Re: Brake switch adjustment
[Re: stumpy]
#2656990
05/19/19 07:21 PM
05/19/19 07:21 PM
Posts: 1,637 Florida
GMP440
Or you could get the heavy duty white switch that screws into that hole. That one is adjustable. Had the same problem as you years ago with the press on switch. It would never disingage. I switched to the screw on version and never had a problem again.
[Re: GMP440]
#2657075
05/19/19 10:43 PM
05/19/19 10:43 PM
Posts: 2,725 541 slobovia
A990
541 slobovia
Or you could get the heavy duty white switch that screws into that hole. That one is adjustable. Had the same problem as you years ago with the press on switch. It would never disingage. I switched to the screw on version and never had a problem again. Those switches are pretty junky. They come apart and the brake lights turn on and I finally had to glue it together.
[Re: stumpy]
#2657082
05/19/19 11:12 PM
05/19/19 11:12 PM
Posts: 3,886 Lost and Spaced
bboogieart
Lost and Spaced
Make sure the adjusters are in the correct side, or the brakes will get tighter every time you use them. Causes all kinds of problems Don't ask.
I have mechanical Aptitude. I can screw up anything.
[Re: hemirdrnnr]
#2657186
05/20/19 10:54 AM
05/20/19 10:54 AM
Posts: 1,820 South Bend
John Brown
South Bend
white switch that screws / Do you have a part # for that switch? Looks to be a SLS66 in Standard Ignition.
