Where to find good motor mounts 70 B-Body #2663797
06/08/19 02:52 PM
06/08/19 02:52 PM
Chicagoland 'Burbs
SlickRS23 Offline OP
Chicagoland 'Burbs
Does anybody know where I can buy good quality motor mounts for a 1970 b body with a 440.
I picked some up from O'Reilys and ended up throwing them in the garbage after sawing the studs and realizing how cheap they were.
Looked at NAPA, and the same thing.
I picked up some Mancini Mag mounts, but they are two different thickness. Sending them back Monday.
I'm posting this in the restoration forum as I don't want no chains, straps, poly mounts or other race car solutions.
Actually, my 40 year old moogs look better then anything I can find new and I'm considering using them if I can't find a motor mount.
Would be nice to put some new mounts on before I put the engine back in.
Re: Where to find good motor mounts 70 B-Body [Re: SlickRS23] #2663948
06/09/19 08:42 AM
06/09/19 08:42 AM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
All the parts stores are the same crap. You have to saw off the studs. I’ve used the Mighty Mounts because the won’t break. You may have to cut some off the studs to keep it from hitting the block. I can’t remember. They are not cheap, for sure. Unfortunately, they don’t fit the k member any better than the cheap repops. You have to grind down the part that sits on the k frame or it will not sit flat and you can’t get the bolt in place. It’s not a fun lesson when you get to the end and then realize you have to start over. Fit the mount to the k member first. It’s sad that most repop parts now are close enough to use but not a direct easy fit. It’s like they do it on purpose. I installed a set a “Metro” door panels on a Challenger the other day and as good as they are, they still have shortcomings. They are too short at the front of the door and don’t line up with the top screw very well.
Re: Where to find good motor mounts 70 B-Body [Re: fastmark] #2663988
06/09/19 11:03 AM
06/09/19 11:03 AM
69x Offline
69x  Offline
I think you mean Mity Mounts, not Mighty Mounts
Re: Where to find good motor mounts 70 B-Body [Re: 69x] #2664036
06/09/19 01:56 PM
06/09/19 01:56 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Last couple times I needed them
I've been lucky enough and been able to find NOS
Last set was just maybe 3 years ago
Re: Where to find good motor mounts 70 B-Body [Re: SlickRS23] #2664042
06/09/19 02:05 PM
06/09/19 02:05 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
USED/NOS is your only choice if you wish to narrow your field....
I have the Schumacher Poly Loc mounts, about as close to factory as your going to get from an aftermarket source, plus they have an interlock feature to prevent them from tearing in half...they've been in my 70 440/6 Charger for 14 years...ZERO issues
Re: Where to find good motor mounts 70 B-Body [Re: SlickRS23] #2664190
06/09/19 10:41 PM
06/09/19 10:41 PM
Chicagoland 'Burbs
Chicagoland 'Burbs
I don't think these new motor mounts at O'Reilys, Napa or other stores even meet manufactures specifications.
and they call these OEM replacement parts, I can see a repop part not working, but an OEM?
These new mounts have to have the studs shortened so they don't put a hole in the block,
and the rubber is way too soft as I could probably pull them apart easily if I wanted to.
I purchased a set at the local parts store for less then $7.00 each. If I remember correctly, Moogs used to cost about $15. to $20 each 40 years ago.
I don't mind paying for a quality part. especially when a failure could result in a damaged hood, air cleaner, fan shroud or radiator.
Maybe I will just use my 40 year old Moogs.
I've heard the Poly mounts and the so called "Bolt Thru" mounts cause a lot of vibration for a street driven restoration.
Re: Where to find good motor mounts 70 B-Body [Re: SlickRS23] #2664226
06/10/19 12:57 AM
06/10/19 12:57 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
As I mentioned above I have the Poly Locs from Schumacher and I would venture to say no more vibration than factory rubber mounts....no fitment issues either, bolted on and fit like factory pcs....
Re: Where to find good motor mounts 70 B-Body [Re: DAYCLONA] #2664296
06/10/19 09:39 AM
06/10/19 09:39 AM
Sobieski Wi
bee1971 Offline
bee1971  Offline
Sobieski Wi
Only one I was concerned about was the drivers side on my 383/432 Stroker
Did it at work with a drill press
Two summers now
Cheap Anchor motor mounts from OReillys
Zero Zero Zero Vibration
1971 Dodge Charger Superbee
2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded
Siberian Huskies
Re: Where to find good motor mounts 70 B-Body [Re: bee1971] #2664416
06/10/19 02:13 PM
06/10/19 02:13 PM
Chicagoland 'Burbs
Chicagoland 'Burbs
Two summers now
Thanks for the pics. This might be the way to go.
I see you assembled them, then drilled thru the mount and the bracket.
Probably the easiest and cheapest.
Re: Where to find good motor mounts 70 B-Body [Re: bee1971] #2664418
06/10/19 02:14 PM
06/10/19 02:14 PM
SE PA.
Q
QuickBpBp Offline
QuickBpBp  Offline
Q
SE PA.
May I ask what are NOS ones selling for these days? Never see any around..
Re: Where to find good motor mounts 70 B-Body [Re: bee1971] #2664425
06/10/19 02:29 PM
06/10/19 02:29 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
My mounts are NOS, made in USA, TRW branded replacements from the '80s.
I realize this is the resto area, but many restored cars are also packing more heat than stock...so maybe this is worth bringing up....
I've addressed the left mount as most everyone else has.
What have you done to address the right mount from being smashed downward? Does anyone care?
Look how the bottom of the oil pan is not quite parallel to the K member....this is pretty common...
Most seem to let it go but I'm not too happy to watch it happening, and am going to a motor plate to stop it.
Rich H.
Esse Quam Videri
Re: Where to find good motor mounts 70 B-Body [Re: ZIPPY] #2664460
06/10/19 04:23 PM
06/10/19 04:23 PM
Harriman NY
71GTX471 Offline
71GTX471  Offline
Harriman NY
[quote=ZIPPY]My mounts are NOS, made in USA, TRW branded replacements from the '80s.
I've been buying these off ebay for a couple of years now & have managed to assemble 4 sets.
Re: Where to find good motor mounts 70 B-Body [Re: SlickRS23] #2664462
06/10/19 04:29 PM
06/10/19 04:29 PM
Sobieski Wi
bee1971 Offline
bee1971  Offline
Sobieski Wi
Two summers now
Yes
If you decide to buy from your local jobbers
Take them out of the box first before walking out
Look at where the nut is welded to the mount etc
I must have had ten in my hand before picking two that I was happy with from different jobbers
Then Ace Hardware for that countersunk grade 8 bolt etc.
So far so good
Siberian Huskies
Re: Where to find good motor mounts 70 B-Body [Re: 71GTX471] #2664465
06/10/19 04:33 PM
06/10/19 04:33 PM
Sobieski Wi
bee1971 Offline
bee1971  Offline
Sobieski Wi
But of course when I was looking a few years back
None to bee found
Dug deep at Mopars In The Park also , nothing
Siberian Huskies
Re: Where to find good motor mounts 70 B-Body [Re: QuickBpBp] #2664509
06/10/19 06:53 PM
06/10/19 06:53 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
last set I bought ( keep in mind its been a few years now ) and I think I paid $50 for the pair
Re: Where to find good motor mounts 70 B-Body [Re: gtx6970] #2664522
06/10/19 08:19 PM
06/10/19 08:19 PM
SE PA.
Q
QuickBpBp Offline
QuickBpBp  Offline
Q
SE PA.
IMO that's a steal. I would think $100-125pr for real nice Nos ones... especially with the cheap ones made nowadays that are useless unless you never hit the gas pedal...
Re: Where to find good motor mounts 70 B-Body [Re: QuickBpBp] #2667006
06/17/19 08:41 PM
06/17/19 08:41 PM
ohio
ruderunner Offline
ruderunner  Offline
ohio
I've been running a set of solid mounts for a couple decades. No vibration problem for me, but it's a well balanced engine.
Angry white pureblood male
Re: Where to find good motor mounts 70 B-Body [Re: ruderunner] #2667048
06/17/19 10:39 PM
06/17/19 10:39 PM
Iowa
ratroaster Offline
ratroaster  Offline
Iowa
Re: Where to find good motor mounts 70 B-Body [Re: ratroaster] #2667073
06/18/19 02:36 AM
06/18/19 02:36 AM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
Originally Posted by ratroaster
That's exactly what I did on the left side engine mount on Kayse's 69 383 Dart GTS.
Two bolts through it with lock nuts and you really can't see that it's been done.
No future broken mount and no vibration.
Just a stock style new mount on the right side, engine sits level. up
Re: Where to find good motor mounts 70 B-Body [Re: SNK-EYZ] #2667147
06/18/19 10:50 AM
06/18/19 10:50 AM
Ohio
jlatessa Online content
jlatessa  Online Content
Ohio
I did the same mod as SNK-EYZ, easy and effective.(and cheap!)
Joe
