Dana 60; Pro Gears or Standard? #2657081
05/19/19 11:11 PM
05/19/19 11:11 PM
Maryland
Dads426 Offline OP
Dads426  Offline OP
Maryland
First race of the season, got down to 6 cars, won the round, but after that run Kevin noticed some clunking on the return road. Listen to it and I said ring gear is missing a few teeth. Sure enough, 2-1/2 were gone. I installed these standard Richmond 4.10 gears 10 years ago, and after a few hundred runs they decided to let go. Granted, the car was going 10.30's on bias tires at the start, now its going 9.90's on radials (switched to radials last year). Car is a 64 Dodge Polara, NSS, 493 RB motor, about 720 HP, 727 footbrake trans, 4200 stall, weighs about 3600 w/ driver, 1.39-1.40 60ft. So, go with Pro Gears or the regular street gears? Thoughts?
2012 422 Allstars NSS Champion
2013 422 Allstars NSS Champion
2014 422 Allstars NSS Champion
Re: Dana 60; Pro Gears or Standard? [Re: Dads426] #2657083
05/19/19 11:15 PM
05/19/19 11:15 PM
I would put a new set of Dana Corp. gears in it if you can find a set up twocents
If not maybe a good used set of OEM Dana 4.10 work
I'm thinking no one makes a Pro 4.10 gear, correct? shruggy
Re: Dana 60; Pro Gears or Standard? [Re: Cab_Burge] #2657087
05/19/19 11:32 PM
05/19/19 11:32 PM
Fulton County, PA
CMcAllister Online content
Mr. Helpful
CMcAllister  Online Content
Mr. Helpful
Fulton County, PA
Motive, US Gear and Richmond show a 4.10 pro gear. Don't know if I'd use a Richmond though.
Re: Dana 60; Pro Gears or Standard? [Re: Dads426] #2657120
05/20/19 06:52 AM
05/20/19 06:52 AM
PA
Harry's Taxi 2 Offline
PA
It does look like pro gears would be a good idea.
If you do go to pro gears and keep the same 4.10 ratio, you'll need the spool that's normally used for 4.56 and lower gears.
'86 Maple Grove KOS Mopar low qualifier......true street legal with no power adders.
NOS-used when losing since 1940.
Re: Dana 60; Pro Gears or Standard? [Re: Harry's Taxi 2] #2657142
05/20/19 08:53 AM
05/20/19 08:53 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I ran a standard Motive 4.10 in mine. Bent a tooth at 425 passes. Bought an offshore 4.30, 125 passes broke pinion teeth. Foot brake mid 1.2x 60ft. Now it has a US gear pro 4.30. Pro gears take a 5 series spool instead of a 3 series normally used with a 4.10.
Doug
Re: Dana 60; Pro Gears or Standard? [Re: dvw] #2657201
05/20/19 11:39 AM
05/20/19 11:39 AM
Fulton County, PA
Mr. Helpful
Mr. Helpful
Fulton County, PA
A few hundred runs on that old street gear - they don't owe you anything. I would be fine with a Motive or US Gear. What I've seen the last few years, Richmond would not be a good choice.
Re: Dana 60; Pro Gears or Standard? [Re: CMcAllister] #2657286
05/20/19 06:19 PM
05/20/19 06:19 PM
Maryland
Dads426 Offline OP
Dads426  Offline OP
Maryland
Thanks for the replies. I'll look for a US Pro gear. We are already running the series 5 carrier.
Re: Dana 60; Pro Gears or Standard? [Re: Dads426] #2657312
05/20/19 07:47 PM
05/20/19 07:47 PM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
Nice pattern on those gears, they didn't fail from a bad setup that's for sure.
Just mentioning what you probably already know, but might want to have a look at the tranny sprag. Last time i broke gears it got my sprag too.
Re: Dana 60; Pro Gears or Standard? [Re: dthemi] #2657322
05/20/19 08:15 PM
05/20/19 08:15 PM
Maryland
Dads426 Offline OP
Dads426  Offline OP
Maryland
Gears never failed completely during the run. Actually won the round; heard some noise on return road. Tranny has a LBA valve body and 16 element sprag.
Re: Dana 60; Pro Gears or Standard? [Re: Cab_Burge] #2657755
05/21/19 08:57 PM
05/21/19 08:57 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
iagree I'm not at your power level but my stick car hits the tires hard and my car weighs a tick under 3600# I used a 3.54 Dana gear for almost 200 passes and they were used when I installed them. I took them out to install a set of used Dana/Eaton 4.10 gears and they had a nice pattern and are quiet so I will give them a whoopin this summer and see what happens.
Gus beer
64 Plymouth Savoy
Dana 60
Re: Dana 60; Pro Gears or Standard? [Re: fourgearsavoy] #2657767
05/21/19 09:50 PM
05/21/19 09:50 PM
Youngstown
Vincenzo Offline
Vincenzo  Offline
Youngstown
I remember Nick Wilson (compu-flow) told me his 64 Plymouth had a used 4.10 from a pickup. Nick ran 9.40's @ 3600lbs. And he was never easy on it. RIP Nick
Woodruff Carburetor Specialties
330-799-9479
Re: Dana 60; Pro Gears or Standard? [Re: Vincenzo] #2657788
05/21/19 10:38 PM
05/21/19 10:38 PM
Rittman Ohio
Rittman Ohio
Nick on the bumper up https://www.youtube.com/watch?v=jTdwZLrstPk
Sure do miss that guy frown
Gus beer
64 Plymouth Savoy
Dana 60
