Dana 60; Pro Gears or Standard?
#2657081
05/19/19 11:11 PM
05/19/19 11:11 PM
Posts: 1,443 Maryland
Dads426
Maryland
First race of the season, got down to 6 cars, won the round, but after that run Kevin noticed some clunking on the return road. Listen to it and I said ring gear is missing a few teeth. Sure enough, 2-1/2 were gone. I installed these standard Richmond 4.10 gears 10 years ago, and after a few hundred runs they decided to let go. Granted, the car was going 10.30's on bias tires at the start, now its going 9.90's on radials (switched to radials last year). Car is a 64 Dodge Polara, NSS, 493 RB motor, about 720 HP, 727 footbrake trans, 4200 stall, weighs about 3600 w/ driver, 1.39-1.40 60ft. So, go with Pro Gears or the regular street gears? Thoughts?
2012 422 Allstars NSS Champion 2013 422 Allstars NSS Champion 2014 422 Allstars NSS Champion
Re: Dana 60; Pro Gears or Standard?
[Re: Cab_Burge]
#2657087
05/19/19 11:32 PM
05/19/19 11:32 PM
Posts: 11,621 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Motive, US Gear and Richmond show a 4.10 pro gear. Don't know if I'd use a Richmond though.
[Re: Dads426]
#2657120
05/20/19 06:52 AM
05/20/19 06:52 AM
Posts: 288 PA
Harry's Taxi 2
PA
It does look like pro gears would be a good idea.
If you do go to pro gears and keep the same 4.10 ratio, you'll need the spool that's normally used for 4.56 and lower gears.
'86 Maple Grove KOS Mopar low qualifier......true street legal with no power adders.
NOS-used when losing since 1940.
[Re: dvw]
#2657201
05/20/19 11:39 AM
05/20/19 11:39 AM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
A few hundred runs on that old street gear - they don't owe you anything. I would be fine with a Motive or US Gear. What I've seen the last few years, Richmond would not be a good choice.
[Re: CMcAllister]
#2657286
05/20/19 06:19 PM
05/20/19 06:19 PM
Dads426
Maryland
Thanks for the replies. I'll look for a US Pro gear. We are already running the series 5 carrier.
[Re: dthemi]
#2657322
05/20/19 08:15 PM
05/20/19 08:15 PM
Dads426
Maryland
Nice pattern on those gears, they didn't fail from a bad setup that's for sure.
Just mentioning what you probably already know, but might want to have a look at the tranny sprag. Last time i broke gears it got my sprag too. Gears never failed completely during the run. Actually won the round; heard some noise on return road. Tranny has a LBA valve body and 16 element sprag.
[Re: fourgearsavoy]
#2657767
05/21/19 09:50 PM
05/21/19 09:50 PM
Posts: 44 Youngstown
Vincenzo
Youngstown
I remember Nick Wilson (compu-flow) told me his 64 Plymouth had a used 4.10 from a pickup. Nick ran 9.40's @ 3600lbs. And he was never easy on it. RIP Nick
Woodruff Carburetor Specialties 330-799-9479
[Re: Vincenzo]
#2657788
05/21/19 10:38 PM
05/21/19 10:38 PM
Posts: 10,555 Rittman Ohio
fourgearsavoy
Rittman Ohio
I remember Nick Wilson (compu-flow) told me his 64 Plymouth had a used 4.10 from a pickup. Nick ran 9.40's @ 3600lbs. And he was never easy on it. RIP Nick Nick on the bumper https://www.youtube.com/watch?v=jTdwZLrstPkSure do miss that guy Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
