Brake switch adjustment #2656878
05/19/19 01:37 PM
05/19/19 01:37 PM
robertop Offline OP
robertop  Offline OP
One more question,guys: how to adjust the little brake light switch that is near the top of the brake pedal in a 69 Runner? Right now it's too lose so, when the brake pedal is at rest, the rear brake lights still are on with the engine off. Thank you! P.S. It seems easy, but the thing appears rather fragile, so I don't want to damage it needlessly without knowing exactly how to do it.
Re: Brake switch adjustment [Re: robertop] #2656886
05/19/19 01:55 PM
05/19/19 01:55 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Should be a bolt holding the switch bracket, just loosen and move it. Are your brakes adjusted correctly? If they aren't the pedal could be too low which could cause your switch issue.
Re: Brake switch adjustment [Re: stumpy] #2656984
05/19/19 07:08 PM
05/19/19 07:08 PM
robertop Offline OP
robertop  Offline OP
Okay, good point. I changed the pads and the rear drums and adjusted them manually. I need to drive backwards and pump the brakes until they are properly adjusted. Thanks for the advice on the brake switch.
Re: Brake switch adjustment [Re: stumpy] #2656990
05/19/19 07:21 PM
05/19/19 07:21 PM
GMP440 Offline
GMP440  Offline
Or you could get the heavy duty white switch that screws into that hole. That one is adjustable. Had the same problem as you years ago with the press on switch. It would never disingage.
I switched to the screw on version and never had a problem again.
Re: Brake switch adjustment [Re: GMP440] #2657044
05/19/19 09:43 PM
05/19/19 09:43 PM
Mobile Al
hemirdrnnr Offline
hemirdrnnr  Offline
Mobile Al
white switch that screws / Do you have a part # for that switch?
Re: Brake switch adjustment [Re: GMP440] #2657075
05/19/19 10:43 PM
05/19/19 10:43 PM
541 slobovia
A990 Offline
A990  Offline
541 slobovia
Those switches are pretty junky. They come apart and the brake lights turn on and I finally had to glue it together.
Re: Brake switch adjustment [Re: A990] #2657077
05/19/19 11:01 PM
05/19/19 11:01 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
You could just manually adjust the brakes through the hole in the backing plate.
Re: Brake switch adjustment [Re: stumpy] #2657082
05/19/19 11:12 PM
05/19/19 11:12 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
haha
Make sure the adjusters are in the correct side, or the brakes will get tighter every time you use them.
Causes all kinds of problems
Don't ask.
whistling
I have mechanical Aptitude.
I can screw up anything.
Re: Brake switch adjustment [Re: bboogieart] #2657180
05/20/19 10:40 AM
05/20/19 10:40 AM
moparx Offline
moparx  Offline
Originally Posted by bboogieart
haha
Don't ask.
whistling
SAAA....MOKIN' !!! [in my best jim carey voice biggrin]
not that i have ever experienced this....... laugh2
beer
Re: Brake switch adjustment [Re: hemirdrnnr] #2657186
05/20/19 10:54 AM
05/20/19 10:54 AM
South Bend
John Brown Offline
John Brown  Offline
South Bend
Looks to be a SLS66 in Standard Ignition.
Re: Brake switch adjustment [Re: John Brown] #2657315
05/20/19 07:57 PM
05/20/19 07:57 PM
Mobile Al
hemirdrnnr Offline
hemirdrnnr  Offline
Mobile Al
Thanks for the # !!!
