported Eagle or Apache heads on it, whichever power added you want and see what happens.
Re: What would you build? SB Blower max effort with these rules [Re: WO23Coronet] #2666543
06/16/19 03:09 PM
06/16/19 03:09 PM
Quebec, Canada
Diablo Offline OP
Diablo  Offline OP
Quebec, Canada
So if we are all saying the W/P heads are out and there is a good chance the Gen 3 Hemi heads "will" be out...... What are the heads to go with?
Re: What would you build? SB Blower max effort with these rules [Re: Diablo] #2666565
06/16/19 04:11 PM
06/16/19 04:11 PM
So. Burlington, Vt.
So. Burlington, Vt.
Might want to see if Gen 1 stuff is legal.
I’m pretty sure everything needed is available new.
Re: What would you build? SB Blower max effort with these rules [Re: Diablo] #2666567
06/16/19 04:15 PM
06/16/19 04:15 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
Im pretty sure all P heads have non stock valve angles, and some W heads also.
I think the Brodix BA would be legal from your rules.
I agree with those that are weary of the rule change about the hemi. You seem to be very much on your game, and it wouldn’t be long before the hemi gets outlawed. My honest opinion is if they let you have a turbo hemi, no other combo could touch it.
Re: What would you build? SB Blower max effort with these rules [Re: Diablo] #2666587
06/16/19 05:32 PM
06/16/19 05:32 PM
New York
polyspheric Offline
polyspheric  Offline
New York
No centrifugal, twin screw?
Boffin Emeritus
