94 Jeep GC- HVAC fan runs WFO with the key off. #2649784
04/28/19 09:10 AM
04/28/19 09:10 AM
A certified culture free zone.
74RALLYE Offline OP
74RALLYE  Offline OP
The HVAC blower motor on Pop's 94 Jeep GC runs WFO with the ignition key removed. I looked at a shop manual and suspect that a relay or control module might be the problem. The manual didn't show the physical location of any of these components. I'm guessing I need to pull the dash to find them.
Has anyone seen or fixed an issue like this? The Jeep also has the Automatic Temperature Control option. I tried pulling all of the relays and connectors that I could physically reach with no luck. Also, the AC compressor will not come on while the fan is in this WFO mode.
Re: 94 Jeep GC- HVAC fan runs WFO with the key off. [Re: 74RALLYE] #2649830
04/28/19 11:11 AM
04/28/19 11:11 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
WFO is Wide F+++ Open? I would think the main fuse for the blower would be under the hood in the big fuse box. Did you pull that?
Coming soon!!!!
Re: 94 Jeep GC- HVAC fan runs WFO with the key off. [Re: Mr.Yuck] #2649845
04/28/19 11:35 AM
04/28/19 11:35 AM
74RALLYE Offline OP
74RALLYE  Offline OP
Yes, the fuse will shut down the blower motor, but that doesn't fix the problem.
Re: 94 Jeep GC- HVAC fan runs WFO with the key off. [Re: 74RALLYE] #2649877
04/28/19 12:59 PM
04/28/19 12:59 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
I know nothing but duck duck go comes up with this one
https://www.2carpros.com/questions/1993-jeep-grand-cherokee-blower-motor-wont-turn-off
it's a head scratcher
Don't be the exception.
Re: 94 Jeep GC- HVAC fan runs WFO with the key off. [Re: Supercuda] #2649880
04/28/19 01:09 PM
04/28/19 01:09 PM
74RALLYE Offline OP
74RALLYE  Offline OP
Thanks for the link, but I finally found a thread on a Jeep forum that matches my problem. It's likely the motor control resistor. You would think a resistor only goes open when defective, but I think it's more like a solid state speed controller.
Re: 94 Jeep GC- HVAC fan runs WFO with the key off. [Re: 74RALLYE] #2649889
04/28/19 01:21 PM
04/28/19 01:21 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Pretty sure they are two names for the same thing.
RA has them, price isn't too bad unless you have the automatic temperature control setup, then it's pricey.
Re: 94 Jeep GC- HVAC fan runs WFO with the key off. [Re: 74RALLYE] #2650005
04/28/19 08:43 PM
04/28/19 08:43 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
yes I know, just so you could shut it off until u figure it out.
Coming soon!!!!
Re: 94 Jeep GC- HVAC fan runs WFO with the key off. [Re: 74RALLYE] #2650047
04/28/19 11:13 PM
04/28/19 11:13 PM
It's a dry heat
gtx6970 Online content
gtx6970  Online Content
It's a dry heat
Pretty common actually .
Ive had the main control assy do the same thing. just not near as common
Re: 94 Jeep GC- HVAC fan runs WFO with the key off. [Re: Mr.Yuck] #2650122
04/29/19 09:24 AM
04/29/19 09:24 AM
74RALLYE Offline OP
74RALLYE  Offline OP
Hey Mr Yuck, Sorry for the snippy reply. I was having "one of those days"
