Which Intake manifold for a mild 440? #2655186
05/13/19 10:35 PM
05/13/19 10:35 PM
USA
440mopar Offline OP
440mopar  Offline OP
USA
Which intake manifold would be a better choice for a relatively mildly built, street driven 440 with a 750 cfm carb, an Edelbrock CH4B or a Performer RPM?
Re: Which Intake manifold for a mild 440? [Re: 440mopar] #2655191
05/13/19 10:48 PM
05/13/19 10:48 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Performer RPM
wave
Re: Which Intake manifold for a mild 440? [Re: MR_P_BODY] #2655203
05/13/19 11:04 PM
05/13/19 11:04 PM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
^^^^ What he said......
Re: Which Intake manifold for a mild 440? [Re: MR_P_BODY] #2655251
05/14/19 08:17 AM
05/14/19 08:17 AM
an8sec70cuda Offline
Originally Posted by MR_P_BODY
Performer RPM
wave
iagree If you need more hood clearance, the Holley Street Dominator is a good bit shorter, but performs almost identically to the Performer RPM.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Which Intake manifold for a mild 440? [Re: an8sec70cuda] #2655570
05/14/19 10:34 PM
05/14/19 10:34 PM
As said do the math on the heights you have cuz the RPM is very tall. Otherwise any used/cheap dual plane will work fine.
Re: Which Intake manifold for a mild 440? [Re: RapidRobert] #2655720
05/15/19 03:08 PM
05/15/19 03:08 PM
Minnesota, USA
minnesota guy Offline
Minnesota, USA
I concur if lack of hood clearance, use the Street Dominator, otherwise Performer RPM. I actually use both right now on 2 of my mild 440's.
Re: Which Intake manifold for a mild 440? [Re: minnesota guy] #2655767
05/15/19 06:33 PM
05/15/19 06:33 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
I'm a big fan of the Holley Street Dominator!
I'm back to running a flat hood and really like the way it fits and performs.
'63 Dodge 330
11.19 @ 121 mph
Re: Which Intake manifold for a mild 440? [Re: 440mopar] #2655780
05/15/19 07:06 PM
05/15/19 07:06 PM
Idaho
LaRoy Engines Offline
Idaho
Of the two? The one you already own. If you don't already own one, use the other advice that makes you happiest.
Re: Which Intake manifold for a mild 440? [Re: LaRoy Engines] #2655788
05/15/19 07:25 PM
05/15/19 07:25 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
“Mild 440” isn’t enough of a description for me to lean in one direction or another with regards to choosing an intake manifold...... other than to assume a Super Victor, TF, Team G, or other similar type of intakes wouldn’t be the best choice if the motor is in fact “mild”.
What it’s going in, and how it will be used should also be part of the conversation.
Re: Which Intake manifold for a mild 440? [Re: fast68plymouth] #2655831
05/15/19 09:15 PM
05/15/19 09:15 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
FWIW, the Perf RPM on a 440 fits fine under an early-B hood using a drop-base air cleaner & Holley carb.
Re: Which Intake manifold for a mild 440? [Re: LaRoy Engines] #2655966
05/16/19 10:34 AM
05/16/19 10:34 AM
Chicago, IL
TonyS451 Offline
TonyS451  Offline
Chicago, IL
penguin for a mild street car, thats prob the best advice right there! Or, you can read Andys intake manifold comparo article, which also has some good info.
2 kids and a dog
