Re: Which Intake manifold for a mild 440?
[Re: MR_P_BODY]
#2655251
05/14/19 08:17 AM
05/14/19 08:17 AM
Posts: 13,363 Marion, South Carolina [><]
an8sec70cuda
Performer RPM If you need more hood clearance, the Holley Street Dominator is a good bit shorter, but performs almost identically to the Performer RPM.
[Re: an8sec70cuda]
#2655570
05/14/19 10:34 PM
05/14/19 10:34 PM
RapidRobert
As said do the math on the heights you have cuz the RPM is very tall. Otherwise any used/cheap dual plane will work fine.
[Re: minnesota guy]
#2655767
05/15/19 06:33 PM
05/15/19 06:33 PM
Posts: 4,673 Wichita
GY3
Wichita
I'm a big fan of the Holley Street Dominator!
I'm back to running a flat hood and really like the way it fits and performs.
[Re: 440mopar]
#2655780
05/15/19 07:06 PM
05/15/19 07:06 PM
Posts: 559 Idaho
LaRoy Engines
Idaho
Which intake manifold would be a better choice for a relatively mildly built, street driven 440 with a 750 cfm carb, an Edelbrock CH4B or a Performer RPM? Of the two? The one you already own. If you don't already own one, use the other advice that makes you happiest.
[Re: LaRoy Engines]
#2655788
05/15/19 07:25 PM
05/15/19 07:25 PM
Posts: 14,498 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
“Mild 440” isn’t enough of a description for me to lean in one direction or another with regards to choosing an intake manifold...... other than to assume a Super Victor, TF, Team G, or other similar type of intakes wouldn’t be the best choice if the motor is in fact “mild”.
What it’s going in, and how it will be used should also be part of the conversation.
[Re: LaRoy Engines]
#2655966
05/16/19 10:34 AM
05/16/19 10:34 AM
Posts: 4,296 Chicago, IL
TonyS451
Chicago, IL
Which intake manifold would be a better choice for a relatively mildly built, street driven 440 with a 750 cfm carb, an Edelbrock CH4B or a Performer RPM? Of the two? The one you already own. If you don't already own one, use the other advice that makes you happiest. for a mild street car, thats prob the best advice right there! Or, you can read Andys intake manifold comparo article, which also has some good info.
2 kids and a dog
