Re: is adding dynomat to a restored car.........
[Re: theraif]
#2651999
05/04/19 07:57 PM
05/04/19 07:57 PM
Posts: 21,405 It's a dry heat
gtx6970
It's a dry heat
hurt the $$ of the car since its not 100% factory Done right and as long as its not visible no parties will ever know its there unless you tell them. I use it in every car I've done for the past 10 years or more I use Fatmat . and if I use 2 rolls. it MIGHT add 75 lbs TOPS . And thats covering every square inch of the interior of the car . from the firewall to pkg shelf, and roof to floorpan, even inside the door shells
[Re: dangina]
#2652153
05/05/19 10:39 AM
05/05/19 10:39 AM
Posts: 6,710 KY
65pacecar
KY
I would say no unless your doing a concours resto - there are companies out there that are the same or better than dynamat without the high price tag - I used B-Quiet I agree, I have had good luck with Fat Mat too.
