aftermarket billit thermostat housing for big blocks ? #2652525
05/06/19 10:36 AM
05/06/19 10:36 AM
moparx Offline OP
moparx  Offline OP
i'm looking for an aftermarket thermostat housing, the billet type with an O-ring seal.
upon searching the usual places, it seems the ones offered are generic chevy parts when you read the fine print. i know they will physically bolt up, but when i inquired to several vendors, they [for some reason] couldn't supply me with the O-ring diameter.
does anyone know of a vertical [not swivel] billet housing that will correctly fit a thermostat, and bolt to an aluminum water pump housing with a 2" diameter thermostat hole ?
TIA ! bow
beer
Re: aftermarket billit thermostat housing for big blocks ? [Re: moparx] #2652527
05/06/19 10:40 AM
05/06/19 10:40 AM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
Don't know about the O-ring type but Napa sells a nice OE replacement for like $7... Whatever U do avoid that chunky chrome china job they warp & leak badly..
Just my $0.02... wink
Re: aftermarket billit thermostat housing for big blocks ? [Re: moparx] #2652528
05/06/19 10:45 AM
05/06/19 10:45 AM
N.W. Florida
Fat_Mike Offline
Fat_Mike  Offline
N.W. Florida
Hughes Engines.
Re: aftermarket billit thermostat housing for big blocks ? [Re: Fat_Mike] #2652534
05/06/19 11:00 AM
05/06/19 11:00 AM
moparx Offline OP
moparx  Offline OP
no chunkychinachrome wanted at any cost ! this will be painted. i'm not a "shiny" kind of guy.
as the saying goes : "chrome don't getcha' home !"
beer
Re: aftermarket billit thermostat housing for big blocks ? [Re: Fat_Mike] #2652544
05/06/19 11:10 AM
05/06/19 11:10 AM
Iowa
burdar Online work
Owen's Dad
burdar  Online Work
Owen's Dad
Iowa
https://www.summitracing.com/parts/bsp-90820/overview/
I'm pretty sure this is the one I bought for my small block. I haven't run the engine yet to see if it seals. I did notice that once the housing was tightened down, the thermostat was still a little loose. The stock thermostat housing holds the thermostat tight. Not sure if this is a big deal or not. I did add a little sealer to the perimeter of the thermostat and it doesn't move now.
Re: aftermarket billit thermostat housing for big blocks ? [Re: burdar] #2652634
05/06/19 02:08 PM
05/06/19 02:08 PM
Wheatfield, NY
Cuda340 Offline
Cuda340  Offline
Wheatfield, NY
Re: aftermarket billit thermostat housing for big blocks ? [Re: Cuda340] #2652642
05/06/19 02:50 PM
05/06/19 02:50 PM
Gilroy,CA.
mopardude318 Offline
Gilroy,CA.
This is what you want.
https://bobmazzoliniracing.com/store/#!/Billet-Aluminum-Water-Neck-Package/p/24086606/category=4769098
408 Stroker 533 HP 520 FT LBS...........................1970 Dart RMS AlterKation
Re: aftermarket billit thermostat housing for big blocks ? [Re: mopardude318] #2652647
05/06/19 02:59 PM
05/06/19 02:59 PM
Howell, Michigan
Hemidavey Offline
Hemidavey  Offline
Howell, Michigan
We have removed several of the chrome ones at my shop, they are always warped. We thought customers were over tightening them until I resurfaced one, it was so soft it clogged my 12" disc sander. They are dead soft! That billit one Mancini sells works good.
Re: aftermarket billit thermostat housing for big blocks ? [Re: Hemidavey] #2652699
05/06/19 05:55 PM
05/06/19 05:55 PM
On a side note: confirm it is flat & don't overtorque. One place I would use "the right stuff" cement WITH a thin gasket.
Re: aftermarket billit thermostat housing for big blocks ? [Re: RapidRobert] #2652719
05/06/19 07:06 PM
05/06/19 07:06 PM
Alberta Canada
PossessedDuster Offline
Alberta Canada
I went with this set-up http://www.terrysautolab.com/
Billet, and uses an o-ring not made in China either works great and no more leaks.
Re: aftermarket billit thermostat housing for big blocks ? [Re: PossessedDuster] #2653644
05/09/19 10:39 AM
05/09/19 10:39 AM
moparx Offline OP
moparx  Offline OP
duster, that almost looks like a chevy housing with an adapter ? i know there are several housings out there that claim to be for our mopars, but on closer inspection in the details, it says "universal chevy". i know the chevy t-stat is smaller, so a couple outfits i contacted for dimensions, they claimed their supplier didn't have these available, and one said the OD of the O-ring was 2.25. that would just cover the housing hole, which is 2", and i wouldn't feel comfortable with it being that close.
beer
Re: aftermarket billit thermostat housing for big blocks ? [Re: burdar] #2654170
05/10/19 09:17 PM
05/10/19 09:17 PM
N.E. Ohio
K
KillerBee Offline
KillerBee  Offline
K
N.E. Ohio
This is the one I used on my wife 440 Six Pack engine with polished PRW aluminum housing.
Installed dry with no sealant and hasn't leaked a drop in 3 years.
Re: aftermarket billit thermostat housing for big blocks ? [Re: PossessedDuster] #2654358
05/11/19 03:02 PM
05/11/19 03:02 PM
nj
JAMESDART Offline
JAMESDART  Offline
nj
I've used a couple of the 440source billet ones, I can't remember if they are o ring but the seal good.
