is adding dynomat to a restored car......... #2651945
05/04/19 04:45 PM
05/04/19 04:45 PM
my own world
theraif Offline OP
theraif  Offline OP
my own world
hurt the $$ of the car since its not 100% factory work
Re: is adding dynomat to a restored car......... [Re: theraif] #2651950
05/04/19 05:10 PM
05/04/19 05:10 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
What is the rest of the car like? If it is close to 100% original and you're trying sell it, maybe, but if not and it is mainly where no one will see it and you want to drive it, then I say go for it.
Re: is adding dynomat to a restored car......... [Re: 71birdJ68] #2651954
05/04/19 05:20 PM
05/04/19 05:20 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
It wouldn't bother me, as long as it wasn't visible.
However, that stuff makes it impossible to judge interior condition of the floors, so I'd take photos that prove the floor condition prior to the Dynamat.
I added some NVH foam inside my old Chevy PU - primarily its roof, between the interior & exterior panels - and the thing is very quiet inside.
Even closing the doors, it seems a much higher-quality cab, and it's the poverty model that used to sound like the inside of a snare drum.
Re: is adding dynomat to a restored car......... [Re: topside] #2651965
05/04/19 05:48 PM
05/04/19 05:48 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
It is a real b!tch to remove so once its there, all parties better be happy with it !!
Re: is adding dynomat to a restored car......... [Re: theraif] #2651999
05/04/19 07:57 PM
05/04/19 07:57 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Done right and as long as its not visible no parties will ever know its there unless you tell them.
I use it in every car I've done for the past 10 years or more
I use Fatmat . and if I use 2 rolls. it MIGHT add 75 lbs TOPS . And thats covering every square inch of the interior of the car . from the firewall to pkg shelf, and roof to floorpan, even inside the door shells
Re: is adding dynomat to a restored car......... [Re: gtx6970] #2652022
05/04/19 09:32 PM
05/04/19 09:32 PM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
If it's a paint dab restoration I wouldn't recommend it. Otherwise do as you see fit. twocents
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: is adding dynomat to a restored car......... [Re: GoodysGotaCuda] #2652042
05/04/19 11:21 PM
05/04/19 11:21 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
Last consideration factor would be the weight added to the vehicle..Depending on how much you use it can add a considerable amount of weight to the vehicle..
Re: is adding dynomat to a restored car......... [Re: theraif] #2652065
05/05/19 01:07 AM
05/05/19 01:07 AM
AndyF Offline
AndyF  Offline
I have dynomat in my '65 Coronet 500. My car is an original 426W four speed car so the dynomat probably does hurt the resell value. Of course, the mini-tubs, Porsche disc brakes, Dana 60 and EFI probably also hurt the resell value so I suppose it doesn't matter much to me.
Re: is adding dynomat to a restored car......... [Re: AndyF] #2652068
05/05/19 01:36 AM
05/05/19 01:36 AM
Lethbridge, AB, Canada
dangina Offline
dangina  Offline
I would say no unless your doing a concours resto - there are companies out there that are the same or better than dynamat without the high price tag - I used B-Quiet
Re: is adding dynomat to a restored car......... [Re: dangina] #2652153
05/05/19 10:39 AM
05/05/19 10:39 AM
KY
65pacecar Offline
65pacecar  Offline
KY
I agree, I have had good luck with Fat Mat too.
Re: is adding dynomat to a restored car......... [Re: 65pacecar] #2652310
05/05/19 04:12 PM
05/05/19 04:12 PM
my own world
theraif Offline OP
theraif  Offline OP
my own world
watching a show whistling that claims as day it left factory grin i was the factory didn't do that
