aftermarket billit thermostat housing for big blocks ?
#2652525
05/06/19 10:36 AM
05/06/19 10:36 AM
Posts: 19,355 north of coder
moparx
i'm looking for an aftermarket thermostat housing, the billet type with an O-ring seal. upon searching the usual places, it seems the ones offered are generic chevy parts when you read the fine print. i know they will physically bolt up, but when i inquired to several vendors, they [for some reason] couldn't supply me with the O-ring diameter. does anyone know of a vertical [not swivel] billet housing that will correctly fit a thermostat, and bolt to an aluminum water pump housing with a 2" diameter thermostat hole ? TIA !
Re: aftermarket billit thermostat housing for big blocks ?
[Re: Cuda340]
#2652642
05/06/19 02:50 PM
05/06/19 02:50 PM
Posts: 339 Gilroy,CA.
mopardude318
Gilroy,CA.
This is what you want.
https://bobmazzoliniracing.com/store/#!/Billet-Aluminum-Water-Neck-Package/p/24086606/category=4769098
408 Stroker 533 HP 520 FT LBS...........................1970 Dart RMS AlterKation
[Re: Hemidavey]
#2652699
05/06/19 05:55 PM
05/06/19 05:55 PM
RapidRobert
On a side note: confirm it is flat & don't overtorque. One place I would use "the right stuff" cement WITH a thin gasket.
[Re: PossessedDuster]
#2653644
05/09/19 10:39 AM
05/09/19 10:39 AM
moparx
duster, that almost looks like a chevy housing with an adapter ? i know there are several housings out there that claim to be for our mopars, but on closer inspection in the details, it says "universal chevy". i know the chevy t-stat is smaller, so a couple outfits i contacted for dimensions, they claimed their supplier didn't have these available, and one said the OD of the O-ring was 2.25. that would just cover the housing hole, which is 2", and i wouldn't feel comfortable with it being that close.
[Re: burdar]
#2654170
05/10/19 09:17 PM
05/10/19 09:17 PM
Posts: 6,497 N.E. Ohio
KillerBee
N.E. Ohio
https://www.summitracing.com/parts/bsp-90820/overview/I'm pretty sure this is the one I bought for my small block. I haven't run the engine yet to see if it seals. I did notice that once the housing was tightened down, the thermostat was still a little loose. The stock thermostat housing holds the thermostat tight. Not sure if this is a big deal or not. I did add a little sealer to the perimeter of the thermostat and it doesn't move now. This is the one I used on my wife 440 Six Pack engine with polished PRW aluminum housing. Installed dry with no sealant and hasn't leaked a drop in 3 years.
